System Name | WorkInProgress |
Processor | AMD 7800X3D |
Motherboard | MSI X670E GAMING PLUS |
Cooling | Thermalright AM5 Contact Frame + Phantom Spirit 120SE |
Memory | 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32 |
Video Card(s) | Gainward RTX 4070Ti Phantom Reunion (The54thvoid Edition) |
Storage | WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming)| 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) {1xCorsair ML120 Pro|5xML140 Pro} |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Seasonic Focus GX-850 80+ GOLD |
Mouse | Logitech G502 X |
Keyboard | Cherry G80-3000N (TKL) |
Software | Windows 11 Home |
Benchmark Scores | ლ(ಠ益ಠ)ლ |
broken fan bearing
Explaining what your problem is first before throwing up links to random places usually helps a lot on these forums. Even more so if youre a person who just registered on the forum
System Name | Dumbass |
Processor | AMD Ryzen 7800X3D |
Motherboard | ASUS TUF gaming B650 |
Cooling | Artic Liquid Freezer 2 - 420mm |
Memory | G.Skill Sniper 32gb DDR5 6000 |
Video Card(s) | GreenTeam 4070 ti super 16gb |
Storage | Samsung EVO 500gb & 1Tb, 2tb HDD, 500gb WD Black |
Display(s) | 1x Nixeus NX_EDG27, 2x Dell S2440L (16:9) |
Case | Phanteks Enthoo Primo w/8 140mm SP Fans |
Audio Device(s) | onboard (realtek?) - SPKRS:Logitech Z623 200w 2.1 |
Power Supply | Corsair HX1000i |
Mouse | Steeseries Esports Wireless |
Keyboard | Corsair K100 |
Software | windows 10 H |
Benchmark Scores | https://i.imgur.com/aoz3vWY.jpg?2 |
yep most tend to ignore threads like this.Explaining what your problem is first before throwing up links to random places usually helps a lot on these forums. Even more so if youre a person who just registered on the forum
Thank you! Is there a way for me to fix it?
Sorry about that. I was just super frustrated after getting nowhere with Nvidia and Lenovo.
Please post pictures in the forum. They're very helpful! Attachments work very well here on TPU!Sorry about that. I was just super frustrated after getting nowhere with Nvidia and Lenovo.
Not everyone. We're all here. BTW, welcome to TPU!yep most tend to ignore threads like this.
System Name | stress-less |
Processor | 9800X3D @ 5425 MHZ |
Motherboard | MSI PRO B650M-A Wifi |
Cooling | Thermalright Phantom Spirit EVO (Intake) |
Memory | 64GB DDR5 6200 1:1 CL32-36-36, FCLK 2067 |
Video Card(s) | RTX 4090 FE |
Storage | 2TB WD SN850, 4TB WD SN850X |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | Jonsbo Z20 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | DeathadderV2 X Hyperspeed |
Keyboard | 65% HE Keyboard |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
Nevermind, watched the video, pictures wouldn't have helped.Please post pictures in the forum. They're very helpful!
Yes, that fan has dry bearings and needs some oil. You will need to take the housing off the card and take the fan off the housing. Then you will need to access the bearings on the back-side of the fan motor assembly. You might have to take off a label or remove a rubber bearing cap. Do NOT use WD40. Use a drop or two of a light oil like Marvel Mystery Oil or even full synthetic motor oil(5W30 or 10W30).Thank you! Is there a way for me to fix it?
This is were pictures of the card will be helpful. But yes, it should just be a few screws, then unplug the fan wires from the board. There should be a few more that attach the fan to the housing. Apply a drop or two right into the bearings, and put everything back together in the reverse order you took it all apart. Since you will have it all apart, it's best to oil both fans, just in case.I tried to find a video that would show how to take that card apart. So I release the 4 screws on the front?
System Name | H7 Flow 2024 |
Processor | AMD 5800X3D |
Motherboard | Asus X570 Tough Gaming |
Cooling | Custom liquid |
Memory | 32 GB DDR4 |
Video Card(s) | Intel ARC A750 |
Storage | Crucial P5 Plus 2TB. |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Eweadn Mechanical |
Software | W11 Pro 64 bit |
While true, the fan wires are almost always run through the shroud housing and can not be removed without first taking the shroud off the card.You can usually remove the fans by undoing two or three screws which are visible if you slowly turn the blades with your finger.
Once the screws are undone you only need to disconnect the wire at the connector.
Unless you think you have enough slack in the fan cables to move the fan around, yeah you'll need to take the shroud off. Based on your video, I can't tell. If you do have enough slack, then go for it.I do see the 3 screws visible through the blades. I could unscrew those. But you are saying that I first should take the shroud off the card?
That will work very well. But remember, just 1 or 2 drops. Too much and the excess oil will leak back out and get all over your card and attract dust.And I have full synthetic 10w-20
Processor | 5930k @ 3.7 normally; can do 4.1 stable |
Motherboard | asus rog rampage 5 |
Cooling | noctua server two fan air |
Memory | 16GB @2133 |
Video Card(s) | 1670 ti |
Storage | several SSD adding nvme soon |
Display(s) | lg 77" cx 4k, lg 55 b8 4k |
Case | big tower lots of fans including side and top fans |
Audio Device(s) | on board |
Power Supply | seasonic 1200watt |
Mouse | adjustable vertical |
Keyboard | really cheap |
Software | windows 8.1, Linux -dual boot different drives |
System Name | Black MC in Tokyo |
Processor | Ryzen 5 7600 |
Motherboard | MSI X670E Gaming Plus Wifi |
Cooling | Be Quiet! Pure Rock 2 |
Memory | 2 x 16GB Corsair Vengeance @ 6000Mhz |
Video Card(s) | XFX 6950XT Speedster MERC 319 |
Storage | Kingston KC3000 1TB | WD Black SN750 2TB |WD Blue 1TB x 2 | Toshiba P300 2TB | Seagate Expansion 8TB |
Display(s) | Samsung U32J590U 4K + BenQ GL2450HT 1080p |
Case | Fractal Design Define R4 |
Audio Device(s) | AuraSound AS42 Soundbar | Plantronics 5220 | Sony WH-1000XM3 | Nektar SE61 | Behringer XR18 |
Power Supply | Corsair RM850x v3 |
Mouse | Logitech G602 |
Keyboard | Dell SK3205 |
Software | Windows 10 Pro |
Benchmark Scores | Rimworld 4K ready! |
Not true at all. Oiling fan bearings that may have not been given enough lube at the point of manufacturing is a great long term solution. I rarely have to re-oil a fan after having done so. Fan bearings are not magic. Keep them lubed and they run great. If the lube dries up, re-lube, carry on.Unless you're very lucky oiling the fan won't buy you more than a few months...
That about sums it up.it's generally better to replace them--assuming you can find a suitable replacement.
ANot true at all. Oiling fan bearings that may have not been given enough lube at the point of manufacturing is a great long term solution. I rarely have to re-oil a fan after having done so. Fan bearings are not magic. Keep them lubed and they run great. If the lube dries up, re-lube, carry on.
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
I take it the warranty period is over? It's not an old card.
I clicked the dangerous link and found.... a video! whew
broken fan bearing seems likely, you didnt use compressed air and over-rev or spin the fan backwards did you?
Unless you're very lucky oiling the fan won't buy you more than a few months...it's generally better to replace them--assuming you can find a suitable replacement.
Replace the fan or the card?
either. you can find fan assembly's for that card on ebay. but i would contact the manufacturer first to see if they would be willing to ship you out a replacement before you modify the card if its still under warranty.
there are also 3rd party after market options available like Arctic Cooling who will do coolers for that card but in their case its more a case of replacing the stock heatsink for one of their better ones.
It all depends how much time and money you want to throw at it.
As for replacing the card -- since the PC is a business unit (or formerly a business unit) i would be cautious about what you upgrade to because those PCs dont tend to come with power supplies that can give a lot of juice.
