Project WaterFall -- A water cooling project log by Phenom
Discussion in 'Project Logs' started by MxPhenom 216, Oct 16, 2012.
  1. [H]@RD5TUFF
    Nov 13, 2009
    5,616 (2.46/day)
    1,707
    San Diego, CA
    Great choice on the fans, they perform so well, they are a little noise but a worthy trade off IMO. :toast:
  2. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    Im running 2 in push pull on my megahalem for my CPU at like 10v. They are pretty damn quiet. I also have 4 of the AF series as case fans. Again, very quiet even at full tilt 12v
  3. Irony
    Irony
    Sep 25, 2011
    1,751 (1.09/day)
    463
    Outer Rim system of the interwebz
    I have 4 AF120s that aren't bad either; if I was gonna get em again I would go with the SPs though. But they just look good too, with the rings to accent the edges
  4. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    The SPs and AF are meant for 2 different cooling solutions. AF is for air flow(perfect for case fans), and SP is static pressure to push air through radiators and heatsinks.
  5. Irony
    Irony
    Sep 25, 2011
    1,751 (1.09/day)
    463
    Thats true but they're also quieter.
  6. james888
    james888
    Jun 27, 2011
    5,458 (3.23/day)
    2,828
    They still have good air pressure for less fpi radiators too. Just not sp air pressure.
    MxPhenom 216 says thanks.
  7. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    Depends on if your talking QUiet versions or not. My SPs are noticably louder then the AFs
    I am kind of wishing I got 1/2" tubing though. I'll move up to bigger tubing when I add the CPU too the loop
  8. TheMailMan78
    TheMailMan78 Big Member
    Jun 3, 2007
    21,735 (6.85/day)
    8,286
    Project Blue Virginity.
  9. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I just need to get the mods to get the title to actually change.
    Today im going to probably do some of the stuff I can do without putting it all in the system. Like putting the pump in the res and stuff like that. Still waiting on dremel parts to do some case hacking and such.
  10. james888
    james888
    Jun 27, 2011
    5,458 (3.23/day)
    2,828
    You got your loop all planned already and this isn't for your case, but the same layout. Still thought I would share.
    http://imgur.com/a/fUWD7
  11. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    someone modded their 500r so much that they put a 360 rad in the front. That looks sweet. I think what im going to do though when I add my CPU to the loop. is get a thick 120mm rad like the XSPC RX120, and go
    [​IMG]
    I think what im going to do though when I add my CPU to the loop. is get a thick 120mm rad like the XSPC RX120, and do this.
    [​IMG]
  12. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,788
    Totally untrue.
  13. james888
    james888
    Jun 27, 2011
    5,458 (3.23/day)
    2,828
    Instead of those hdd cages you should find one of these and put it in a push pull configuration with those corsair sp's.
  14. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    Im looking at the BitFenix individual sleeved extendsions, but jesus they are really long!!!
  15. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    15,044 (4.19/day)
    8,553
    Beaumont, Alberta
    Sleeve your own wires. will be far cheaper, and better electrical power.
  16. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I dont trust myself doing the 24pin. And how would it be better electrical power?
  17. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,703 (2.53/day)
    1,791
    Chicago
    Hmm I have never heard that but I guess less crosstalk/noise as they arent all bunched together?
    Anyway looking good so far dude! Yeah go for Real Man's 1/2" tubing :p. Heh it just looks better generally I think and also better flow though the temp diff would be nominal at best. Is harder to work with though in tight spaces. You also need new fittings then too. Got a kill coil or something for anti-microbial?
    I think you may be the first guy I've seen who is starting with GPU cooling.
  18. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    next year when i upgrade procs, Ill add CPU to the loop. with a VERY fat 120mm rad.
  19. erocker
    Jul 19, 2006
    41,061 (11.76/day)
    16,182
    I don't see any HDD's. I suppose if you're running an all SSD setup, you could velcro them to the back of the mobo tray.
  20. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,227 (8.19/day)
    6,678
    Chatsworth, GA
    Watercoolering is kind of a mute thing these days with the advances in air cooling and smaller lower votage dies but non the less I believe it looks great!
    Crunching for Team TPU
  21. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    yeah thats the only thing haha! I have 4 drives haha! 1 DVD drive, and a fan controller.
  22. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,788
    If I had that case and went that route, I'd just move a single cage to in front of my PSU. It would be super easy.
  23. Wrigleyvillain
    Oct 13, 2007
    7,703 (2.53/day)
    1,791
    Chicago
    Well my first rad that came with a used complete loop was this fat ass XSPC 220 and, frankly, it didn't seem to make a very noticeable difference over my regular little Swiftech MCR-220 I bought later. But maybe you have some other data. Definitely harder to work with that behemoth as well, though.
    And like I said, get a kill coil then you can just use distilled and not worry about algae growth, which is possible unless you change your water every couple months (gets to be a pain). Can toss in res or even inside a tube (can bend the coil in or out to fit snug).
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=28871
  24. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    Today is the day. Ill have a ton of pictures coming later. I hope I have everything.
  25. manofthem
    manofthem WCG-TPU Team All-Star!
    Jan 9, 2011
    8,710 (4.69/day)
    17,647
    I was so surprised when I received my first kill coil and saw how small it was. I don't know why, but I was expecting it to be bigger (thats what she said) :laugh:
    I hope it goes well; nothing is worse than missing something and not being to finish. Looking forward to the pics :toast:
