- Jun 2, 2017
- 9,828 (3.39/day)
System Name | Best AMD Computer |
Processor | AMD 7900X3D |
Motherboard | Asus X670E E Strix |
Cooling | In Win SR36 |
Memory | GSKILL DDR5 32GB 5200 30 |
Video Card(s) | Sapphire Pulse 7900XT (Watercooled) |
Storage | Corsair MP 700, Seagate 530 2Tb, Adata SX8200 2TBx2, Kingston 2 TBx2, Micron 8 TB, WD AN 1500 |
Display(s) | GIGABYTE FV43U |
Case | Corsair 7000D Airflow |
Audio Device(s) | Corsair Void Pro, Logitch Z523 5.1 |
Power Supply | Deepcool 1000M |
Mouse | Logitech g7 gaming mouse |
Keyboard | Logitech G510 |
Software | Windows 11 Pro 64 Steam. GOG, Uplay, Origin |
Benchmark Scores | Firestrike: 46183 Time Spy: 25121 |
So I bought a MSI X570S Ace Max and absolutely fell in love with it. The PCIe allocation, the features, the VRM and stability were all exemplary. Windows 11 will love your system if it is all NAND and this board delivered on those fronts. I have one of those WD AN1500 and since you can basically put any drive in there it has 4TB of storage (for the 1 TB price). The issue is that X570 is limited in terms of lanes. The beauty of this board is the 3rd PCIe slot is wired at x8. That meant that I was seeing 6 GB/s sequential as the x8 fills the slot allowing the Marvell controller to run at full speed (WD AN1500). As an example the Asus X570-E Strix can only run at x4. With that I see 3 GB/s sequential in the bottom slot. One of the features of MSI boards is Memory Try it. Even the boards that are given negative sentiment like the X570 Pro have this feature and I have used it with my APU system since the 3400G.
With that I was able to run DDR4-4000 18-18-22-22 no problem on the Ace Max board. Then one day I started getting WHEA errors. Then the weirdest thing that I have ever seen on AM4 happened. The 2nd RAM slot the one that you use first on builds became unrecognizable to the BIOS. I had to plug in 4 sticks just to get the PC to boot. Since that is a $600 board I started an RMA. I had no problem with the RMA but after 35 days I get an email stating that they were going to refund my RMA. Bemused I called them. While the associate was on the phone I had the website that I bought the board from up with the listing for the board. As the associate was telling me that they had no stock to give me I could see that I could buy the board for $50 less and have it delivered tomorrow.
I do have a ton of AM4 hardware( I can't believe they have 500 different boards) and I have noticed that the quality of AM4 boards from MSI have gotten a little flaky, like Gigabyte flaky.
Has anyone else had any problems with MSI boards made in the latter stages of 2021? The X570 lineup was pretty solid when it first came out. In some ways X470 is better from some vendors (MSI) than their X570S variants. The thing is the even the USB allocation is stellar. Now I am conflicted, do I get another one but the RMA should take about 2 weeks.
