Help and recommend a new Power supply
Discussion in 'General Hardware' started by fullinfusion, Mar 13, 2014.
  1. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    Well last night I was having a benching session and I have a wattage meter form the wall socket to the power supply.
    I'm using a Corsair HX850 and the highest I seen it go was around 850 with two 7970's clocked hard.
    Well I'm now using two R9 290's in crossfire and I was seing wattage draw of 1050 and at I believe the highest I did see the meter read was 1058 watts.
    This to much for this HX 850?
    Also What brand on modle would you all recommend?
    Is a digital psu a good choice over the standard type of PSU? recommend
    This is what I'm looking at but are there similar ones from different manufactures of this digital design?
    http://www.memoryexpress.com/Products/MX40937
    And will that size fit in my Corsair 650D?
    manofthem says thanks.
  2. FX-GMC
    FX-GMC
    Aug 26, 2013
    935 (1.39/day)
    382
    Cumberland Plateau
    Way too much for an 850w PSU. Any particular reason it has to be that specific digital design?
  3. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    Nope just Digital sounds better so thats why Im asking.
    Need to know so I can order one today before the wife spends all the cash lol
  4. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,000 (7.76/day)
    25,397
    You're pretty much good to go for years to come by getting an AX1200i or the original AX1200* :toast:
    * Corsair even sells pretty nice cable sets, available in a variety of colors, for both models! ;)
    manofthem and fullinfusion say thanks.
    Crunching for Team TPU
  5. FX-GMC
    FX-GMC
    Aug 26, 2013
    935 (1.39/day)
    382
    Cumberland Plateau
  6. Norton
    Dec 21, 2011
    10,000 (7.76/day)
    25,397
    I had mine in a Corsair 350D Fractal Arc Mini for a little while and it fit in that one! (will add a pic later if I can find it)
    **EDIT-
    [​IMG]
    xvi, manofthem and fullinfusion say thanks.
  7. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    Pulling over 1KW tonight boys, Is it true a HX850 is really a re-branded 1000W corsair unit?
    @Norton I cant have a psu that has the fan blowing into the case. Gawd I have have enough heat from my second 290 heating shit up with the case closed. I forgot to enable ULPS last night and holly hell batman the air coming out the top of the rad this morning was killer. I need a big psu with bottom air draw, not one that vents into the case!
    One with fancy led display and led lights showing wattage and such would be sweet!
  8. rubenclavs
    Nov 7, 2013
    177 (0.29/day)
    32
    Seasonic PSU would be better I guess?
    fullinfusion says thanks.
  9. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    Who makes Corsair psu's? seasonic?
  10. ne6togadno
    ne6togadno
    Mar 15, 2013
    1,612 (1.92/day)
    794
    GMT +2
  11. Norton
    Dec 21, 2011
    10,000 (7.76/day)
    25,397
    iirc the psu fan is an intake fan and the heat is exhausted out of the back. I generally mount mine fan side up so I don't have to deal with clogging up a dust filter under the case- psu mounting (fan up/fan down) is a user based decision ;)
    Fun fact- according to Hardware Secrets, the Corsair HX1000 is actually 2x 500w psu's spliced together :twitch:
    fullinfusion and manofthem say thanks.
  12. DF is BUSY
    DF is BUSY
    Oct 13, 2013
    268 (0.43/day)
    50
    agreed with the mentioned 1200i from corsair.
    or the evga 1300 supernova g2
    or the rosewill lightning 1300w (cheapest option out the 3)
    all have great reviews from jonnyguru
  13. R3ign
    R3ign
    Oct 30, 2005
    76 (0.02/day)
    23
    I would recommend a Corsair PSU - even though i've had some issues with my original purchase (their RMA service is fast) have had no problems since
  14. manofthem
    manofthem WCG-TPU Team All-Star!
    Jan 9, 2011
    7,648 (4.68/day)
    13,293
    I agree with @Norton due to the fact that he knows this stuff, and it lines up with on my own experience.
    The HX1000 is an amazing psu! I bought mine used, and then used it for years, never having any issues.
    Just recently upgraded to an AX1200, the very one in Norton's pic I believe, and it too is fantastic, more efficient than the HX1000.
    :toast:
  15. Aquinus
    Aquinus Resident Wat-man
    Jan 28, 2012
    7,628 (6.10/day)
    3,009
    Concord, NH
    I personally really like my Seasonic 1000W Platinum. It's a little expensive but it's worth every penny. It's one +12v rail of awesome.
    @crmaris 's review on it seems to be pretty favorable as well, sans the price. Granted it was cheaper when I bought it.
  16. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    how about a 1000watt unit? if my benching is pulling 1050+ watts at high benching load using an 850 watt unit and still chugging along... but I think its the cause of my oc limit on both cards. really anything over 1kw the prices just get way to high so whats your. guys thoughts on a good 1kw unit?
  17. FX-GMC
    FX-GMC
    Aug 26, 2013
    935 (1.39/day)
    382
    Cumberland Plateau
    If you don't cheap out on it you could probably get away with it. The 850w PSU is evidently spec'd higher than the label says. Most seasonic units are more capable than what they put on the label (which is how a power supply should be.)
  18. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    I like the evga 1300 w for just over 200$ so illcheck what ncix and others have for price
  19. Norton
    Dec 21, 2011
    10,000 (7.76/day)
    25,397
    The other thing to remember is that the psu is rated on the DC side so the AC reading will be higher anyway.
    How much heat are you exhausting from the psu at full load?
  20. fullinfusion
    Jan 11, 2008
    8,635 (3.17/day)
    2,408
    didnt check the exhaust. will check later this week.
  21. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    10,821 (6.13/day)
    2,822
    Seattle, WA
    No, the 1000w version is 2 450w PSUs taped taped together. The hx850 is quite a bit different and better. get the ax1200i
  22. xhawn11
    Jun 3, 2013
    31 (0.04/day)
    4
    Get Evga g2 1300 and save some $.
  23. FX-GMC
    FX-GMC
    Aug 26, 2013
    935 (1.39/day)
    382
    Cumberland Plateau
    I agree. From the johhnguru review of that psu.
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=349
  24. manofthem
    Jan 9, 2011
    7,648 (4.68/day)
    13,293
    You obviously need this
    [​IMG]
    /thread
    :p
  25. HammerON
    HammerON The Watchful Moderator Staff Member
    Mar 2, 2009
    6,751 (2.92/day)
    3,871
    I have had my AX1200 for a couple years now and would definitely recommend it (or the AX1200i).
    fullinfusion, Norton and manofthem say thanks.
Share This Page
