Which motherboard should I get for my E6750, 8800 GT?
dropglock
22 (0.00/day)
First off this computer is going to be for gaming. I've read around forums and people suggest the p35 chipset. I got some that I like already and here is the list. The problem is I don't know which one to get. I want a motherboard that is easy to overclock my E6750 with because I haven't OCed a cpu yet. I also have a 22" Samsung LCD SyncMaster so would I need SLI to play games really smooth since the resolution is high? I need some help please.
Some mobo's on that list are around $140+ and I need to know if those are really worth it compared to the ones that are 90-$120 only. If not I might as well go with the cheaper one.
Thank You
GIGABYTE GA-P35C-DS3R LGA 775 P35 + ICH9R Motherboard
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005312
ASUS P5K SE Core 2 Quad Socket 775 1333MHz PC2-8500 (DDR2-1066) ATX
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005929
GIGABYTE Intel P35 + ICH9 Chipset DDR2 1066 ATX GA-P35-DS3L Rev 2.0(This is what I am thinking of getting, any ideas?)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10006307
DFI BLOOD IRON P35-T2RL LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136038
MSI P35 Neo2-FR Core 2 Quad Socket 775 1333MHz PC2-8500 (DDR2-1066) ATX Motherboard
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005412
GIGABYTE GA-N650SLI-DS4L Core 2 Quad Socket 775 1333MHz PC2-6400 (DDR2-800) ATX
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10007300
ASUS P5KC Core 2 Quad Socket 775 1333MHz DDR3 1333MHz
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005962
ASUS P5K-V Core 2 Quad Socket 775 1333MHz PC2-8500 (DDR2-1066) ATX
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005540
GIGABYTE GA-P35-DS3R Intel Core 2 Duo (Desktop) Socket 775 1333MHz PC2-8500 (DDR2-1066)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005276
abit IP35 pro.. the easiest overclocking there is.. do it all from windows with abit guru.. no sli thow..
trog
Gigabyte GA-P35C-DS3R
That mobo is a little over $140 so it might be a possibility, anyways..
I did some researching and according to the review the
is a overall good mobo for a budget gaming board. This is probably what I might get unless some of you guys can prove how this mobo is bad somehow? Here is where I read the information at. http://www.anandtech.com/mb/showdoc.aspx?i=3169&p=11&cp=4#comments
My other question is... Will this motherboard be able to work with Penryn in the future? The review says that it will be able too once they release a bio's update. To update the bios don't I need a floppy drive?
No you don't need a floppy drive. But if you have one it is strongly reccomended you use that method. Windows flashing is pretty risky.
you can also flash a lot with the flash drive cant you hat?
I don't know about flash drives. I have a floppy drive and it's a safe method, so I studied that one.
DFI blood iron if you know your way around a bios very well. otherwise all gigabyte p35 boards are good, just make sure you get the rev 2.
Rev.2 isnt that good, one feature that is rather useless that is missing is firewire. Just a side note. I'd purchase the GA P35 DS4 if I were you.
Couldn't have said it better myself. I love my Giga DS3R and my Blood Iron. Giga for it's stability, the Blood Iron for an awesome bios.
I prefer the blood iron for One thing, the fan control is awesome with the adjustable PWM, from 0 to 127, unlike most other boards that exclude this feature, saves me a lot of money; i dont have to buy fan controllers/resistors.
AHHHHHH!! So many choices =/ Right now I am debatting with the Gigabyte ds3r, ds3l, GA-P35C-DS3R , blood iron or the MSI P35 Neo2-FR.
Whats the difference with rev 1 and 2? How will I know which motherboard rev it is by looking online?
I say the DFI or the GB P35-DS3.
EDIT But GA-N650SLI-DS4L, is pretty nice too.
