Check CD quality?
AsRock
TPU addict
19,256 (2.95/day)
UK\USA
Cooling D15
I'm after some thing that will tell me what bitrate the actual music CD is. So anyone know of a program that shows this info ?.
JrRacinFan
Served 5k and counting ...
20,126 (3.04/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Bitrate? CD quality bitrate is 1411.2kbps. Or are you asking for a program that will detect what bitrate of a track was recorded at?
AsRock
TPU addict
19,256 (2.95/day)
UK\USA
Cooling D15
yes
JrRacinFan
20,126 (3.04/day)
Youngstown, OH
Storage 20+ TB
Ahhhh .....
Can't think of anything off the top of my head. Sorry. =/
Easy Rhino
Linux Advocate
15,686 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
what drone said.
AsRock
TPU addict
19,256 (2.95/day)
UK\USA
Cooling D15
checking between 2 tracks is not what i am after.
When a song is recorded originally to a CD the quality is normally kbit/s. So making a music CD 320 kbit/s when it's only 128 kbit/s would be a waste of time and HDD space.
As i am finding it more and more common most are 128 kbit/s which is lame ( as long as it's recorded at a higher kbit/s ).
Like i brought the enigma CD and i can say i am not impressed with the quality as it used to be much better.
3,565 (0.64/day)
By the Channel Tunnel, Kent, England
System Name Benny
Processor Phenom II 1055t @ 3.3GHz; 300x11; 1.380v; NB 2700; HT 2400
Motherboard ASUS Crosshair IV Formula (2002 BIOS)
Cooling Thermalright TRUE 120 Black + 2 Xilence Red Wing PWM 120mm (push/pull) + polycarbonate fan holders
Memory 8GB GeIL Ultra 2133MHZ C9 running at 1600MHz @ 7-7-7-21 1T 1.5v
Video Card(s) MSI Twin Frozr II GTX470 @ Stock w/CPU fan cable-tied on, as one of the GPU fans broke.
Storage 60GB OCZ Agility3 (OS);500GB WDC Grn; 1x1TB WDC Blk (Backup)
Display(s) ASUS PA823Q
Case Silverstone Raven 2 (all cables custom sleeved with velcro mod on side panel...)
Audio Device(s) X-Fi (Onboard) + Harmon Kardon HK6100 amp powering JVC HA-RX700's with Zalman mic
Power Supply Corsair HX650W
Software Win7 Pro x64
Benchmark Scores No benchies so making this space useful! Corsair M90, Logitech G19. Phobya FlexLight LED's (gawjus)
I would have thought just about anything; VLC has an option to look at the details of the media you're playing, so does MPC. I use them both all the time for checking bitrates on videos, they also give you details of the bitrate of the audio.
Tatty_Two
Gone Fishing
26,030 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
In Windows media player you can add Bitrate info to check the quality of your CD's playback before you rip them (by right clicking where indicated on attached pic) at therefore the "appropriate" quality (in whatever proggie you choose to use) if thats what your talking about...........
926 (0.15/day)
Akron, OH
System Name Main Rig
Processor Athlon 5350
Motherboard AsRock mITX
Memory 4gb
Storage 120gb Kingston HyperX SSD
Display(s) Samsung Syncmaster 740N
Power Supply Corsair 430 watt
Sounds like you are asking about the bit rate used to record the music in the first place. Most pros and studios today are recording digitally at least at 24bit/96khz and typically at 24bit/192khz resolutions or on analog tape and then converting them to digital--those are way, way above MP3 bit rates. The bit rates of the original recordings are also way above the bit rates of the CD's themselves. CD's all conform to the same standard (16bit @44100hz of linear PCM--the 1411.2Kbps quoted above). The original recordings have to be downsampled to fit on CD. If you have CDs in your collection that don't sound good, it's not because of low bit rates. It's just not a good recording or master, of which there are plenty.
There isn't any way for you to determine what was done on the recording/studio side as far as bit rates go, and it doesn't really matter anyway, because the bit rates they are using are way, way above CD bit rates anyway. Bit rate is just one factor in how good a recording sounds. There are plenty of ways other than low bit rates to screw up a recording, and that's what you are hearing.
10,487 (1.37/day)
Size of the file divided by the duration of the file in seconds = bitrate.
Considering bitrate only defines the amount of data used per second it is quite irrelevant. CD audio is uncompressed, thus has a very high bitrate, something like 650,000/(74*60) You can't compare this to the bitrate of an MP3 or any other format. It says little about actual quality.
926 (0.15/day)
Akron, OH
Memory 4gb
Not quite true--CD audio is compressed when compared to the master recording. Think of it this way--original recording contains all the musical data you could ever hear--CD contains about 95% of all the musical data you could ever hear (data wise, it is much smaller than the original recording)--MP3's contain X% of what the CD contains, based on the bit rate you select (data wise, it is much smaller than the CD).
AsRock
TPU addict
19,256 (2.95/day)
UK\USA
Cooling D15
Sounds like you are asking about the bit rate used to record the music in the first place. Most pros and studios today are recording digitally at least at 24bit/96khz and typically at 24bit/192khz resolutions or on analog tape and then converting them to digital--those are way, way above MP3 bit rates. The bit rates of the original recordings are also way above the bit rates of the CD's themselves. CD's all conform to the same standard (16bit @44100hz of linear PCM). The original recordings have to be downsampled to fit on CD. If you have CDs in your collection that don't sound good, it's not because of low bit rates. It's just not a good recording or master, of which there are plenty.
Yes they do down sample them so they fit but as time goes on some lower it to speed up the process and what ever other lame reasons. Then you have the remastered stuff which i find even worse for obvious reasons. As then your taking new hardware which is like changing your amplifier or speakers and what they THINK sounds right to them.
I know why i like records over is partly due to Dolby Digital as that crap takes away the edges of sounds to take away possible hiss but if you do or do not have his it still takes away sound.
So i wanted to see if there was anyway to check before ripping them of there disks.
So only real way is to buy the most original one you can get ya hands on
3,565 (0.64/day)
System Name Benny
Go into the WMP options and select the 'WMA Lossless' option, it should rip it at the same quality, if you really want to check the bitrate of your cd, try what I said in post 8.
926 (0.15/day)
Akron, OH
Memory 4gb
Unfortunately, a lot of the sound quality of the disc you've selected is based on the skill of the person doing the encoding/mastering. Here's what happens--musicians record what they want to in a studio and then mix it all together. Then, they turn that recording over to someone who's job it is to make it sound as good as it can on format X. So, one person will do the CD, another person will do the vinyl version, someone else will do the DVD--whatever the format. Some people are just better at this than others, just like anything else in life. So, you might get a CD that sounds great and a record that doesn't sound so good or vice versa, from the same original recording.
"Re-mastering" is a popular thing with CD's now. All it really means is that the original recording is downsampled to CD again by a different person using more modern tools 20 years after it was first tried. Generally, this results in a better sounding CD, but not always. In a lot of cases, you can't make beauty out of a turd, with the turd being a bad original recording.
Anyway, I digress--to get a good sounding CD, you need a good original recording plus a good master of the original recording to CD. The only way real way to find these is to read reviews where they listen to a lot of CDs and rate their sound quality.
