- Jan 12, 2010
- 1,526 (0.27/day)
System Name | Custom Built |
Processor | AMD Ryzen 5 3600 |
Motherboard | Asus PRIME A520M-A |
Cooling | Stock heatsink/fan |
Memory | 16GB 2x8GB Corsair Vengeance LPX 2400MHz |
Video Card(s) | MSI 1050Ti 4GB |
Storage | KINGSTON SNVS250G 256GB M.2 + 2 data disks |
Display(s) | Dell S2421NX |
Case | Aerocool CS103 |
Audio Device(s) | Realtek |
Power Supply | Seasonic M12II-520 EVO |
Mouse | Logitech MX Master 2S |
Keyboard | Logitech |
Software | Windows 11 Pro 64-bit |
Hi
I have this new build since Januarry and it works fine stability and performance-wise
But checking Event Viewer I saw two WHEA-Logger events. Both say this
A fatal hardware error has occurred. A record describing the condition is contained in the data section of this event.
They happened on Feb 4 and Feb 24
I don't remember any freezing/BSOD/reboot nor stability issue when they happened but the first one happened right after a (seemingly normal) boot after a Kernel-boot event (The boot type was 0x1)
The XML view for the Feb 4 event is this
- <Event xmlns=" ">
- <System>
<Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{c26c4f3c-3f66-4e99-8f8a-39405cfed220}" />
<EventID>1</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2021-02-04T05:27:30.5093180Z" />
<EventRecordID>39430</EventRecordID>
<Correlation ActivityID="{509fe7ac-fe26-4480-98e5-b63f7a4e4921}" />
<Execution ProcessID="4976" ThreadID="6444" />
<Channel>System</Channel>
<Computer>DESKTOP-xxxxxx</Computer>
<Security UserID="S-1-5-19" />
</System>
- <EventData>
<Data Name="Length">462</Data>
<Data Name="RawData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ata>
</EventData>
</Event>
Does anyone have a clue about what happened? I tried to find how to decode that string but nada!
Many thanks
- <Event xmlns=" ">
- <System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
</System>
- <EventData>
</EventData>
</Event>
Many thanks
