Asus rog strix z690-gaming A DDR4 motherboard, and the ram that I purchased were these:
Memory Size
16GB (2 x 8GB)
Tested Latency
14-16-16-36
Tested Voltage
1.45
Tested Speed
3600
Now these ram work perfectly at 14-16-16-36 @ 1.45 volts, 3600mhz, gear 1:1 mode, 2T.
If I set the 2T to 1T I get BSOD's pretty quick once loaded into Windows 11 and sometimes the comp won't even load into the operating system. Why is this? Am I gonna see fps decrease in Battlefield 2042 because of this (or in games)? What's the point of me getting CL14 if I gotta be stuck using command rate 2T? I should have just gotten 32 gigs 3600mhz CL16 ram instead?
SIGH!
Any input/help/suggestions would be appreciated, thanks in advance.
Memory Size
16GB (2 x 8GB)
Tested Latency
14-16-16-36
Tested Voltage
1.45
Tested Speed
3600
SIGH!
