Aiming for a new AMD PC setup for about $/€1800, plus-minus, but I kindly need some help and advice to get the right parts...
642 (0.12/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
With Black Friday upcoming and my current PC is not doing its job that well any longer, as it is being overly slow and troublesome when it comes to loading etc. + I cannot play any of the new games that I wanna play because of the specs being bad and whatnot + it's about time to get myself a new PC. This time, I am going for an AMD-setup, and it would be great if it would last for a few years, like 5+ years or so. But, I do not need ALL the parts, as I do have some parts available, such as: monitors (I have 4 available), case (FD R6), power supply (I have a G3 650W now), Noctua-fans in various sizes, mouse and a keyboard. I do need the following parts, however:
- CPU
- CPU cooler
- Graphics card
- Memory
- Motherboard
- SSD
- Power supply
I will use my PC primarily for these things, so it should perform these tasks without any issues:
- Livestreaming and streams (running various streaming programs and other apps in the background)
- Multitasking (I stream while I do other things/projects such as web designing)
- Photo + Video rendering + editing (my current PC takes a long time to perform these tasks, to be honest)
- Light gaming (NO FPS. Mostly sports, RPG, adventure and action games. I am NOT picky when it comes to running all games at max performance/quality etc.)
With Black Friday coming up, I am going to scout for some options, but this time, my budget is about $/€1800, plus-minus.
Any thoughts on a setup that would deal with my tasks nicely?
PS: Look at my listed PC specs for my current setup, if that matters...
578 (0.40/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
i suggest to think twice about the gpu, with today's market situation you would only afford maybe a 3060 at best (which is worse than 1080ti). I suggest getting a 5600G for now, (or a used 2400G, since main objective would be getting a somewhat decent igpu without having to pay much as any igpu is ofc really slow). Stock cpu cooling (u dont need anything fancy until u hit 9 series), good psu, fast ram, a decent B550 mobo (such as Msi B550-A Pro), etc. Build it without dedicated gpu for $1000, test it out, etc. And then just buy a 3080ti for what it will worth in a couple of months. Remember,its not only about the shortage and high gpu prices, but its also about sloppily made cards and some quality control issues https://www.notebookcheck.net/More-...rce-RTX-30-series-cards-emerges.561536.0.html. So even if u pay $800 for a 3060ti (which is ofc a ripoff), you may even get a card with issues.
Deleted member 24505
Surely a 5800x will be better than 5600 for this-
And it's very cheap at the moment too.
578 (0.40/day)
yes but it doesn't have igpu (which forces u to get one, with todays situation when there are scammers everywhere and the prices are ridiculously high). also what if u check out a used 2400g and compare it according to its price/performance ratio? But that is irrelevant if you can get spare parts from ur older pc (?) IF your pc is the one that is mentioned in your system specs, then sure, get a 5800X into there. But as u have a 980ti (1070 level), i would recommend to stick with it for now, except if u desperately need an upgrade.
yes but it doesnt have igpu (which forces u to get one, with todays stituation when there are scammers everywhere and the prices are ridiculously high). also what if u check out a used 2400g and compare it according to its price/performane ratio? But that is irrelevant if you can get spare parts from ur older pc (?)
he wants it for productivity first, so CPU is more important, games secondary, so he can buy a cheapish shand GPU to tide him over. Same as i did by buying the 980ti. For what he is going to use the machine for, he will need a better CPU than a 5600
2,644 (2.25/day)
Germany
System Name Sunk Cost Fallacy
Cooling Arctic Liquid Freezer II 360 Rev. 7
Video Card(s) Sapphire Nitro+ RX 7900 XTX Vapor-X
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Lian Li O11 Air Mini
VR HMD Oculus Rift S
as much as i like AMD there is basically no reason to buy anything else than the 5950x for workstations.
a 5800X costs more (50-100€ depending on sales or not) is on par or slower in games than a 12600k, has a lot less multicore performance than a 12600k, and it's on a dead platform with no upgrade path (raptor lake with up to 24 cores should be compatible with Z690)
and since you want streaming and editing (especially streaming) a 12600k is faster than a 5950X in gaming while (for example) recording.
davinci resolve 4k exports are almost on 5900X level even at stock clocks.
Adobe Premier ingest/proxy is even a lot faster than a 5950x
i'd rather look for a 12600k DDR4 Build (the Z690 Pro A from MSI is fantastic and good enough for everything you can throw in the socket)
and what you save from a b550 board you can spend for the z690 board with a more "future proof" PCIe 5.0 slot and even on the cheapest board available 4 M.2 Slots + proper Intel Lan.
and the 12600k overclocks pretty decent (500Mhz on the P Cores, 600 Mhz on the E Cores and 400-500 Mhz on the Ring is doable without any crazy voltages or cooling requirements)
I only suggested 5800z as he said he wanted AMD. I have to agree though on the 12600k though.
Fourstaff
10,024 (1.90/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
What resolution are you running your monitor on? For 1080, RTX3060 is enough for the next few years at least, but once you step up to 1440, its starting to struggle. Reusing your graphics card will be the best bet for now.
Don't skimp on the ram either, get 32 or even 64gb if budget allows, since RAM prices are somewhat reasonable right now.
1,747 (1.48/day)
Alaska USA
- CPU
- CPU cooler
- Graphics card
- Memory
- Motherboard
- SSD
- Power supply
What country are you located (Europe is not a country) and what resolution will you be gaming at?
1,302 (1.33/day)
Thailand
System Name Shoebox
Processor 3600x
Motherboard Msi b550m Mortar +WiFi
Cooling Cryorig m9
Memory Crucial Ballistix c16 B-die 2x8gb
Video Card(s) Powercolor rx570 4gb
Storage WD black sn750 256gb (OS), crucial mx500 1tb(storage),Hitatchi ?? 7200rpm 500gb(Temp files)
Display(s) Samsung 65" TU7100
Case Zzaw b3
Audio Device(s) Yamaha rx-v363
Power Supply Corsair sf750
Mouse Logitech g300s
Keyboard Custom Skyloong sk64s
Software Windows 11Pro
Sorry but unless you know you can source good parts at reasonable prices there no sane reason to build in the current market your far better off looking for a decent reasonably priced prebuilt better yet a custom builder who can source msrp prices with a small cut for their own labor.
1,747 (1.48/day)
Alaska USA
No idea what country you are located nor your resolution hence the reason I didn't include a psu and gpu but this gives you a rough idea of what you're looking at cost wise if you decide to go with an Intel LGA 1700 Alder Lake build.
https://www.computeruniverse.net/en/p/90848813
GIGABYTE Z690 GAMING X DDR4 €175,63
https://www.computeruniverse.net/en/p/90849235
Intel Core i5 12600KF €258,25
https://www.computeruniverse.net/en/p/90785407
Arctic Liquid Freezer II 360 €73,87
https://www.computeruniverse.net/en/p/90782615
G.Skill Aegis DDR4 3200mhz 32GB (2x16GB) CL16 €96,12
https://www.computeruniverse.net/en/p/90742995
Intel 660P M.2 PCIe 3.0 x4 1TB SSD €81,36
Total: €685,23 excl. VAT plus shipping costs
Reviews of that cpu including benchmarks.
642 (0.12/day)
Oh wow. An Intel-setup is that much better?! And seemingly a lot cheaper too? Is an AMD-setup really not that worthy anymore, huh?
Yes, the 5950X will be overkill for my budget, unfortunately.
I am located in Norway.
My resolution (because of my eyes) will mostly be 1080p. Things get too "detailed" and "small" for me and my eyes at 1440p. Weird, i know, but it's just how it is. Yes, i am aware that eventually, i should consider upgrading to a 1440p-setup too. It should be noted that the monitors that have, are 1440p-monitors...
And yes, i intend getting at least 32gb RAM.
Say if i go for the Intel-setup, how "future proof" will the Intel-setup be?
Thank you all so much for the responses and help!
8,944 (3.36/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
As a platform, it wont be. Not unless you buy into DDR5, even then who knows, Intel is known for switching sockets and chipsets very often.
If possible I'd wait for AMD to make the switch to DDR5.
1,747 (1.48/day)
Alaska USA
And when do you think AMD will make the switch to DDR5?
This intel socket should be good for at least this and the next intel cpu. He can get a cheapish intel board for AL now and switch boards when DDR 5 is actually available. Unless you switch setups every year AL should be good for a few years at least, better than waiting for AM5
2,679 (2.22/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
I'd rather pick a 12600K for 265€. Having an working system without a discrete GPU can come in handy. There's also QuickSync as a part of iGPU, maybe it can be put to good use too.
I've checked several other retailers and the price difference between 12600KF/tray and 12600K/tray is very small, or none at all.
dgianstefani
TPU Proofreader
4,248 (1.84/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus AMD Raw Copper/Plexi, HWLABS Copper 240/40+240/30, D5, 4x Noctua A12x25, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MHz 26-36-36-48, 56.6ns AIDA, 2050 FLCK, 160 ns TRFC
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel with pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply Corsair SF750 Platinum, transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS
Mouse Razer Viper Pro V2 Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White & Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19053.3803
Benchmark Scores Legendary
12700k, any z690 DDR4 mobo, Noctua NH-U12A, 32gb of 3800/4000mhz c16 or lower ram, a decent 1/2TB ssd from reviews. I would also splurge on a better PSU, like a Seasonic Prime.
Save the spare money for next year when Eth goes POS, then buy your GPU, otherwise you will be spending 2x MSRP. Integrated GPU on 12700k is good enough for 1080p medium gaming anyway.
Otherwise buy a placeholder GPU like a 1050ti.
Reading your post again, you don't need a strong GPU, but a strong CPU would benefit you, further reason to either keep your 970 or use IGPU on the 12700k.
642 (0.12/day)
Thanks for the input.
Yes, that seasonic prime seems like a very good one to get. Overall good reviews and seems to do the trick/job as well, at least for my purposes.
So, you're saying that i should KEEP the GPU i am using now, and instead upgrade it at a later point, maybe next year or so?
So.... it all points to the fact that i should opt for an Intel-setup then, huh? That's a massive surprise, but i am definitely up for it if that is the way to go, yes.
1,572 (1.15/day)
An [EVGA] G3's fine, it's a Superflower. If you insist, you can of course buy the Prime but tbh it is quite unnecessary as long as your PSU isn't failing.
Do note that there's still some compability issues w/ E-cores tho, they may or may not get smoothed out in the upcoming weeks and/or months.
1,747 (1.48/day)
Alaska USA
The board in that build I posted up above.
642 (0.12/day)
Interesting. The Intel-setup you posted landed on about €1000 (with VAT + shipping), but without GPU + PSU. What about a CPU-cooler, or that is what the Arctic Freeze II is for, i assume? I have never used liquid cooling, so i am not sure how that works.
What about GPU and PSU..? Will the one i already have (see my setup on my profile) work good, or i need a stronger W one?
So, this seems to be the setup to go for, huh?
1,747 (1.48/day)
Alaska USA
You can reuse your current gpu for now until you find a deal. Here's an option to have a look at.
1080P
https://www.computeruniverse.net/en/p/90803642
EVGA 650 GT Gaming 650W 80+ Gold Modular Power Supply €63,02
MSI GeForce RTX 3060 GAMING X LHR 12GB €714,28
dgianstefani
TPU Proofreader
4,248 (1.84/day)
Swansea, Wales
System Name Silent
You can reuse your current gpu for now until you find a deal. Here's a few options to have a look at.
1080P
1440P
https://www.computeruniverse.net/en/p/90824520
EVGA SuperNova 750 GA 750W 80+ Gold Modular Power Supply €72,77
https://www.computeruniverse.net/en/p/90835060
ASUS DUAL GeForce RTX 3070 OC V2 DUAL-RTX3070-O8G-V2 8GB €923,53
Read the OP, he does light gaming in 1080p.
642 (0.12/day)
1080P
Ok, so i will definitely go for the INTEL-setup, not AMD then. What a surprise that was, but i love it!
Few questions:
1: If i can get the i7 12700KF to about the same price as 12600KF, i should go for the 12700KF, yes? Otherwise, i will go for the 12600KF.
2: What PSU options are worth for me to get? 650~1000W recommendations would be good. Are EVGA SuperNova still good enough ones to get, yes?
3: The Arctic Cooler, i only need that, and nothing else in terms of external things? Pardon for that newbie question.
4: Will the Z690 X DDR4 fit into my case, which is Fractal Design Define R6, or?
