ASRock X470 Fatal1ty Gaming ITX/ac Motherboard Pictured
47,655 (7.44/day)
Here are some of the first pictures of ASRock X470 Fatal1ty Gaming ITX/ac, one of the first few upcoming AMD X470 chipset motherboards built in the mini-ITX form-factor. The board draws power from a 24-pin ATX, and an 8-pin EPS connector, and uses an 8-phase VRM to power the SoC. The AM4 socket is wired to two DDR4 DIMM slots, supporting up to 32 GB of dual-channel memory; a reinforced PCI-Express 3.0 x16 slot, and a 32 Gbps M.2-2280 slot (reverse side), besides two of the board's four SATA 6 Gbps ports, four of its USB 3.0 ports, and the onboard audio. The AMD X470 chipset puts out the remaining two SATA 6 Gbps ports and two USB 3.1 gen 2 ports, including a type-C port. High-grade 8-channel HD audio, gigabit Ethernet, and 802.11 ac WLAN with Bluetooth 4.1, make for the rest of it.
Durvelle27
6,823 (1.46/day)
Memphis, TN
System Name Black Prometheus
Processor Ryzen 7 3700X
Cooling Thermalright PA120 SE
Display(s) ACER AOPEN 34" 3440x1440 144Hz
Power Supply EVGA 600W
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
A lot will be happy of this as so many asked for ITX options on the AMD side
4,267 (0.66/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Sold.
Some may like that ASRock went with black instead of red like the X370 Fatal1ty. A little easier to work a non-red color scheme.
iO
531 (0.11/day)
Germany
Processor R7 5700x
Motherboard MSI B450i Gaming
Cooling Accelero Mono CPU Edition
Memory 16 GB VLP
Video Card(s) RX 7900 GRE Dual
Storage P34A80 512GB
Display(s) LG 27UM67 UHD
Case none
Power Supply Fractal Ion 650 SFX
Looks so much better in black and grey but I wish they revised the crappy 3 phase VRMs
4,365 (0.97/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
These have a 6+2 phase VRM. Where are you getting 3 phase from?
iO
531 (0.11/day)
Germany
Processor R7 5700x
Memory 16 GB VLP
Case none
Its 3 doubled phases for increased current capabilities. Plus those 2 for SoC voltage of course.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Nichicon Audio.
That's beyond dumb.
4,365 (0.97/day)
Processor 5800x3d
Mouse *squeak*
Software Manjaro
iO
531 (0.11/day)
Germany
Processor R7 5700x
Memory 16 GB VLP
Case none
Interesting. Dont intel boards do the same thing? Might just be a limitation of ITX.
Its mostly ASRock cheaping out on their mITX and mATX AM4 line up as Intel boards get much better VRMs. But the AM4 socket and retention plastic thing does take up more space than S1151 making PCB design harder.
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
Is there something wrong with nichicon?
It reminds me like GTA adds like pisswater etc...
The decision of a PR or whatever team to put this sort info is really worthless, it nears the snake oil religious preaching territory. It is low, it is tasteless. Put the ALC1220 sign and everything would be solid and clear. They advertise a part contributing less 0.01% of overall performance.
44,267 (6.80/day)
Better than what msi puts out
1,402 (0.31/day)
Processor AMD Ryzen 3700x
Cooling Deepcool LS520 SE
Video Card(s) RTX 3070 FE
Display(s) LG GL850
Case Dan A4 H2O
Power Supply Corsair SF600
Mouse MX master 3
Keyboard Master Key Mx
Software win 11 pro
Nichicon is a brand with a good recognition in the audiophile community, meanwhile realtek got very little appeal compared to ESStech or Asahi Kasei. Realtek is just a cheap, do it all chip, the nichicon logo is there to show that the audio is slightly better implemented compared to all the other realtek motherboard (wich is pretty much 100% of the market).
Those caps does have an impact on the sound signature, I had two motherboard with the same realtek chip, but the one with nichicon cap had a smoother, warmer sound.
2,758 (0.66/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
354 (0.11/day)
Indonesia
System Name Nero Mini
Processor AMD Ryzen 7 5800X 4.7GHz-4.9GHz
Motherboard Gigabyte X570i Aorus Pro Wifi
Cooling Noctua NH-D15S+3x Noctua IPPC 3K
Memory Team Dark 3800MHz CL16 2x16GB 55ns
Video Card(s) Palit RTX 2060 Super JS Shunt Mod 2130MHz/1925MHz + 2x Noctua 120mm IPPC 3K
Storage Adata XPG Gammix S50 1TB
Display(s) LG 27UD68W
Case Lian-Li TU-150
I think it also has to do with AMD's chip using less power than Intel's chips too.
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
You need a doctor or an education. Audiophile is like a spineless disease. The overall schematic implementation matters, not the cap. Any bypassed generic non china low end cap will do the same in coupling tasks(like any other boards reside, Dave still measures them slightly, look up). Any professional audio gear engineer will tell you the same. Snake oil is everywhere over these kind of things. No measurements are usually done and some sort of medieval dragon sighting stories are made based upon nothing. Actually hearing difference means usually something wrong in 99% cases. Oscillation and specific ringing at certain frequency with changed harmonic plot that actually may be pleasing to certain individuals, but actually it is the error and distortion you like.
Otherwise why the shun of Realtek? Who else has comparable interfaces working on HDA bus??? It is enough. The darn board does not have enough space nor power resources to properly utilize more serious sound solutions, yet the audience having the gear to utilize it is even smaller and none of them will use it as a analog signal source either way.
It is just funny how studio grade recording pro gear kind a lives a happy life without these magic caps with gold, virgin blood, fine spider silk... A puzzle indeed. *sarcasm*
They might have put a proper TPA6120, then yes Asrock guys, you did a good job, like others do for certain boards, gamers and any other current thirsty headphone users will praise you.
In the end it means... Like putting an ad on a car - it has round wheels and it is a feature.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
No idea why people would freak out about it anyway. I use a USB DAC for my hungry headphones (and I mean hungry hungry Fischer products)
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
I don't know. Like some sort of fashion trendy thing. Gucci, Armani... show off etc... same with audio gear.
Well I can add an image of a mature design. Lynx E44 card. They adress the pcie latency flaws by using very fast Spartan CPU.
The design is tight, proven and boring. Yet works like an atomic clock. No bells and whistles, just plain precision. Audiophiles are a funny bunch, reminds me of the flat earth rocket cuckoo guy.
44,267 (6.80/day)
Anything is better than Nikos crap..... Which MSI and Biostar both love to use.
No wonder Biostar can't gain any ground
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
5,480 (0.88/day)
Australia
Yes! this is exactly what I have been waiting for! SOLD!
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
Me I don't really care
It seems you don't care to read. Realtek simply isn't enough. ALC1220 is the thing that needs to advertised as the straight responsible key element to compare in between boards. And the chip is really good for a mainstream thing, it works better than certain dedicated multichannel dacs implemented on a dedicated board with independent split power.
If you suppose that ESS Sabre is something good without trade offs you don't understand what really it is as a 1 bit dac and how it works. There's load of them and you put generalize it. Just as caps, there simply are no simple audio caps even for Nichicon. There are KA, FG, FW, KZ etc... each with their own drawback especially the lifespan.
We have an itx board, from asrock, the heck the audiophile thing? It is beyond stupid as such, what's even the discussion about snake oil, that no one will use either way as the product is specifically targeted.
Musicality has nothing to do with caps or sound coloration, it is even in clash with the term hi fidelity lol. If it's recorded as shit(especially so called modern home studios) it will sound more like bigger shit on better gear(in general better gear causes greater abyss). For playing on crap gear it will sound the same(shit), that's the only general difference about audio fidelity and why you want a better gear. The main task of a generic audio part is to be transparent. Leaving all the placebo snake oil to the minority of believers and let them buy their dedicated devices. Case closed.
23,829 (6.15/day)
Well spoken sir, I always refer to the audiophile craziness with 'you enjoy your 100 dollar audio cables created by elves in moonlight'. Do they exist, oh yes they do...
When in doubt, how about this 'current conditioning unit'
https://www.lessloss.com/firewall-module-p-216.html
"Use the Firewall module with any equipment so that its potential performance can be realized in today's over-polluted electro-magnetic atmosphere " :laugh:
Its hilarious. Browse a bit and be amazed
667 (0.20/day)
127.0.0.1, London, UK
System Name Warranty Void Mk.IV
Processor AMD Ryzen 5 5600
Motherboard Asus X470-I Strix
Cooling Phanteks PH-TC12LS + 2x Be Quiet! Pure Wings 2 140mm / Silverstone 120mm Slim
Memory Crucial Ballistix Elite 3600MHz 2x8GB CL16 - Tightened Sub-timings
Video Card(s) EVGA RTX 2080 XC Ultra
Storage WD SN550 / MX300 / MX500
Display(s) AOC CU34G2 / LG 29UM69G-B - Auxilary
Case CM NR200P
Audio Device(s) Realtek ALC 1220+SupremeFX
Power Supply Silverstone SX650-G 650W
Mouse Logitech G302/G303 SE/G502/G203 / MMO: Corsair Nightsword
Keyboard CM Masterkeys Pro M / Asus Sagaris GK100
VR HMD Oculus Rift S
Software Windows 10 Pro x64 - LTSB
Finally an ITX board that I was waiting for since Ryzen launch. Now if it would have a B-chipset sibling that would be even more awesome. More options are always great.
Almost every motherboard with AMD chipsets were nothing like what Intel boards are for Covfefe Lake. They seemed much better in every way. Thankfully this discrepancy seems to have gone away.
What was worse that only premium boards shipped with ALC1220 codec, most of them used the ancient ALC889. I wanted to do audio connector re-tasking, guess what. Even with unlocked drivers I couldn't do squat.
