8GB of DDR2 1066Mhz or 4GB of DDR3 1333Mhz
Duekay
258 (0.04/day)
Brisbane AU
System Name Workstation : Server/HTPC
Processor Core i7 920 @ 4.2GHz : Core i3 2120
Motherboard Gigabyte GA-EX58-UD5 : Gigabyte GA-Z68MA-D2H-B3
Cooling Cooler Master V8 : Stock
Memory Corsair DDR3 12GB @ 1600Mhz : Corsair DDR3 8GB @ 1600Mhz
Video Card(s) GTX 560 Ti & GT 430 : Onboard
Storage OCZ Max I/O 2x128 SSD Raid0 + Corsair 3x120GB SSD Raid0 : Corsair 2x60GB SSD Raid0
Display(s) Dual samsung 24" & 1 Acer 22" : Acer 22 & Samsung 46" TV
Case Antec P182 Performance One : Antec 4U rackmount
Audio Device(s) Mackie Onyx 400F 10x10 : Maudio Fast Track Pro
Power Supply Corsair HX-620 : Corsair HX-650
Software Windows 7 64bit, Cubase 5 : Windows 7 64bit
I am wanting to find out if ill see more performance from 4GB of DDR3 1333Mhz or 8GB of DDR2 1066Mhz.
The DDR3 with 4 GB cost $70 more than the 8GB of DDR2
Im running Windows XP 64-bit if any one was wondering :D
Thanks
Dave
517 (0.07/day)
Stamford, UK
System Name The Money Sink
Processor Intel i7-5960X at 4.60Ghz
Motherboard MSI X99A Godlike
Cooling Custom watercooling loop, single D5 -> CPU, dual D5 -> GPU's
Memory 64GB DDR4-3000
Video Card(s) 2 x 1080Ti @ Stock for the moment (40oC LOAD)
Storage 960GB Mushkin Scorpion Deluxe and 2 x 512GB M.2 SSD RAID0
Display(s) Dual Curved LG 34" Display
Power Supply EVGA 1600W G2
Benchmark Scores ALOT
Without doubt I would buy the DDR2! Price/performance DDR2 wins hands down... DDR3 isn't good enough yet to warrant the price difference.
10,242 (1.43/day)
Granite Bay, CA
System Name Big Devil
Processor Intel Core i5-2500K
Motherboard ECS P67H2-A2
Cooling XSPC Rasa | Black Ice GT Stealth 240 | XSPC X2O 750 | 2x ACF12PWM | PrimoChill White 7/16"
Memory 2x4GB Corsair Vengeance LP Arctic White 1600MHz CL9
Video Card(s) EVGA GTX 780 ACX SC
Storage Intel 520 Series 180GB + WD 1TB Blue
Display(s) HP ZR30W 30" 2650x1600 IPS
Case Corsair 600T SE
Audio Device(s) Xonar Essence STX | Sennheisser PC350 "Hero" Modded | Corsair SP2500
Power Supply ABS SL 1050W (Enermax Revolution Rebadge)
Software Windows 8.1 x64 Pro w/ Media Center
Benchmark Scores Ducky Year of the Snake w/ Cherry MX Browns & Year of the Tiger PBT Keycaps | Razer Deathadder Black
Size of memory translates to the ability to run more programs at once. Frequency of memory translates to speed.
Don't forget to look at the timings. You have a link or part numbers to the RAM you had in mind?
888 (0.14/day)
System Name Meshify C Ryzen 2019
Processor AMD Ryzen 3900X
Motherboard X470 AORUS ULTRA GAMING
Cooling AMD Wraith Prism LED Cooler
Memory 32GB DDR4 ( F4-3200C16D-32GTZKW, 16-16-16-36 @ 3200Mhz )
Video Card(s) AMD Radeon RX6800 ( 2400Mhz/2150Mhz )
Storage Samsung Evo 960
Display(s) Pixio PX275h
Case Fractal Design Meshify C – Dark TG
Audio Device(s) Sennheiser GSP 300 ( Headset )
Power Supply Seasonic FOCUS Plus Series 650W
Keyboard Logitech G 15
You have XP, the performance difference isn't going to be much.
But once you upgrade to Vista X64, the 8GB will come in handy. Everything boots so much faster thanks to superfetch.
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
like danishdevil said, the ram timings are important. i bet that ddr3 is around 8-9 CL and the ddr is prolly around 5.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
my advice would be simple: ram speed is most important when OCing.
1066 means 533 FSB, 1333 means 666 when using 1:1 divider (the lowest many modern motherboards will go)
The most important thing being... you have a DDR2 motherboard. you cant use DDR3 anyway.
10,242 (1.43/day)
Granite Bay, CA
Keep in mind, that performance is equal at higher MHz with a looser timings as compared to a lower MHz with a tighter timings. Intel systems like bandwidth, and AMD systems seem to like tighter timings.
So, DDR3 at CL9 sounds bad, right? What if it's running at 2GHz? :nutkick:
HTC
4,694 (0.75/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
Enough said.
Unless, ofc, you have plans for a DDR3 motherboard, in which case, there's still some discussion to be had ...
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
10,242 (1.43/day)
Granite Bay, CA
Or you get the right kit of $150 DDR3 and OC the balls out of it :D
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
haha GSKILL FTW :rockout !
Duekay
258 (0.04/day)
Brisbane AU
I got XP 64bit, so thats way im going for the 8gig :rockout:
Duekay
258 (0.04/day)
Brisbane AU
My mobo will run it as long as they are right on the asus web site,
they said:
The chipset officially supports the memory frequency up to DDR3 1066MHz/DDR2 800. Due to the tuning by ASUS exclusive technology, this motherboard natively supports up to DDR3 1333/DDR2 1066MHz.
Mussels
58,412 (7.78/day)
Oystralia
the chipset doesnt mean the motherboard.
You list a P5K-VM
http://asus.com/search.aspx?searchitem=1&searchkey=P5K-VM
This link says
asus said:
- Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® G33 chipset
- Dual-channel DDR2 1066/800/667 MHz
- 2x1394
- 12xUSB 2.0
- All High-quality Conductive Polymer Capacitors
no DDR3 support mentioned. only DDR2 Later down the page it also mentions 'native DDR2 support' but again no mention of DDR3
Either we arent talking about the motherboard in your system specs, or you looked up the wrong one.
Duekay
258 (0.04/day)
Brisbane AU
You list a P5K-VM
This link says
Lol now i see were you coming from, yea that is strange there must be different boards for different country's,- http://au.asus.com/products.aspx?l1=3&l2=11&l3=542&l4=0&model=1690&modelmenu=2
93 (0.01/day)
Processor AMD 1700X
Cooling Corsair H110iGT
Memory 16GB Corsair VENGEANCE LPX 3200 CL16
Video Card(s) VEGA 64 w/ Corsair H100
Storage 480GB Patriot Hellfire -- WB Blue SN550 1TB -- WD Red 2TB Raid 0 -- WD Black 4TB
Display(s) Dual Benq 24"
Case Corsair C70 VENGEANCE
In the first 4 lines of the motherboard overview specs it says DDR2. I have seen that chipset used on DDR3 motherboards, but that board is NOT DDR3 compliant.
P5K-VM
ASUS Super Memspeed Technology Enhances Memory Speed
- 2x1394
- 12xUSB 2.0
- Compatible with all FSB1333/1066/800/533MHz CPUs except Quad Core
"The chipset officially supports the memory frequency up to DDR3 1066MHz/DDR2 800. Due to the tuning by ASUS exclusive technology, this motherboard natively supports up to DDR3 1333/DDR2 1066MHz. Please refer to www.asus.com or user manual for Memory QVL" -ASUS
Mussels
58,412 (7.78/day)
Oystralia
i tend to not use the asus au site, as it lags horribly for me... odd, especially since i'm australian too.
ok after it eventually loaded, i see what confused you. The CHIPSET can use DDR2 or DDR3 - however, this motherboard can only use DDR2. Notice how at the top, it only mentions DDR2?
The asterisk and mentioning DDR3 is a mistake on the webstite - another reason to check the alternate ones, and not just say with the .au version.
For your future reference, DDR2 and DDR3 slots are physically different - if it did have them, it would clearly label two slots for DDR2 and two for DDR3... and you wouldnt be able to run 4x DDR2 sticks anyway, if it was a combo board.
Duekay
258 (0.04/day)
Brisbane AU
Thanks man, I really didn't know what was going on there.
good thing i didn't buy the DDR3 today lol, well this makes things a lot easer with the choice :D
What brand would you go for, Corsair, G.Skill, Geil, Kingston, OCZ or Team, i have been eying up the OCZ Platinum PC8500
10,242 (1.43/day)
Granite Bay, CA
OCZ's RMA process is really great, and they make good RAM, but some isn't that great for overclocking.
Corsair can be good, but expensive. G.Skill has some really nice budget overclockers, and I love my new DDR3 from them. Geil, meh. Kingston, overpriced. Team is really overclocker's ram, but you pay the price for it.
If you're getting 4x2GB, get some G.Skills to save some money. I figure you're not doing extreme OCing anyway, because anything but 2x1GB with DDR2 will impede your max OC.
Two of these would do:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
Mussels
58,412 (7.78/day)
Oystralia
to be honest, look for stock clocks as opposed to gaining an OC. i have cheap 1100MHz samsung generic ram that cost me $50 a stick, yet i see people paying more for OCZ ram that wont even do 900MHz at the same timings i can do 1000.
Go for warranty and stock clocks, as opposed to timings or brand name.
888 (0.14/day)
I really doubt that Xp will use up more then 4GB ram. Vista knows how to handle RAM very well, but XP uses a lot more virtual memory ( someone correct me if I am rong ).
Duekay
258 (0.04/day)
Brisbane AU
Well that sucks, i just got XP 64bit for the reason of taking advantage of getting extra Ram :banghead:
2,758 (0.43/day)
XP 64-bit will handle it fine. But one question. What do you do that needs or you wanting 8gb?
888 (0.14/day)
When I say "handle it" I mean utilize it. Vista will use all of it, XP will only use RAM when needed. That's one of the few good things about Vista.
Duekay
258 (0.04/day)
Brisbane AU
I write music with this pup, i use heaps of samples and audio clips and she just cant really get anywhere with only 2 gig
All the new synth/samplers use the Ram just as much as the CPU, They take a Wav sample and use modulators and effect to modify the signal.
The more Ram i have the more of these high end demanding synths i can run at once, along with a nice fast CPU for processing powerful and complex algorithms.
