Xbox 360 controller keeps connecting/disconnecting
33 (0.01/day)
St Brelade, JE
System Name Desktop
Processor Intel i7 5820K CPU @ 4.5Ghz
Motherboard ASUS X99-S
Cooling Corsair H90i
Memory Corsair Vengeance 64GB DDR4 @ 2400Mhz
Video Card(s) 2x EVGA GTX 1070 (SLI)
Storage 4x250GB Crucial SSDs RAID 10 (OS/Apps), 4x1TB WD Black HDDs RAID 10 (Data), 2x2TB WB Black RAID 1
Display(s) Philips BDM4350UC 43" 4K @60Hz + BenQ 27" 1080p @60Hz
Case Cooler Master HAF X
Audio Device(s) Sound Blaster Z with Logitech Z506 Speakers and Astro A50 Headset
Power Supply EVGA SuperNova G2 1000Watt
Mouse Mad Catz R.A.T 8
Keyboard Razer Chroma RGB
My xbox controller keeps connecting/disconnecting, I hear the audio notification from Windows 10 that it's connected then disconnected constantly. I'm trying to play rocket league but my controller keeps going on/off. I've tried different ports front and rear on my PC and disabling USB power saving and selective suspend settings. The controller itself is fine, I swapped with my brother, mine stays connected on his, his on mine has the same problem. Any ideas?
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Is it wired or wireless?
33 (0.01/day)
St Brelade, JE
System Name Desktop
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Update chipset drivers? They usually include the USB host drivers.
33 (0.01/day)
St Brelade, JE
System Name Desktop
I actually think that cracked it, just played a round of rocket league and it didn't disconnect. I think I may have been using an 8.1 driver since there was no 10 release for a while. Fingers crossed as it disconnects every round but update, reboot and round of RL seems to be ok.
44,274 (6.80/day)
i hope cord isnt screwed up
Kanan
Tech Enthusiast & Gamer
3,517 (0.99/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Sometimes it's because of weak batteries too, had the problem and fixed it with charged batteries (I use rechargables with it).
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Great it's fixed. For reference, Microsoft have drivers specifically for it on their website.
AsRock
TPU addict
19,254 (2.95/day)
UK\USA
Cooling D15
Umm, i just plugged mine in and it auto installs the required drivers.
Good that you got it sorted out.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
It's funny, when I got my controller in April, the driver was just available on Microsoft Update and the controller worked without a hitch. However, I reinstalled W7 in June after the original got hosed due to that SATA problem I created a thread about some time ago. I then plugged the controller in after W10 was released and now that driver is no longer available from MU. Odd coincidence, isn't it?
The driver I'd downloaded off Microsoft's website did install and work properly at least.
AsRock
TPU addict
19,254 (2.95/day)
UK\USA
Cooling D15
Well after i posted what i did i was thinking that i upgraded from win 7 were as the OP upgraded from Win 8.1.
I have had my controller for years now, never had a issue tbh.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
For the controller itself, not USB. Most likely the driver Windows grabbed for the USB host didn't properly handle power saving modes so it kept disconnecting the device to conserve power. That's why installing the chipset drivers (includes USB) fixed the problem.
The driver ships with Windows 10. If you plug an Xbox controller into a PC, it automatically detects and uses the appropriate driver. There is nothing to install.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
there actually is a piece of software other than the built in HID drivers, but it isnt needed. From my experiences, Some people dont get the "plug it in and everything works out of the gate" result..(its happened to me once or twice), and they assume they need a driver. I dont know if its the fact that there are different brand Controllers, or what, but I can attest to the fact that it Does indeed happen. The software i referenced in the start of my reply, is some useless thing that does god knows what, but i have installed it myself. But im guessing its gotta be the different brand devices that yeilds different results from different users. for me it worked as you say on win 10, but on 7 it has done what i mentioned above, and worked on different PC's...i have no reason for why though.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Windows 10 has the driver (probably Windows 8/8.1 too), Windows 7 gets it through Windows Update.
I'm talking only about Microsoft branded Xbox controllers. Third party, I have no idea.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
I think you may have misunderstood, or perhaps me misunderstood you.
I'm saying that on W7 it no longer finds the driver on Microsoft Update, since W10 came out. which is a rather odd coincidence. I had to then install the driver I'd manually downloaded from Microsoft's site to fix this.
I'm not surprised that W10 supports it natively.
On a side note, that controller is very well designed and made. I've got an official Microsoft one in special edition colours. Check it out:
www.amazon.co.uk/gp/product/B00M35TNNU
33 (0.01/day)
St Brelade, JE
System Name Desktop
That was exactly the problem. When plugged into my brothers PC it was fine but he sits perfectly still when gaming, I tend to move around a bit and noticed it when I plugged back into my own PC. Every time I moved the cord I noticed it disconnects. I'm going to order a new controller this time probably wireless as the cord on this one is a bit disheveled and I tend to run over the cord with the chair a bit (I use wireless headsets for this reason).
PS: Does anyone know if an Xbox One controller would work with games on PC? I would just get a 360 controller but my brother has an Xbox One and said it'd make sense as a spare controller.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Microsoft Xbox One Controller + Wireless Adapter for Windows 10. Might want to consider getting the Play & Charge kit too. If you have a lot of microUSB cables laying around, you might be able to make due without it.
On the 360 side of things, you'd need the wireless controller for Windows (controller + USB receiver) and the Play & Charge kit (includes rechargeable battery pack and proprietary USB cable).
33 (0.01/day)
St Brelade, JE
System Name Desktop
Thanks for that. I managed to find it on the Amazon UK site plus I have an unwanted Amazon voucher given to me. I may get the play and charge kit but for the time being I have a ton of rechargeable AA and AAA batteries lying around but changing batteries mid-game might become a nuisance. :)
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
I have play and charge for 360 and I highly recommend it. If I'm playing a controller game for days straight, it usually lasts about 3 days unplugged and takes 4-6 hours to charge. I never stop playing--plug in when the it shows low battery, unplug when light is green.
