ATi tool driver problems/Not installed
DaMulta
My stars went supernova
16,168 (2.33/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
I think the ATi tool driver isn't installing when I install ATi tool.
I cannot get past the Overdrive mark in ATi tool. When I pass it locks and I have tried 27beta1,2, and 26. I have also tried drivers 7.6,7.7, and 7.8/ I think this is the problem tho and I don't know how to fix it.
Well that was somthing else.....sorry to waste everyones time. Still can't go past the 700 mark for some odd reason.
Do you have it set for driver level overclocking?
Maybe try not using Driver Level?
I did...I'm giving up for now.
i have the same problem,kind of.im on vista 32bit but,if i turn on driver lvl overclocking,it doesnt set the clocks up,just keeps resetting it to stock.if i turn it off driver lvl,i get black screen and rebbot.
i did get it working on xp but it wouldnt go over 700 on the ram,or black screen rebbot.
not going to be of much help but I had a similar problem, atitool was working fine and able to clock to a certain amount but then I used rivatuner and atitraytool to clock and ended up needing to reboot and this *attached* came up after reboot and was there for 3 reboots and then disappeared and it's stopped working ever since even after reinstall of atitool or the drivers.
