24 Pin Power Cable Mod
3,471 (0.61/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
Goodie! Green light that is!
Now if only that 20-pin plug would be as easy to pluck out as the 24-pin was :(
Also, it's not going to be a high power rig but a VIA C7 board, total system running ~110watts max
5,214 (0.87/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
My sleeving came in today! Damn this guy is awesome! Hopefully I can get my Harbor Freight tonight to pickup some shrink tubing and start my adventure.
3,471 (0.61/day)
Good stuff kenkickr!
Also, here's a valuable beginner's tip for all you PSU sleevers:
When you pry the connectors out of your ATX plug, stick them on a piece of tape, in the correct order. This just might save you a headful of frustration and puzzling...
And after a couple of hours of prying (blast that ol' 20 pin!) this one is done! Unfortunately it's also pretty much bedtime, so no time for beauty work...
Thanks again MKmods for confirming the possibility!
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
Thrackan thats an excellent tip:respect:
3,471 (0.61/day)
I'll do you one last post of wisdom before I really hit the pillows :D:
- When you stick them on tape, don't go tossing around with it, you WILL mess it up... (I'm glad I didn't need that pinout anymore)
- If you don't have a hyper pro connector jiggle'n'pry tool, use a bent staple or a watchmakers screwdriver for instance. Any bigger tools make those female connectors HELL to pry loose.
Tomorrows schedule: work, testing the PSU, hopefully some aluminum sawing or maybe some cable tidying on this machine. My little case is getting there, step by step!
Now I'm left with 16 20cm cables and a male+female 20-pin connector. I just might use those someday.
OH! I know what I might do with those cables and connectors! I'm thinking of making a "modular" connection system for the molex connectors I need to use. Just putting it out in text so I remember :D
K
kyle2020
good luck! :D
My extra sleeving + heatshrink gets in today, so look forward to pictures / updates from me too :D
3,471 (0.61/day)
Finally got to testing, and my trusty old 10-euro PSU still works after all I made it go through :D
Though my modular system might not happen as the pins are different from the molex pins. I'm considering whether or not to take up soldering them.
5,214 (0.87/day)
Software Win 11 Pro
I should have ordered more cause I want to sleeve all the way from the ATX connection to the PSU and I don't think 25' is going to be enought, I know it's not going to be enough but in the mean time I'm going to do the PCI-E connections and the ESP connection.
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
Cooling Air
Case Custom
thats the original prob I had.. its hard to realize just how much you really need.
imperialreign
7,043 (1.15/day)
Sector ZZ₉ Plural Z Alpha
System Name УльтраФиолет
Processor Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved)
Motherboard ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB
Cooling Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler
Memory Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T
Video Card(s) Quadfire: (2) Sapphire HD5970
Storage (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA
Display(s) Samsung Syncmaster T240 24" (16:10)
Case Cooler Master Stacker 830
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro PCI-E x1
Power Supply Kingwin Mach1 1200W modular
Software Windows XP Home SP3; Vista Ultimate x64 SP2
Benchmark Scores 3m06: 20270 here: http://hwbot.org/user.do?userId=12313
agreed, same with heat shrink . . .
not to mention waste from the occasional goof-ups. If you have one avaialable, a heat-gun or very high-powered hair-dryer is much better for setting heatshrink than a lighter . . . at least when you're using nylon sleeving (although it takes a little longer for a heat-gun to work). It's very easy to melt the sleeving by accident.
3,628 (0.62/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
completally of topic but, imperialreign ur last quote made me chuckle :D
387 (0.06/day)
Los Angeles, CA
Processor Intel i7 4790K
Motherboard ASRock z97 Extreme
Cooling NZST Kraken
Memory 16gb
Video Card(s) 2x EVGA GTX 1080 FTW2
Storage Samsung 950 EVO
Display(s) 28'' Samsung
Case NZXT H700i
Power Supply EVGA 850G2
So I was wondering if anyone knows where I can get this single tool to remove the connector off the 4pin floppy/3pin fans. It looks like this
I had a whole set but lost just that one tool
If anyone has an extra one or knows where i can buy that single tool please let me know. I dont want to buy another whole set again.
3,471 (0.61/day)
Removing those is dead easy with a small screwdriver.
Just push down and then twist down, like the image I just made for you :D
387 (0.06/day)
Los Angeles, CA
Cooling NZST Kraken
Memory 16gb
Case NZXT H700i
yeah thats how I use to do it but im lazy and that tool made things so much faster. All 4/3 pins at once vs 1 pin at a time.....
900 (0.14/day)
Canada
System Name MurderBox #17
Processor Intel Core i7 5930k - 4.5Ghz 1.275v - Bitspower Summit EF
Motherboard Asus X99-E WS - Bitspower THOR AIX99 Full Full Board Block
Cooling SR-1 480, 8x Corsair ML120 , MCP350, I&H Res 250, PETG hard pipe, Mayhems Pastel White
Memory 32GB G.Skill Ripjaws 4 DDR4 2666
Video Card(s) Nvidia GTX 1080 Ti Founders Edition - EK Fullcover waterblock with Backplate
Storage 970 Pro 512GB, 960 EVO 500GB, PM961 512GB, 3x SM951 256GB,, WD Black 2TB, Seagate 4TB
Display(s) ASUS PG348Q 3440x1440, 2X ASUS PB278 2560x1440
Case MurderMod TJ07 With Illuminated mid-plate
Audio Device(s) Schiit Bifrost > Schiit Asgard > Hifiman HE400i - Audio Technica AT2020
Power Supply Corsair AX1200i With custom MDPC Sleeve and Noctua NF-A14 iPPC-3000 PWM
Mouse Steelseries Rival 600
Keyboard Corsair K95 RGB
Software Microsoft Windows 10 Professional 64bit
Here is my effort in 24pin sleeving madness.
Good work from all who have done it because I know just how tedious it is to do.
2,119 (0.37/day)
massachusetts
System Name VAN
Processor Intel Core 2 Quad Q9650 3.0GHz LGA 775 95W @ 3.0GHz
Motherboard ASUS P5Q Deluxe LGA 775 Intel P45 Intel Motherboard
Cooling Thermaltake SpinQ VT, front-rear-side 120mm, top-bottom 80mm
Memory Crucial Ballistix Tracer 8GB(4x2GB), DDR2, 800 MHz, 4-4-4-12, 2.0V, w/ Red LEDs
Video Card(s) AMD Radeon HD 6770 1GB
Storage Samsung 850 PRO 256SSD (OS) - WD 640GB 7200 RPM (files) - Seagate 1TB 7200 (backup)
Display(s) DUAL 19" Samsung, LG LCDs
Case NZXT Lexa Blackline
Audio Device(s) Realtek Onboard
Power Supply OCZ 600 Stealth-X-Stream 600W RT
Mouse Cyborg R.A.T. 9
Keyboard Razer Black Widow Ultimate
Software Windows 7 Ultimate
yeah I can imagine, it must take a lot of patience, when working with small things I get agrivated very quickly...what size sleeving did you use?
900 (0.14/day)
Canada
1/8" sleeving with 7mm 2:1 heatshrink. I was a bit nervous on the first boot up because it is 24 chances to get one of them wrong and blow up your board. If you take your time and be methodical it is not very difficult, just time consuming.
2,119 (0.37/day)
massachusetts
System Name VAN
yeah that would make sense
3,471 (0.61/day)
Actually, each wire could go into 23 wrong sockets, so that would be 23x24= 552 wrong patterns... Or maybe that's totally wrong, but ehrm yeah...:wtf:
Point is, you have to be methodical about it :D
900 (0.14/day)
Canada
Haha either way it would be kablammo for your board if one is hooked up wrong.
Deleted member 24505
Since i did my 24 pin atx, i have gone sleeving mad.I have now sleeved my pci-e power lead and my dvd power lead,plus any other cables i could sleeve too.
3,471 (0.61/day)
I still need to find some wire wrap as I'm kind of fed up with removing the pins on the 24 plug again.
I also lack good sleeving material though, I'm probable going with a "cover it up so you won't see it" method :p
2,119 (0.37/day)
massachusetts
System Name VAN
why would you not want to see it?
3,471 (0.61/day)
2,119 (0.37/day)
massachusetts
System Name VAN
ohhh I thought you meant you had already did what this thread is about and you wanted to hide it ok...now I completely understand mine looks strikingly similar lol
