Greetings!
First I would like to say that I am in love with these forums. The wealth of information on these and the articles have been invaluble.
On to my issue.
I have been working with W1zzards guide in conjuction with a few other sites to try to unlock the other pipes on this card.
The card was purchased in December, from ATI. I have tried about 3-4 different bio's most of which are from this site with no success. The clock settings/XT features in the CAT drivers are unlocking fine, and the system is stable at even PE speeds. Only problem I have seen when I don't use my 850 Pro BIOS is that the fan on the GPU does not operate unless I use the ATI tool fan selection settings.
I have also read in another article referring to FUSE settings that report in ATI Tool. Upon further examining my settings it seems that mine do not have F's in the hex values where they need to be.
Just got done reading a post where someone modded a bios for someone who had a FUSE setting that differed. Was wondering if any of you could do the same for me.
If possible could there be a way to have control of my VPU fan, along with unlocking the XT options in the CAT drivers, and have the card operate at the XT default values. (So I don't have to run ATI Tool in the background. ) I'd really just like it to be at 100 percent at all times, not so much to lengthen it's lifespan but because noise doesn't matter. I'm useing a Thermalright SLK-80 with fan that sounds like a 747 moving 104 CFM. So I won't hear it anyways.
Manufacturer: ATI
Model: Radeon x850 Pro
BIOS Version: 009.008.001.004
BIOS Part Number: 113-A47503-103
BIOS Date: 2005/02/08
Bus Type: AGP
CONFIG_DIE_FUSES: 0xFFFFDFFF
CONFIG_SUBSTRATE_FUSES: 0xFFFFFF9E
CONFIG_ROM_FUSES: 0x860
CONFIG_PIPE_SELECT: 0xAD46
I attached my stock bios if that helps. Thanks for your time, and help. Hope ya'll had a good xmas. It's in txt format instead of bin i just renamed it under dos so it should go back i assume to a valid .bin file type.
Thanks again.
Eno
On to my issue.
Manufacturer: ATI
Bus Type: AGP
Thanks again.
Eno
