- Mar 18, 2008
- 5,484 (0.87/day)
- Australia
System Name | Night Rider | Mini LAN PC | Workhorse |
Processor | AMD R7 5800X3D | Ryzen 1600X | i7 970 |
Motherboard | MSi AM4 Pro Carbon | GA-AB350H-D3 | Gigabyte EX58-UD5 |
Cooling | Noctua U9S Twin Fan| Stock Cooler, Copper Core)| Big shairkan B |
Memory | 2x16GB DDR4 G.Skill 3600MHz| 4x8GB Corsair 3000 | 6x2GB DDR3 1300 Corsair |
Video Card(s) | MSI AMD 6750XT | Solo RTX 4060| MSI RX 580 8GB |
Storage | 1TB WD Black NVME / 250GB SSD /2TB WD Black | 250GB SSD WD/2TB SSD, 2x1TB, 1x750 | WD 500 SSD |
Display(s) | Gigabyte 27" 1440P 180Hz / 22" DELL| MSI 27" 1080P 100Hz / 17" DELL | 22" DELL / 19"DELL |
Case | LIAN LI PC-18 | Mini ATX Case (custom) | Fractal |
Audio Device(s) | Onboard | Onbaord | Onboard |
Power Supply | Silverstone 850 | Silverstone Mini 450W | Corsair CX-750 |
Mouse | Coolermaster Pro | Rapoo V900 | Gigabyte 6850X |
Keyboard | Corsair K90| Ducky One | Some POS Logitech |
Software | Windows 10 Pro 64 | Windows 10 Pro 64 | Windows 7 Pro 64 |
Hi guys, I thought i might put this up for people that also might have missed this setting to get AHCI mode working on your motherboard.
A mate of mine decided to look into it and found a Windows Vista/7 fix so you can enable AHCI mode in your BIOS without the system blue screening, like it does for most computers that are already set on IDE mode.
Now most of you guys might already knows this but I didn't and all my computers where set on IDE mode and when I would change it to AHCI it would just crash when booting so I just thought oh well it don't work and never bothered with it again. But it seems if you set AHCI mode BEFORE installing Windows you wont have this issue, but if you did not set it before then running this Fix will fix your problem
Ok run this Fix > http://support.microsoft.com/kb/922976 then go to your BIOS, change your settings from IDE mode to AHCI mode, save and exit, boot into Windows, it will then install all the drivers that you need for this Mode. Once its finished it will ask you to reboot, reboot and your done
Made a big difference for me in boot times and file transfer times, everything sped up alot.
