What Voltages to Use for Underclocking RAM to 2933 and 2666?
275 (0.12/day)
Processor AMD Ryzen 7 3700x
Motherboard Aorus X570 Elite
Cooling EK AIO 120 D-RGB
Memory Corsair Vengenace LPX 2x8GB @ 3000MHz
Video Card(s) Aorus GTX 1080 Ti
Storage 1x 1TB PCIe 4.0 NVMe, 2x 1TB hard drive, 1x 120 GB SSD
Display(s) Aorus FV43U
Case Corsair 110R
Audio Device(s) Sound Blaster Z Card, Sennheiser GSP 600, Razer Nommo
Power Supply be quiet! System Power 9 600W
Keyboard Logitech G915
VR HMD Oculus Quest 2
I have two sticks of Vengeance LPX 3000mhz RAM, what voltages should I set them for when underclocking them to 2933MHz and 2666MHz?
18,450 (2.47/day)
1.2V is standard Voltage for DDR4, but maybe not at 2933. Try 1.3 or 1.25V.
Why would you want to underclock the RAM though?
275 (0.12/day)
Case Corsair 110R
So do I do 1.3V then for both 2666 and 2933?
18,450 (2.47/day)
2666 ought to run at 1.2V, but you're simply going to have to try. I mean, the system either works, or it doesn't.
You might have to loosen up the timings if you want low Voltage and higher speeds as well.
9,828 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
You would have to see if your RAM supports 1.2 but I would not worry about that as undervolting RAM is actually pointless. When you pick the speed in the BIOS it should adjust the voltage accordingly but will stay at 1.35 which is the default setting for the RAM you have. I guess you have not updated your specs in a while as it still shows you have an FX processor.
275 (0.12/day)
Case Corsair 110R
My BIOS doesn't adjust them automatically so that's why I'm asking here. Also no I'm not running on an fx on my main PC now.
3,152 (0.90/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
RAM undervolting wont help much in reducing power consumption.
Anyway, I'm currently at 2933MHz at the standard 1.2v. With normal latencies, you should be able to archive something similar.
1,487 (0.31/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
You need to update your system specs so people can help you better. Yes the new motherboards have an auto setting for ram as well as XMP setting for OC profiles for ram. update your specs
Your ram 2933 will only run at the 2666 speeds as well. The default voltage for 2666 is fine as well. It is not recommended that you mix match ram and speeds because it can cause system instability and you will be back asking more questions why my system is sluggish or whatever.
Before you say again you do not have an auto setting update your specs and or link your new motherboard.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
I have Vengeance LPX Ram, I have gone the opposite way, stock voltage at 3000mhz is 1.30 for mine @ CL15 (I think), I can do 3200mhz at CL16 or 3100mhz @ CL15 both on 1.35V @ 1T.......... for you I would just be safe and set at 1.30v for either speeds and leave it there, I have no doubts 2666 would run at 1.25V but it's unlikely 2933 will unless you tweak timings accordingly.
If you really want to keep voltage low then maybe leave at 1.25v and you may be able to set 2666 @ CL14 and also at 1.25v you may get away with 2933 @ CL16, have a play.
275 (0.12/day)
Case Corsair 110R
I think you just misunderstood my post. My RAM isn't 2933, it's 3000 stock, and I want to know what voltages to set it to when underclocking to 2933 and 2666.
I'm not trying to reduce power consumption or anything so I just need to know what voltages to set them to so it's stable or whatever else, never really underclocked RAM before.
9,828 (3.41/day)
Cooling In Win SR36
Are you saying you don't have XMP profiles on your BIOS?
All you have to do is enable the XMP profile and pick 2933 as the RAM speed. I doubt you will see a difference of any kind in terms of power draw. You will not see 1.2 volts at 2933 as that is only 67 away from the stock clock. BTW if you are on Ryzen it actually hurts performance to run at lower speeds. My thoughts are to leave the RAM as is and suck up the 2 cents a month premium for running at stock voltages.
275 (0.12/day)
Case Corsair 110R
I do have XMP, I just thought that only worked with overclocking, not underclocking, so I'll try just to use that then to underclock.
757 (0.34/day)
XMP will run your modules at what they are rated at. You’re over complicating this for no reason, fella.
275 (0.12/day)
Case Corsair 110R
I've never underclocked RAM before so I don't fully understand what needs to be done for it.
9,828 (3.41/day)
Cooling In Win SR36
Just enable the XMP profile.
275 (0.12/day)
Case Corsair 110R
127097
So I turned on XMP and then lowered the multiplier to 2666. Is that it?
9,828 (3.41/day)
Cooling In Win SR36
318 (0.05/day)
WA, USA
System Name Desktop
Processor AMD Ryzen 5950X
Motherboard ASUS Strix B450-I
Cooling be quiet! Dark Rock TF 2
Memory 32GB DDR4 3600
Video Card(s) AMD RX 6800
Storage 480GB MyDigitalSSD NVME
Display(s) AOC CU34G2X
Power Supply 850w
Mouse Razer Basilisk V3
Keyboard Steelseries Apex 5
Why not run it at 3000? I'm still so very confused...
Ryzen doesn't like 3000, so it normally goes to 2933.
I think the issue is/was he thought he needed to undervolt since it's downclocking. You don't need to undervolt, just leave it at 1.35v.
Maybe even try 1.4v and 3200
757 (0.34/day)
Yep, run it at 3200 with a slight bump in voltage if that's the case.
I haven't heard of 3000 being an issue, but I haven't bothered checking either.
19,379 (3.46/day)
Yeah... feels like half of a story. Did you try xmp and was it not stable? What's the whole story here?
What's the reason you want to use 2933? That is below the BASE spec of your CPU (which is 3200). AMD recommends 3600 speed, in fact.
As far as what voltage... who knows exactly. You can try lowering it to the suggested 1.3 and see if that works....but there isnt a cookie cutter setting. You'll have to make some effort to check and test for stability.
4,914 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
I've found out I can get away with 3200 MHz and 18-19-19-19-38 at 1.2v. Doesn't hurt to experiment with the settings.
4,914 (1.48/day)
Crank that voltage! C18 is mega loose at 3200.
I was messing around with how loose the timings have to be to run 3200 MHz with the voltage restricted to 1.2v. Timings are tighter than a new set of Crucial DDR4-3200 though.
The timings can be tightened to C15-17-17
