trickson
OH, I have such a headache
- Dec 5, 2004
- 7,595 (1.07/day)
- Planet Earth.
System Name | Ryzen TUF. |
Processor | AMD Ryzen7 3700X |
Motherboard | Asus TUF X570 Gaming Plus |
Cooling | Noctua |
Memory | Gskill RipJaws 3466MHz |
Video Card(s) | Asus TUF 1650 Super Clocked. |
Storage | CB 1T M.2 Drive. |
Display(s) | 73" Soney 4K. |
Case | Antech LanAir Pro. |
Audio Device(s) | Denon AVR-S750H |
Power Supply | Corsair TX750 |
Mouse | Optical |
Keyboard | K120 Logitech |
Software | Windows 10 64 bit Home OEM |
here's the link for the nozzle's/washer http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=203&HS=1 if you can't find it on petras site don't be afraid to call alex or quoc and ask, i'm shure they'll have/get it for you
are you shure? IIRC from what i saw from all of the testing at Xs the nozzled and bowed fuzion would net 3c-5c better temp's on a q6600 vs a stock fuzion. the nozzle/washer kit is no more than $7 so well worth it IMO....
I think I will wait on getting it , see how the temps are and then post them here . If some one that has the insert post's lower temps than what I get with the stock block then I may just get one .
