[Case Gallery] Cosmos 1000 WC
  • Thread starter Thread starter maxhardware
  • Start date Start date
M
maxhardware
Specs:
Wolfdale 3.0GHZ
Foxconn Mars
Corsair Dominator
Nvidia 8800GTS
Mods:
Watercooler
(unfinished) I waiting for cable management (from performance-pcs.com)
Looks good already, but I'll wait until you've got your cable management sorted out, to vote.
Right now, just because it's a simple and clean system, and that's what I love, I would probably give a 7 or 8, with cable management, an extra point, me thinks, since it's a tough case to do great cable management with.
If you've got more details about the loop, and how you've secured the radiator up top, I'd like to know, since I've been thinking of watercooling my system for a while now, and the Cosmos seems a good case for such a thing.
I change the pump (defective)
before
now
Really nice rig, the new pump rez combo look awesome, I also like the paint work & placement of the rads, smart build.
(sorry for my english, i speak spanish only)
Today received the Side Panel.
I'm very happy, only I lack the second pump for independent Loops
Holy; overkill on the Radiators dude! You must be operating in a really hot environment or something.
I like it!
were did you get the side panel with the window.
I like it!
Actual Room temp +/- 80°F
I use high overclock (518FSB x 9 = 4,662). I use a Peltier module (154watts)
<a href="http://img92.imageshack.us/my.php?image=88095262sm7.jpg" target="_blank"><img src="http://img92.imageshack.us/img92/7601/88095262sm7.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Im about to build a similar rig very soon. I will be using the same case. ( Oh and by the way... you can get that side window from newegg =] )
I have a question about the radiators.. well the one you mounted inside the case on the top. What brand is it and did you have to modd the case any to get it to fit? I was going to buy the swiftech kit with the dual radiator.. but im not sure if it can be mounted in a horizontal position on top of the case. here's the link for the LCS im buying for the case.. if you or anyone can help me out it would be nice i just need to know mainly if its going to work mounted atop of the case on the inside. thank you
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108076
It looks beautiful! Wonderful job! Very asthetically pleasing. 10/10 from me!
You payed $100 for that panel. Look like I need to make some changes to my prices. Sorry U had to pay so much, what's done is done, But looks good.
(Again, sorry for my english)
Look this:
svcompucycle_2008_1169699
Only $35 in SVC.com
But Clearside is smaller than the one I bought
Thats looking really nice, with the added loop, How much did the second loop bring temps down.
Temperature drop:
GPU = 5-7°F
CPU = 7-9°F
Actual temp: (idle) Without peltier (thermoelectric module)
Room: 79°F
CPU: 81°F (Wolfdale @ 3.0)
CPU: 90°F (Wolfdale @ 4.5) 500x9 @ 1.57v
GPU: 106°F (8800GTS 320mb)
Actual temp: (Full) Without peltier (thermoelectric module)
Room: 79°F
CPU: 92°F (Wolfdale @ 3.0)
CPU: 111°F (Wolfdale @ 4.5)
GPU: 136°F (8800GTS 320mb) (1 test with 3dMark06)
My next Mod, watercooling on:
-Northbridge
-Hard Drive
in 6-8 weeks. I have no money :(
10/10
awesome build
Love It!
looks really good.
cant look at your worklog, because log in is needed just to view, & everything is not my language, do you have some top secret webpage, that login is needed just to read a worklog.
worked that time... Your native language isn't English is it
