Acronis true image cloning problem
echo75
456 (0.07/day)
Denmark
System Name Main
Processor Q6700 @ 3.5Ghz (with 1.50 Vcore)
Motherboard P5K
Cooling Xigmatek HDT S1283 (amazing performance)
Memory Corsair 800mhz 4GB @ 864mhz
Video Card(s) Asus 8800GT@ 720/1800/2100,blue Pcb with 92cm Glaciator cooler(4870 still under testing)
Storage Seagate 250GB SATA , 500GB eSATA
Display(s) LG Flatron 19"
Case Antec Designer (modded)
Power Supply Corsair VX 550W
Software Win XP Pro SP2
Benchmark Scores 3Dmark06 = 15,253 for 8800GT, 3Dmark06 = 15,807 for HD 4870
just discovered that i actually has Acronis true image 8 OEM version that came along with an external hard disk i bought 2 years ago.
i install the software, make a boot disk , connect SATA disk to my PC and attempt to clone my current IDE to SATA as it claims to be able to do so.
Problem is that when i boot from the Acronis boot CD, and the software wizzard starts, it says " Acronis true image can not find any Disks" . This is funny cos the software itself running when run in windows interface can recorgnise the 2 disks but when i boot outside windows it doesnt see anyting.
Now i have just ordered the full version of Acronis 11 for $34 and am downloading it now it better work or i will really be pissed.:wtf:
1,700 (0.27/day)
Im using TI 11 and I have had alot of questions because I run raid. So, what i have dug up is Acronis uses its own driver base to detect your hardware. Now the driver base is built around the linux kernal that is included with the software. I use a P965 chipset and (luckily) it detected my hardware. But I think your chipset is too new, it wont work. Especially with 8. But here. This si the official Acronis forum http://www.wilderssecurity.com/forumdisplay.php?f=65
echo75
456 (0.07/day)
Denmark
System Name Main
Motherboard P5K
yeah, i found the forums and have actually posted a thread there.
7,238 (1.06/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Good luck. Report back. If you want to do lots of cloning, or have a compressed backup of an install image, then True Image is the way to go.
But if all you want to do is upgrade one HDD, there is a better and quicker solution. Use Acronis Disk Director. (EXCELLENT). Copy the IDE partitions to the new SATA drive. Then use director again to change the partition size to fill the new disk. Dead easy.
Some years ago I tried TI and gave up. Too fussy. I use Director for everything. HDD upgrades, cloning, swapping, backups.
echo75
456 (0.07/day)
Denmark
System Name Main
Motherboard P5K
After getting the Acronis 11 it worked like a charm, it has the ability to clone in windows interface (with a couple of auto reboots ofc) and i have sucessfuly cloned my IDE to a larger SATA. it seems to have lots of other data protecting safety nets too. i will play with it for a while.
10,487 (1.37/day)
Cybrnook is correct, it's a simple driver issue. If there is no driver there is no controller, no controller means no disk. However considering it's some LiveCD it's probably not that easy to fix.
I would expect the latest version to support any common current controller. If not paying = support from their side ;)
echo75
456 (0.07/day)
Denmark
System Name Main
Motherboard P5K
yeah Banjoman, i became 34 bucks just poorer to solve the problem.
10,487 (1.37/day)
At least you know they actually update their software, does the $34 bucks include future updates/versions or what?
And on a sidenote, isn't $34 for keeping your data safe a good investment? Specially with the dollar being worthless in the first place :)
echo75
456 (0.07/day)
Denmark
System Name Main
Motherboard P5K
i quite agree, its a small price to pay for my data safety, just was a bit sour that they didnt upgrade my version 8- 11 for free since i had one legal version in the first place.
Anyway with the US dollar at an all time low, the Danish crown has never been stronger so i dont actually mind :p That chimp of a president Bush obviously has taken some bad decisions though to the detriment of his people but to my financial benefit in this case due to the dollar rate .
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
InnocentCriminal
Resident Grammar Amender
6,477 (0.88/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
We use Acronis at work (I work for a IT company that build bespoke set ups for students with disabilities and the a-like) and it's freaking excellent! I recently lost my whole Games partition and with a custom made BART PE CD with the Acronis Tools included I was able to use Disk Expert to recover my drive, worked instantly as if my failure had never happened.
I think that $34 was well spent.
smig
156 (0.03/day)
Israel
System Name Smig
Processor AMD Athlon 64 X2 5600+
Motherboard MSI K9n6SGM-V
Cooling Arctic Cooling Alpine 64 + 2 80 case fans
Memory 2gb DDR2-800 5-5-5-15@400MHz
Video Card(s) Inoision 9600GSO 384mb
Storage 2x Seagate SATA2 250gb - RAID-1
Display(s) no name 19" LCD
Audio Device(s) On-board 7.1
Power Supply Topower 500w
Software XP Pro SP2
you did pay for an upgrade, since the normal price of Acronis True Image 11 is 50 US$ (49.99 :p)
I think you better took Acronis Disk Director Suite for the same price, though you might had to pay the full 50 US$.
I used Partitionmagic in thepast and moved to Acronis. I find Acronis much much better, and worth every nickel.
7,662 (1.17/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
Did aronis get rid of the damn bootloader that if u uninstalled it you'd have to reload ur pc?
echo75
456 (0.07/day)
Denmark
System Name Main
Motherboard P5K
i had no problems un installing the version 8 as they asked before i should install the version 11.
1,700 (0.27/day)
Yeah, its all good. I have had it enabled and disabled in xp and vista. no problems , Im on TI11
