Best program for viewing temps?
exow2
100 (0.02/day)
Processor AMD Athlon II X4 630 2.8ghz
Motherboard Asus M3A78-EM
Memory 4GB Kingston DDR2 800mhz
Video Card(s) Nvidia Geforce 8800GT
Storage 640Gb 7200RPM 32MB Cache Western Digital
Power Supply 400W NZXT
Software Windows 7 Ultimate
I'm just wondering what you guys think the best free program is that I should use to watch my temperatures?:)
EDIT: I'm AMD so intel based software is out.
I'm a little biased but if you have an Intel CPU, I'd go with RealTemp.
The rectal thermometer will probably hurt. :laugh:
HWMonitor in my opinion is best. Since I found it, I haven't used anything else.
@W1zz----Freakin hillarious. :roll:
No im AMD sorry XD probably should include that in the title.
Yeh, I use the same software, very nice, no major overheads or problems whilst running games (ie stuttering) and does what it's meant too, well. It's also 32 and 64bit compliant.
Yea but is there a program I can use that will display my cpu temperatures in the taskbar etc,
hwmonitor...nuff said
Alright thanks guys HWmoniter it is
I use CoreTemp and it's pretty good for a free app.
I use coretemp, easy to use, has logging, all those neat features. Is actually extremely accurate as well.
Image is mine below.
K cool thanks I downloaded that as well, I can use both HWmoniter for temp on my gpu and stuff and use coretemp to always see my temperature in the taskbar
Yeah that's one feature that I love about CoreTemp along with the fact that it's free. I love how it allows you to see your temp in the taskbar.
I use Everest Ultimate + the Multi Sensor gadget for Vista/Seven by SFkilla. Everest gives you the most accurate readings (only RealTemp comes near to it) and MultiSensor gives you the ability to display them always on your sidebar. Result:
Everest 5.50 with vista sidebar
