Blu-ray problem please help
1,156 (0.17/day)
System Name Alienware laptop R4
Processor intel i7-3610M @ 2,30Ghz
Motherboard dell?
Cooling 2 built in laptop cooling fans
Memory 16GB DDR3 1600mhz
Video Card(s) AMD Mobility Radeon HD m290x 4GB GDDR5
Storage 256 ssd and 512ssd
Display(s) laptop screen 17.3" 1920x1080 + LG 22" inch LCD HD 1920 x 1200
Case My laptop back pack case
Audio Device(s) Sound Blaster
Power Supply laptop brick
Software Windows 7 Home Premium 64 bit
Hello every one i have just bot a new LG blu-ray player. I was hoping to just put it in my exsternal sata case so i could use it with my lappy, well every thing was great i booted windows and it read the blu-ray disk so i strarted to wotch the blu-ray movie. then i got to the main menu and i hit play and the screen goes green but i can hear the movie playing, but theres nothing on the screen. eny help would be wonderful :)
Is the format supported by your computer screen??? Driver issue maybe?
sounds like a codec problem. what software are you using.
i have CyberLink Advisor and everything is in the green witch is good
What program are you using to decode the movie?
CyberLink power dvd.
its driving me nuts i want blu-ray :(
got any alternative players? i'm not sure what free ones can play blu ray players.
if you use anyDVD HD, that removes the encryption. you can then try media player classic in the CCCP codec pack - see my guide here
thanks but it says it can not render the image :( i think i migt have to rma this think :(:(:(
its a software problem. its just finding out what hte problem is. hell it could even be outdated video card drivers.
Well just updated drivers and nothing still doesnt work :(
hmm last thought, powerDVD has a 'hardware acceleration' tickbox. try with it both on, and off.
What version of PowerDVD? I do know PowerDVD 8 does provide software decoding of Blu Ray.
overclocker,
which soundcard are you using? Does it have the appropriate HDMI output and are those audio signals being passed to your AV receiver?
Tell us more about your hardware.
If you're using analogue cables for the audio is this reflected in your PowerDVDs settings?
yup that is the problem. Try that, I too had issues like that before.
Which version are you using? The free crap version? That thing is just piece of poop. Get the full version like me and you will be happy. I hated the OEM version and finally got the retail one and plays well.
For auto decoding of DolbyTrueHD and DTS HD to PCM DTS 5.1 install reclock and check the option on it to run with PowerDVD, it will take care of sound issues.
he he I have gone thru loads of pain to fix this sh*t.
tryed it and nothing i em using my laptop as in my specs <---
yes i em using the free version.
i bot an exsteral usb to sata case to run the blu-ray player
whoa dude, use edit and put those posts back into one. its against rules to multi post here.
Did u get the latest update for PDVD OEM?
yes i updated the blu-ray player. well should i rma it or do you think i can get it working i would love to keep it LOL.
well its definately a codec/software problem. Have a look around for trial versions of other blu ray playback software. Google found me WinDVD, as an alternative.
Are you using your laptop screen and external LCD at the same time? You might have to set it to only use the external display, as the video will only play if the player is on the primary display which is your laptop LCD unless you disable it.
