Better Cooling Options 10850k
6,871 (1.09/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
Looking for a better cooling solution for my 10850k. I want to be able to run it at 100% full load @ 4.9GHz and at least stay under 90' c, preferably under 80'c. I am currently using a 240mm AIO unit (see system specs), and my CPU runs mid-high 90'ties at full load. Full load is achieved by running the WCG BOINC client. Is there a air cooler (preferred) or AIO unit that can handle a 10850k clocked at 4.9GHz all cores/threads at 100% full load and meet my desired temperature levels? Or is custom water cooling required for my desired results?
824 (0.26/day)
Riverwood, Skyrim
System Name Storm Wrought | Blackwood (HTPC)
Processor AMD Ryzen 9 5900x @stock | i7 2600k
Motherboard Gigabyte X570 Aorus Pro WIFI m-ITX | Some POS gigabyte board
Cooling Deepcool AK620, BQ shadow wings 3 High Spd, stock 180mm |BQ Shadow rock LP + 4x120mm Noctua redux
Memory G.Skill Ripjaws V 2x32GB 4000MHz | 2x4GB 2000MHz @1866
Video Card(s) Powercolor RX 6800XT Red Dragon | PNY a2000 6GB
Storage SX8200 Pro 1TB, 1TB KC3000, 850EVO 500GB, 2+8TB Seagate, LG Blu-ray | 120GB Sandisk SSD, 4TB WD red
Display(s) Samsung UJ590UDE 32" UHD monitor | LG CS 55" OLED
Case Silverstone TJ08B-E | Custom built wooden case (Aus native timbers)
Audio Device(s) Onboard, Sennheiser HD 599 cans / Logitech z163's | Edifier S2000 MKIII via toslink
Power Supply Corsair HX 750 | Corsair SF 450
Mouse Microsoft Pro Intellimouse| Some logitech one
Keyboard GMMK w/ Zelio V2 62g (78g for spacebar) tactile switches & Glorious black keycaps| Some logitech one
VR HMD HTC Vive
Software Win 10 Edu | Ubuntu 22.04
Benchmark Scores Look in the various benchmark threads
I guess your options would probably something like the nh-15d with some more powerful fans (so quite a bit noiser) or really a 360mm AIO (Which is the better option if you don't want to go custom water cooling)
6,871 (1.09/day)
S.E. Virginia
price is the only reason I don't want to go custom water cooling
Deleted member 202104
You might be better served dropping back to stock (4.8 all core) and tweaking voltage down. I can run 100% around 80c on a U12s with a second fan in a fairly poor airflow case.
12,453 (1.87/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
Not all AIO's are created equal. If you check out Gamer's Nexus reviews of AIO's, the Arctic Cooling Freezer II and EK AIO were much better than your run of the mill Asetek AIO's. For reference I replaced my Noctua NH-U12S w/ 2 fans with a EK AIO 240, and my temps dropped 6c on my 5600x. The EK AIO 240 can be bought direct from EK for under $100. About 70-75% of the benefits of custom water at a 1/3 the cost. Couple that with a better thermal paste and see if you have any room to drop your vcore at all.
3,106 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Intel Heatspreaders are concave.
Asetek Coldplates are Convex. (which makes it a perfect fit)
i'd highly recommend a NZXT Kraken X73 (had the same on a 10850k and it's almost 10°C better than my H150i RGB PRO XT (CoolIt Coldplate which is concave (better fit for AMD but not for intel)
12,453 (1.87/day)
I just put another EK AIO on a new 10600k a few days ago. It keeps it in the 60's on OCCT runs. However, it's the only cooler I've had on it, so I can't really compare temps. Take a look at the review on the EK AIOs. I have the non-RGB versions, which are the same minus RGB and cheaper.
EK AIO 360 & 240 D-RGB Cooler Review: Thermals, Noise, Coldplate Levelness | GamersNexus - Gaming PC Builds & Hardware Benchmarks
unclewebb
8,348 (1.35/day)
The 10850K are 10900K rejects. Intel jacked the voltage curve up to ensure that they run stable. You can significantly improve these CPUs by reducing the excess voltage to what the CPU actually needs. Some motherboards at default settings are very generous with adding additional voltage.
Here is an example while running Cinebench R20; first at default voltage and then the same CPU with a -125 mV undervolt. Night and day difference in power consumption and temps just by doing some tuning. The CPU is running at the same speed in both tests so performance is exactly the same. This is with a 240mm AIO.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
io grabbed a Noctua NH-U12S chromax.Black to replace my Corsair H110i GTX not long ago. it doesnt cool as well as the H110i, & its not as quiet as it either, but it does a very good job & it is in no way not quiet, & it carries none of the 'possible dangers' of liquid cooling. it cost me $65 iirc.
this was for my 8600K
its understated & not as large as i thought it wouldve been.
11,096 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
The 10850K are 10900K rejects. Intel jacked the voltage curve up to ensure that they run stable. You can significantly improve these CPUs by reducing the excess voltage to what the CPU actually needs. Some motherboards at default settings are very generous with adding additional voltage. Here is an example while running Cinebench R20; first at default voltage and then the same CPU with a -125 mV undervolt. Night and day difference in power consumption and temps just by doing some tuning.
This ^
my 10850 runs the same temps at stock as at 1.27v 4900mhz. Offset and then better 360mm AIO cooling...
The other thing I do is set motherboard auto-voltage with -.10mv offset and set a mobo thermal limit of 90 C, that allows me to run 5150mhz normal during gaming, with thermal velocity boost offset it backs down to 1.31v 5.05Ghz at 70C and then 1.27v at ~4900mhz at 90C (the performance is still fantastic even at 4900mhz 90C). So far that's been the best performing setup for me and also protects the chip during avx spikes.
12,453 (1.87/day)
I had this Noctua, and added a second Chromax fan. It's a great air cooler for it's size and it's whisper quiet. It still couldn't cool nearly as well as the EK AIO that replaced it, and once you added the additional $18 Noctua fan to the U12S, it costs just as much.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
This ^
Yep, I run 5.0GHz all core and it just barely breaks 80°C with my 240mm AIO under an Aida stress test. And I think the voltage could go lower, but I can't be bothered to tweak further.
6,871 (1.09/day)
S.E. Virginia
I appreciate the replies. Keep in mind, my cooling requirements includes cooling my 10850k at 100% full load 24/7 running BOINC. Gaming temperatures are of no concern as my CPU runs harder when I'm not using it. Currently, I'm running a "balanced" setting . It's bouncing between 3.6-4.8 GHz with temperatures staying at or under 60'c, but my BOINC points are down more than I care for them to be compared to what this CPU does at a locked 4.9 GHz all core clock.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
the only reason I went with the Noctua over my AIO is the enthusiast itch. I wanted to change up because id been running an AIO for five years or more. I’m glad I made the switch to, it is very quiet ,and it was half the price. Mainly I was happy to not have the same concerns you get with liquid cooling, as well as tubing getting dried out , pumps going bad, or any of that crap. Unless I crush it or do something stupid, it’ll never wear out :rolleyes:
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
And like we said, lower your voltage. My 10850K@5GHz doesn't break 80°C on any of the cores and only barely breaks 80°C on the package under an Aida stress test. Aida stress test is harder on the CPU than Bionic.
Don't throw money at a problem before trying the free solutions.
6,871 (1.09/day)
S.E. Virginia
OC adjusted to 5 GHz at 1.275 volts, will let it run for today and check temps when I get home from work this afternoon. I was running 1.3 volts. Temps right this minute are where I'd like them to be, but my room is cold right now. I sleep with a fan in a open window and right now, it's around 50-60'f in my room (I like a cold room when I sleep). We'll see what temps are like this afternoon after my room warms up to it's normal 73-74'f.
3,621 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
4.9Ghz at 1.24Vcore would make your CPU pretty chilly in the summer then :D
6,871 (1.09/day)
S.E. Virginia
And it didn't make it, crash at 5GHz @ 1.275 volts. No idea what temps got up to. Voltage bumped to 1.285 and clock dropped to 4.9, We'll see what happens today
well it made it though the day with no crash, but it's bouncing off the 90'c mark, so back to my original question, recommend me a better coiling option than my MSI MAG CORELIQUID 240R AIO unit that I have now. Something that if possible, will keep my 10850k below 80'c.
6,871 (1.09/day)
S.E. Virginia
really thinking about going back to air cooled and getting a Deep Cool Assassin III or Noctua NH-D15 and see how they do. I always preferred air cooling over water. So much simpler to manage.
Deep Cool Assassin III heatsink ordered, should be here Sunday.
6,871 (1.09/day)
S.E. Virginia
Assassin III heatsink installed. 4.9GHz all core @ 1.285 volts
