7-zip benchmark compilation
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Figured with someone benchmarks floating around this one would be interesting since quite a few people actually use 7-zip. I am also stealing newteckie's format for the thread so many thanks for him actually making a good layout.
What you are going to need:
7-Zip 9.30 beta: LINK
Rules:
  • Put Add Me+version run as the title of your post.
  • Include a screenshot of CPU-z (CPU and Memory tabs) and the 7-zip window with your results (all in the same screen shot).
  • Only 7-zip version 9.30 beta will be counted.
Instructions
  1. Start 7-zip
  2. Select tools-> benchmark
  3. Select Dictionary size: 192mb (>8GB RAM) or 64mb (<8GB RAM)
  4. Allow it to run at least 4 passes and hit stop
You will be left with that screen
Post your results in the following format:
Name | Processor Maker | CPU Model and Clock | Total Rating (CPU USAGE) | Total Rating (Rating/Usage) | Total Rating (Rating) | 64-bit or 32-bit | Notes
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Results 192MB:
cdawall | AMD | Phenom II X4 B97@4160mhz | 360% | 3961 MIPS | 14262 MIPS | 64-bit | Dirty test run
Ashen | AMD | FX 8150@4640mhz | 702% | 3309 MIPS | 23256 MIPS | 64-bit |
DOM | Intel | i7 3770K @ 4.5GHz | 756% | 3419 MIPS | 25814 MIPS | 64-bit |
Morgoth | Intel | Xeon E5520 x2 @ 2395mhz | 1359% | 1886 MIPS | 25639 MIPS | 64-bit | 14 threads | 192mb
Jizzler | AMD | FX 8120 @ 3093Mhz | 722% | 2416 MIPS | 17422 MIPS | 64-bit | Stock
Earthdog | Intel | 3570K @4500mhz | 372% | 4980 MIPS | 18454 MIPS | 64-bit |
agent00skid | AMD | A6-3500@2400MHz | 286% | 2496 MIPS | 07151 MIPS | 64-bit | 6 threads
Aquinus | Intel | Core i7 3820 @ 4920Mhz | 757% | 3783 MIPS | 28608 MIPS | 64-bit | 192MB Dict, 8 Threads
AlienIsGOD | Intel | Core i5 2400 @ 3.2ghz | 367% | 3520 MIPS | 12871 MIPS | 64-bit
cadaveca| Intel | i5 3570K 4600 MHz | 377% | 5497 MIPS | 20617 MIPS | 64-bit |
Totocellux | Intel | Core i7-950 @ 4255Mhz | 751% | 3245 MIPS | 24376 MIPS | 64-bit | 192MB
HammerON | Intel | i7 970@4.0GHz | 590% | 3748 MIPS | 22132 MIPS | 64-bit | 6 cores, 192 MB test
oralpain | Intel | 3930k @ 4.3GHz | 1127% | 3657 MIPS | 41238 MIPS | 64-bit | 24-thread, 8x4GB Samsung, stable
IamEzio| intel | Core i5 3470 3.2GHz | 379% | 4008 MIPS | 15100 MIPS | 64-bit | 192MB
xiekxis | Intel | i7 3930k @ 4.6 GHz | 1148% | 3367 MIPS | 38645 MIPS | 64 bit | 12 threads, 192MB
rickss69 | Intel | 980X @ 4015MHz | 768% | 3408 MIPS | 26133 MIPS | 64-bit | game rig
Results 64MB:
cdawall | AMD | Phenom II X4 B97@4160mhz | 351% | 3972 MIPS | 13953 MIPS | 64-bit | Dirty test run
Melvis | AMD | Phenom II 1055T@Stock | 562% | 2765 MIPS | 15570 MIPS | 64-bit |
Arctucas | Intel | Core i7 950@4273mhz | 727% | 3261 MIPS | 23693 MIPS | 64-bit |
erocker | Intel | Core i7 3770K@4.6GHz | 753% | 3682 MIPS | 27680 MIPS | 64 bit |
Morgoth | Intel | Xeon E5520 x2 @ 2395mhz | 1464% | 1780 MIPS | 26081 MIPS | 64-bit | 16 threads
Melvis | AMD | FX-57@stock | 100% | 2482 MIPS | 02478 MIPS | 32-bit | old school
cdawall | AMD | Athlon X2 L310@1500mhz | 186% | 1390 MIPS | 02600 MIPS | 64-bit | netbook
Fatal | Intel | i7 950 @4025MHz| 753%| 3121 MIPS| 23487 MIPS | 64-bit |
Earthdog | Intel | 3570K @4500mhz | 374% | 4811 MIPS | 17965 MIPS | 64-bit |
Qu4k3r | Intel | C2Q Q6600@3.2GHz | 372% | 2952 MIPS | 11001 MIPS | 64 bit |
Fatal | AMD | Phenom II 940 @3.402 | 375% | 3208 MIPS | 12033 MIPS | 64-bit |
xaira | Intel | Celeron G540 2.5ghz | 184% | 2595 MIPS | 04772 MIPS | 64-bit | 4DALOLZ
Earthdog | Intel | 3770K @ 4500mhz | 752% | 3591 MIPS | 26858 MIPS | 64-bit |
agent00skid | AMD | A6-3500@2400MHz | 290% | 2458 MIPS | 07139 MIPS | 64-bit | 6 threads
Aquinus | Intel | Core i7 3820 @ 4920Mhz | 750% | 3730 MIPS | 27933 MIPS | 64-bit | 64MB Dict, 8 Threads
helloWorld | Intel | i7 2600K @ 4.8 GHz | 768% | 3323 MIPS | 25542 MIPS | 64-bit
Ev1LrYu | Intel | Intel Core i7 2670QM @ Stock | 755% | 2050 MIPS | 15437 MIPS | 64 bit | Notebook
agent00skid | AMD | Phenom II X3 N830@2100MHz | 295% | 2024 MIPS | 05977 MIPS | 64-bit | 6 threads
cadaveca| Intel | i5 3570K 4600 MHz | 379% | 5353 MIPS | 20171 MIPS | 64-bit |
natr0n | AMD | Phenom II X6 @3.5 | 566% | 3391 MIPS | 19211 MIPS | 64-bit |
wrathchild_67 | Intel | i5 2500k@5GHz | 390% | 5220 MIPS | 20367 MIPS | 64-bit | 8 threads, 64MB
DOM | Intel | i7 3770K @ 4.8GHz | 743% | 3827 MIPS | 28286 MIPS | 64-bit |64MB
Melvis | AMD | Phenom II 965@Stock | 371% | 3247 MIPS | 12057 MIPS | 64-bit | 64MB
Melvis | AMD | A4-5300@Stock | 360% | 2521 MIPS | 04956 MIPS | 64-bit | 4 Threads
Melvis | AMD | Athlon II X2 260@Stock | 197% | 2986 MIPS | 05868 MIPS | 64-bit | 4 Threads
Totocellux | Intel | Core i7-950 @ 4301Mhz | 754% | 3182 MIPS | 24001 MIPS | 64-bit | 64MB - 8 threads
HammerON | Intel | i7 970@4.0GHz | 1103% | 2878 MIPS | 31788 MIPS | 64-bit | 12 threads, 64 MB test
Melvis | AMD | FX 8350 @ Stock | 749% | 3168 MIPS | 23719 MIPS | 64-bit | 64mb test
rickss69 | Intel | 980X @ 4015MHz | 1116% | 2835 MIPS | 31704 MIPS | 64-bit | game rig
If you click the upper column you can change the sort.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
This is what a proper post should look like.
(posting this one for Ashen)
DOM
7,628 (1.10/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
DOM | Intel | i7 3770K @ 4.5GHz | 756% | 3419 MIPS | 25814 MIPS | 64-bit | Notes
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
How interesting I was honestly expecting the FX chip to hold the cpu usage (multithreading amount) over the intel chip with HT. Other weirdism is the Phenom is holding the best per core (rating/usage)
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
my system freezes at 2min...
5,482 (0.88/day)
Australia
Motherboard MSi AM4 Pro Carbon | GA-AB350H-D3 | Gigabyte EX58-UD5
Memory 2x16GB DDR4 G.Skill 3600MHz| 4x8GB Corsair 3000 | 6x2GB DDR3 1300 Corsair
Video Card(s) MSI AMD 6750XT | Solo RTX 4060| MSI RX 580 8GB
Storage 1TB WD Black NVME / 250GB SSD /2TB WD Black | 250GB SSD WD/2TB SSD, 2x1TB, 1x750 | WD 500 SSD
Display(s) Gigabyte 27" 1440P 180Hz / 22" DELL| MSI 27" 1080P 100Hz / 17" DELL | 22" DELL / 19"DELL
Case LIAN LI PC-18 | Mini ATX Case (custom) | Fractal
Keyboard Corsair K90| Ducky One | Some POS Logitech
Software Windows 10 Pro 64 | Windows 10 Pro 64 | Windows 7 Pro 64
You might have to decrease the amount "192" as anyone with 4GB of memory or less wont be able to run it as i just found out.?
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
No idea why yours does try less threads?
I will make a second set at 128mb for people with under 8gb
2,635 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01 w/Alphacool Apex RAM X4 Water Cooler and Core DDR5-RAM Module
Video Card(s) MSI Suprim SOC w/Alphacool Core Geforce RTX 5080 Suprim + Vanguard with Backplate
Storage Samsung 990 PRO 1TB M.2
Display(s) MSI 321URX
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Hmm... I can only run two threads (out of eight) or I get a 'cannot allocate enough memory' error.
I see you and Ashen running 16GB, whereas I only have 6GB.
EDIT:
The best I can get:
Arctucas|Intel|i7 950@4273MHz|727%|3261 MIPS|23693 MIPS|64 bit|
5,482 (0.88/day)
Australia
Even 128 is to much, i just tested it and the max anyone can go with 4GB of memory or less is 64mb :ohwell:
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
64mb run
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I can run 192mb fine without 16gb's of RAM. Where do we set it to run 4 times? So is it 64mb then?
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
I will have two lists one for 64mb and one for 192mb just label which you ran
The section were it says passes is what I am talking about takes about 3-4 of them to get a good stable number. I updated the OP to make that a little more clear.
5,482 (0.88/day)
Australia
Melvis | AMD | Phenom II 1055T@Stock | 562% | 2765 MIPS | 15570 MIPS | 64-bit | 64mb test
43,629 (6.36/day)
add me 64MB
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Morgoth | Intel | Xeon E5520 x2 @ 2395mhz | 785% | 2324MIPS | 18260MIPS | 64-bit | 8 threads | 192mb
Morgoth | Intel | Xeon E5520 x2 @ 2395mhz | 1464% | 1780MIPS | 26081MIPS | 64-bit | 16 threads | 64mb
ill turn of my ramdrives to get 192mb on 16 threads
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
i did
5,482 (0.88/day)
Australia
Melvis | AMD | FX-57@stock | 100% | 2482 MIPS | 2478 MIPS | 32-bit | 64mb old school
Just for fun!! :D
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
64mb run
to far?
4,267 (0.66/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Add Me 192MB
734 (0.12/day)
Golden, Colorado
System Name KAREN / EVA / GHOST
Processor Intel Core i7-950 / AMD Phenom II X4 940 BE / Core i5 3570k
Motherboard ASUS TUF Sabertooth X58 / DFI LP DK 790FXB-M2RSH / Asrock z77e-itx
Cooling Thermaltake Frio / Corsair Cooling™ Hydro Series H50 / Corsair Hydro Series H60
Memory Corsair Dominator 6GB DDR3 1600 / Corsair Dominator Quad2X4096-8500C5DF / G.SKILL Ripjaws Serie 1600
Video Card(s) XFX HD6950 CF unlocked /XFX HD5770 CF/ MSI R4890 Cyclone
Storage OCZ Vertex 2 60 WD Raptor X WD1500AHFD / Seagate Barracuda /Western Digital 80gb, Toshiba 1TB
Display(s) 2 Acer P215H 21.5 Widescreen / Acer S211HL 21.5 / HP 2009F 20inch
Case SILVERSTONE RAVEN RV02-BW / NZXT Phantom /Bitfenix Prodigy
Audio Device(s) On board / Philips MMS 321 - PC multimedia speakers
Power Supply Ultra X3 ULT40311 1000W / Cosair CMPSU-750TX 750W/ CORSAIR Gaming Series GS700 700W
Software Windows 7 64 bit / Windows 7 64 bit / Windows 7 64 bit
Fatal | Intel | i7 950 @4025MHz| 753%| 3121 MIPS| 23487 MIPS | 64 bit |
19,379 (3.46/day)
AddMe+ 64 and 192MB
Earthdog | Intel | 3570K @4500mhz | 374% | 4811 MIPS | 17965 MIPS | 64-bit | XXX
Earthdog | Intel | 3570K @4500mhz | 372% | 4980 MIPS | 18454 MIPS | 64-bit | XXX
(not sure why its so small... I just attached to the forum. Click to enlarge)
347 (0.06/day)
Valencia, Venezuela
System Name Tropicaliente | Digger | A515-43-R19L
Processor FX-6300 | Q6600 | R3 3200U
Motherboard ASRock 970 Extreme 4 | Gigabyte X48T-DQ6 | Grumpy_PK
Cooling EVGA CLC120 | OCZ Vendetta | Stock
Memory 16GB DDR3-1600 | 8GB DDR3-1333 | 16GB DDR4-2666
Video Card(s) PowerColor RX-570 4GB Red Dragon | HIS HD5670 1GB IceQ | Vega 3
Storage 256GB SSD (OS) + 512GB SSD (Games) + 500GB + 2TB + 4TB | 80GB + 320GB | 128GB NVME + 512GB SSD
Display(s) Asus VN247H-P | KVM USB Switch | 15.6" FHD
Case Antec ONE | Generic Black
Audio Device(s) on board + Logitech Z623 | on board | on board
Power Supply Cooler Master GX-650 | Antec VP-450 | Powerbrick ac/dc
Mouse MS Wired Desktop 600
Keyboard MS Wired Desktop 600
Software Win 10 x64 Pro | XCP-ng 8.1: XOA, pfSense, RouterOS, FreeNAS, Zabbix | Win 10 x64 Home
add me 64mb
