Mussels
Freshwater Moderator
- Oct 6, 2004
- 58,412 (7.77/day)
- Oystralia
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
This is a long story, so read it all before you jump in offering help. no need to cover unrelated/already tested ideas.
I have a TP link wireless N router - TL-WR941ND V2
i have four wireless N adaptors - two are 150Mb, two are (supposed to be) 300Mb in both directions.
The problem is that the 300Mb adaptors are being total dickbags. they run on the Ralink RT2870 chipset.
List of problems:
1. No matter what driver i use, they seem to report the upload speed in windows as the connected speed. From the router i can see differently - for example, this.
2. (ties in with 1.) No matter what i do, i cant seem to get a 300Mb upload speed which was why i bought these damn things in the first place. i can get 250-300Mb down, which is fine, but max of 150Mb upload is worthless... i might as well have stayed with my two 150Mb only adaptors if thats all i was going to get.
3. As soon as i install the ralink software (not just 'driver only') all wireless networking breaks on my machine, even for a realtek wifi adaptor. it seems to screw up windows built in wifi system, which it uses for its core features - so i cant disable the windows service and just run this, fyi.
This means that if the software had whatever cure i need for 300Mb, i cant use it
microsoft and ralink drivers changed nothing, i already tested a third party 300Mb adaptor and it worked fine, already flashed the router to DD-WRT - no change, the problem lies with the adaptors or their drivers.
Anyone got any ideas how to fix this?
List of problems:
