10 bit problem
Fatic
21 (0.01/day)
Hey guys i have Asus PB287Q monitor,its supported 1.07 billion color.I will update lastest nvidia driver (436.02).But doesn't active 10 bit bpc.How can active 10bpc option?
Deleted member 67555
Go into Device Manager and Right click on display then Properties then update drivers.
If that that doesn't work maybe somebody else will have a better idea
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
You might have to scroll down and select the resolution under the "PC" section before 10 bpc shows up.
130 (0.03/day)
Your monitor has DP 1.2. I doubt its supports 4k 60hz + 10-bit, 4:4:4 subsampling. I think only DP 1.3+ can do that. So there will have to be compromises, ie, 4k @ 30hz to be able to do 10-bit. Best to stick to 4k 60hz, 4:4:4 and 8-bit.
18,456 (2.47/day)
That's a TN panel though, I thought they can't do "real" 10-bit?
It should be 8-bit+FRC, no?
I can't get 10-bit output on my IPS panel either, which Asus also claims is 10-bit...
And no, changing to 30Hz doesn't enable the option.
4 (0.00/day)
The PB287Q is TN panel with 10bit (8bit + FRC), which is not true 10bit color support. I have the PA329Q, the professional line which is an IPS 4k + 60hz + true 10bit RGB/4:4:4 over DP 1.2, and have no problems with these settings.
Fatic
21 (0.01/day)
Thanks for answers,but my panel not true 10 bit supported.Asus tricked me :(
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
What's you GPU?
PS.
You bought a 4K TN panel and want to see 10-bit colour from it. You tricked yourself.
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
This has nothing to do with the panel type you probably can't get 10-bit color on RGB, not enough bandwidth. Use YCbCr 422 and 60hz.
Fatic
21 (0.01/day)
What's you GPU?
PS.
I have rtx 2070 are check it offical site.
6,431 (2.85/day)
Poland
Well this display uses DP 1.2 which can't output 10-bit at 4K 60. HDMI 1.4 which this monitor also uses does not support 10-bit at 4K, only 8-bit at 30 (?) Hz. Return the monitor if you can.
4 (0.00/day)
A proper 4k panel can output those settings on dp 1.2, as in the pa329q.
