Centurion 5 CAC-T05-UW - Part of it is bent
The Pro
14 (0.00/day)
Processor Intel Core 2 Duo E6600
Motherboard MSI Intel 975X
Cooling Stock Fans/heatsyncs
Memory 2GB PC2 6400 Corsair XMS2
Video Card(s) XFX Geforce 7900GS
Storage Western digital 250GB SATA
Display(s) Samsung Syncmaster 204B
Audio Device(s) X-fi Xtreme music
Power Supply PCpowerandcooling Turbocool 510
Software Windows XP home
Hello, This is my first computer build and i got all the parts i needed
MSI 975X Platinum Socket T (LGA 775) Intel 975X
COOLER MASTER Centurion 5 CAC-T05-UW
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
XFX Geforce 7900GS 256MB 256-bit PCIE
Creative Sound Blaster X-Fi
DVD drive
WD 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s
SAMSUNG 204B-BK Black 20.1" 5ms LCD Monitor
PC Power & Cooling Turbo-Cool 510-SLI ATX12V 510W
Other stuff is not important.
Anyways i started building it today and when i took the case out of the package the part up where the top sidepanel screw is next to the PSU opening was bent so i could not get the side panel off.
I will post pics when my camra's batterys finish recharging.
What should i do, im not in the mood for waiting 10 days and paying $20 to ship it back to newegg. But i will if i have to.
Hello and welcome to TPU :toast:
I don't think this will of much help... but can't you bend it back?
I could try.
If i do will it void my warrintee or something.
Send it back to newegg if you want it PERFECT. Otherwise DIY!
DVD drive
Looks like Bill Gates christmas list :)
Good choices take it nice and slow no short cuts and that will be one tight p/c. So what you gonna run win xp server 2003 dos with 3.11 att unix linux ?
Windows XP home.
Ive decided to send it back only if newegg gives me overnight free shipping both ways.
Wow that took a long time.
I have the new case now.
But I cant seem to get the I/O sheild off.
There is no visible screws and ive tryed to remove it by pushing on it but nothing works.
Any suggestions?, I did not get a instruction manual that was more then 1 page when I got the case
The instructions for the case are found here in the PDF format, so make sure you have Adobe Acrobat:
http://www.coolermaster-usa.com/Download/Product Installation/Centruion 5_CAC-T05.pdf
Thats the most retarded manual ever.
Thats what I mean
Looks ok to me
Uhhh all you have to do is push on it..
Just make sure you are pushing on it in the right direction (lol).
Iam but it wont budge.
Eat your spinach Popeye :roll:
Which way are you pushing it...
Also make sure nothing is blocking it like a piece of the fan?
I'm pushing it into the case.
Nothing is blocking it.
Yep that worked. Thanks for the help.
lol wonder when someone would say get a hammer i would hae but alas i showed up to late
