Which AIO cooler
251 (0.07/day)
System Name Iracing Beast
Processor 4790K Devils Canyon
Motherboard ASUS Z97 pro gamer
Cooling Corsair H80iV2
Memory Corsair Vengeance Pro DDR3 16 Gig 2446mhz 11-13-13-31 CRT2
Video Card(s) EVGA GTX 1070 SC2
Storage Scandisc 120 gig SSD, 250 gig SSD games, M.2 OS
Display(s) Oculus Rift
Case Antec Twelvehundred V3
Audio Device(s) ASUS Z97
Power Supply Antec 1000w
Mouse Microsoft
Keyboard Kuyimu gamers
Software Win10
Hey guys I am having a hard time figuring out which cooler to buy for my cpu and case.
So I have the Antec v3 twelve hundred case. Which has a top build in 200mm fan, 2 140mm front fans, 1 rear fan and 1 side panel fan.
http://store.antec.com/gaming-series/twelve-hundred-v3.html
I would like to run something like the corsair H series AIO but don't know how to install the radiator fan part in the case?
What would do?
Thank you
peche
Thermaltake fanboy
6,709 (1.75/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
well, you have plenty options there...
i dont like that much corsair's Hidro series, despite being made by Asetek as my loved thermaltake AIO does, when i was in your situation did some research about some AIO coolers, fount several interesting facts about my current Tt Water 3.0 Pro, thick rad, great tubing, decent cpu block / pump combo, also it outperforms some 240mm rad ones, also corsair had a bad season some years ago with several leakages on their coolers,
in your case you are able to install 120mm, 240mm units at the back,
i like the water3.0 pro cuz it save space inside and also performs great!
Regards,
251 (0.07/day)
Mouse Microsoft
Software Win10
Wow thank you. What is water 3.0 who makes it . So which cooler would you recommend around 130usd range
3,505 (0.60/day)
Haaaaang on. I hope the case doesn't really cost 200 bucks as it says on the website?
251 (0.07/day)
Mouse Microsoft
Software Win10
Well that is what they sold for new I guess. It is a 3 year old case. I bought a gAmer pc 2 years ago and came in it.
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
251 (0.07/day)
Mouse Microsoft
Software Win10
I live in seattle wa. But born in Bulgaria.
1,269 (0.33/day)
West Bromwich UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard AORUS X870E Elite WiFi 7
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Antec Flux+ 6 ARCTIC P14 PWM PST A-RGB
Audio Device(s) Marantz PM4001+Fosi P4+2xPolk XT60
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
I would advise to go for the Arctic Cooling Liquid Freezer 240 if it fits in that case other option would be the Corsair H80i GT. I have both coolers and they are very good.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Where it's cool almost all of the time. I'd suggest going with an air cooler instead. They're more reliable and even if the fan(s) stop working, they will continue to provide some cooling. With that case, you should have no problems fitting the largest air coolers, such as the D15S, Le Grand Macho RT which perform similarly with many of the AIO's.
1,207 (0.19/day)
Bitola, Macedonia
System Name Brutus
Processor AMD Ryzen 5600X PBO
Motherboard Asus Prime X570-P
Cooling EKWB AIO 240MM Push-Pull fans
Memory Patriot Viper Steel DDR4 4000 32GB (4x8) @4066 CL16, Custom Timings
Video Card(s) MSI RTX 3080 SuprimX 10GB
Storage Kingston A2000 500GB + Toshiba 1TB HDD
Display(s) Samsung 24" S24D300 + 2x LG LED 24"
Case Cooler Master H500
Audio Device(s) SB X-Fi Titanium Fatality Professional
Power Supply Sama Forza Modular 750W 80+ Gold
Mouse Cooler Master Master Keys Lite
Keyboard Cooler Master Master Keys Lite
I have an Antec 1200 myself, and I don't think there is enough space to fit a dual 120 rad in the back of the case, it's really close to the 200mm fan at the top. I might be wrong though
PS. Found this:
Corsair H100 in an Antec 1200
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
PS. Found this:
Professional?:shadedshu: A trip to the hardware store to get another set of those long screws would eliminate that whole hassle from the first part of the video, EDIT although I will admit that trying to wrestle the cooler plus 2 fans and then get the screws inserted at the same time is a real pain. Some double sided tape helps.
Here's a couple of pictures that I found. One appears to be a H50 and the other an H80.
H50 Having that "reservoir" bump in front of the other fan is not a problem.
H80. I think the "reservoir" part of the radiator, where the hoses attach, should be on the top.
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
1,207 (0.19/day)
Bitola, Macedonia
System Name Brutus
Ignore the word professional and all is well, I was surprised it fits :D
I've placed my Nepton 120XL like the 2nd picture, and it looks exactly the same, same thickness as well. You can put the hoses top or bottom, makes no difference. In fact, cooler master shows the product on their web page with the piping being at the bottom.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I prefer the hoses at the base of the radiator only for the reason evaporation can occur over time and air bubbles can cause cavitation and premature pump failure.
Ruru
S.T.A.R.S.
13,772 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Arctic Freezer 120/240's are cheap here in Finland and popular. I'd go for one if I'd get an AIO.
