OnBoard
- Sep 16, 2006
- 3,033 (0.44/day)
- Finland
Processor | Core i5-750 @ 3.6GHz 1.136V 24/7 |
Motherboard | Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby! |
Cooling | Alpenföhn Brocken HeatpipeDirectTouch |
Memory | Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24 |
Video Card(s) | Gigabyte GTX 460 1GB OC (mostly stock speeds) |
Storage | OS: Samsung F3 500GB Games: Samsung F1 640GB |
Display(s) | new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD |
Case | new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans |
Audio Device(s) | new! ASUS Xonar DG & JVC HA-RX700 headphones |
Power Supply | Cougar CM 700W Modular |
Software | Windows 7 Home Premium x64 |
Benchmark Scores | Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging |
I'll start by saying I know I won't get 4GB, but reading numerous other thread about this here and else were I though I'd get somewhere near 3.2-3.5GB.
So Finding 2GB A-Data mems so cheap just had to try it out for my self. Bios shows 3008MB and Windows 2,93GB as you can see. Turning on /PAE switch didn't help to get any more.
Now things get interesting when I turned on memory remap in bios. I get full 4096MB there, but then Windows only finds 2.00GB!
CPU-Z, PC-Wizard, EVEREST and others so the full 4096MB installed all the time, but doesn't really help. 1GB ramdrive takes the memory off the amount Windows shows and not the 3-4GB range that is physicly available.
So have you gurus any other suggestions besides 64bit Windows? I'm getting a 8800GT in few weeks (hopefully) and installing that would mean 256MB (or something) less memory and I'd be under 3GB and that isn't really an improvement over the faster 2GB kit I have in specs.
I remember reading in some other thread that someone else also could get just 3GB, but no-one really seemed to believe him, it's true
There are many peeps here with 4GB, so you must have done something with the issue.
I know that with Abit IP35 that had 2xHDD, 2xburners, 256MB ATI card, even more USB and 4x1GB got ~3.4GB memory, so I don't understand where mine goes. Is P35 chipset just so much better allocating memory or does my IDE burners take away that much. That computer had everything is SATA.
Next step would be disabling some more stuff, but I already have printer ports, coms, extra usb & other stuff disabled. And then try a BIOS update, but not liking that option that much as this one is rock solid and new ones seem to be betas. Maybe that's enough writing for a thread start post
