Whats faster, more FSB or a higher multi?
ShadowFold
16,918 (2.65/day)
Omaha, NE
System Name The ShadowFold Draconis (Ordering soon)
Processor AMD Phenom II X6 1055T 2.8ghz
Motherboard ASUS M4A87TD EVO AM3 AMD 870
Cooling Stock
Memory Kingston ValueRAM 4GB DDR3-1333
Video Card(s) XFX ATi Radeon HD 5850 1gb
Storage Western Digital 640gb
Display(s) Acer 21.5" 5ms Full HD 1920x1080P
Case Antec Nine-Hundred
Audio Device(s) Onboard + Creative "Fatal1ty" Headset
Power Supply Antec Earthwatts 650w
Software Windows 7 Home Premium 64bit
Benchmark Scores -❶-❸-❸-❼-
Im just wondering if 400 x 8 or 337 x 9.5 is a faster 3.2ghz or are they the same?
higher fsb
A higher FSB would equal more performance.
Higher FSB and because it affects more than your processor.
agreed, better overall system performance from a higher BUS.
unless you do a lot of task and applications that are CPU-only intensive, higher CPU clock isn't as effective of a performance gain.
Higher FSB. Because the FSB affects other components too but multi only affects the cpu.
MOAR FSB
even if you had settings that had everything running at stock except for the CPU and FSB, same speed on the CPU produced by both settings... moar fsb wins
Unless you have very good RAM, a higher FSB will mean higher timings for the RAM which will actually slow you down.
Also higher fsb will need more voltages which will decreasing liftime which is a bad thing....
Higher speed doesn't always warrant higher voltages.
Totally right, dude!
That's why there aren't many x * 7 multi overclocks out there! Even with good RAM, those wouldn't last very long (unless they were low OCs).
It is the same thing for Intel and AMD? Cause i know their architechtures are different in the FSB implementation, a higher FSB is always better?
Ty in advance :toast:
In AMD they always win in Bandwidth with their more superior Hyper Transport.
yes higher FSB is better regardless of architecture..because its over all system bandwidth not just ram or proc...the diff you may be thinking of is timings...from what i here AMD likes tigher timings were as intel it doesnt matter so much
Intel's FSB is the chokepoint for the whole system. All the information from ram to cpu and cpu to everything must pass through the fsb. Getting that as high as possible is more important than tight timings. Of course, RAM is a key factor and if it is working very ineffectively, then sacrificing a little fsb for RAM performance is good. Its a balance.
AMD does not have a FSB sirkeldon. Their procs communicate directly w/ the ram via HT i believe, however I am not as familiar w/ their architecture.
  • Like
Reactions: HTC
Your correct Farlex85!
This is part of the reason AMD you want tight timings and don't need such massive bandwidth for equal performance.
That's why, in my case, with RAM @ 5-5-5-15 @ 1062 MHz is actually slower then RAM @ 4-4-4-10 @ 884 MHz, even though Everest says otherwise (difference of about 400 in memory read). In Nero Recode, it's slightly faster with 884 then 1062: about 12 seconds.
I agree, a higher FSB would benefit a system more than simply using a higher multiplier. Now, both on the other hand would be even better!
HAT, I'm with you, an overclock does not always involve added voltage. Though, with sufficient cooling, the additional voltage will not affect shelf-life in any way.
As for those worried about memory, that is why they invented dividers. You can run your memory faster than the FSB, the same speed, or slower. Run the crap out of them, drop some more voltage, active cooling and get those timings down. Either that or run them stock. Whichever is your preference.
This is the truth. Both are the best for the greatest overall performance boost.
the important thing is to get the cpu speed up.. useing a higher multiplier is just an easier way to do this without stressing the rest of the less important bits or adding more instability problems than u have to..
but in theory (in a perfect world) everything should be as fast as possible but higher cpu speed is the best performance gain.. the rest is secondary and might cause more problems than its worth for any small additional gains..
trog
With his board, 400fsb is a non-issue. So 400x8 is better either way.
excessive voltage will shorten the life no matter what the cooling is. If I had one of those uber leet xigmatek coolers and I lived in the north pole, I could still run 1.6v through my processor all the time and knock some life off it.
thats absolutely true hat..but with how fast most of this community change parts it usually isnt an issue.
