tombraider
- Jun 3, 2006
- 5 (0.00/day)
this is my vid : http://www.amazon.com/dp/B0009IBB9W/?tag=tec06d-20
but it's 2nd card and I have some problem
1. When I use AtiTool 0.24, the GPU temp = 90 degrees C (play FEAR)
When I use AtiTool 0.25 beta14, the GPU temp = 65 degrees C
What is right, what is wrong?
2. After play 30min the card turn off! (may be overheat, I'm not sure), but power input led and HDD led still on ??? After I reboot, my card show not correct ! ....(see the picture, not this but something like this ) sometimes it's suspended...
what is the problem? my old card 9800pro is still good ! It works correctly !
My PC: Intel 865PERL, Intel 2.8E HT, PSU CoolerMaster RealPower 450W non fullrange, HDD SATA Seagates 80G,....windowsXP sp2...
help me, thanks !
help me, thanks !
