CPU Not Working after Swapping the Heatsink
Omg09
3 (0.00/day)
So I’ve just bought a new cpu heatsink from BeQuiet (Dark Rock 2) since I had enought of my stock cooler being loud like a Boeing engine (despite the fact the Wraith coolers are brilliant, I mean).
The cpu I have is AMD Ryzen 3700X.
While I unmounted the stock cooler, the cpu was stuck to the heatsink even though the socket lever was locked, which kinda frightened me firstly, but as I found out this happens time to time, I noticed that there were two pins bent on the cpu so I just straightened them using a thin blade.
After me separating the cpu from the stock cooler I put the cpu back and proceeded the whole process and set up the new cpu heatsink.
When I was finished I wanted to turn my PC on but as I pushed the Turn on button on the chasis, nothing happened.
I’m 100% sure there was power going to the computer and I didn’t do anything extraordinary during the swapping of the heatsinks.
Please, could anyone tell me what might be wrong with the cpu? Is there any chance of it working again or is it just definitely dead? Or is it the cpu, isn’t it anything else that is broken?
448 (0.06/day)
System Name Desktop
Processor 7800 x3d
Motherboard Giga b650i aorus ultra
Cooling pk-3 | conductonaut | AC LF II 280
Memory 64g Gskill X5 ddr 6000 cl30
Video Card(s) 7900 xt
Storage 2Tb Inland Premium
Display(s) Armada 27 1440p 165 + 25 1080p 240hz
Case Tt Black Armor : Phantek Evolv shift xt
Audio Device(s) Ae-7
Power Supply Aresgame 850 sff
Mouse Razer Viper ulti
Keyboard Saitek Eclipse I, II, & III
Benchmark Scores assd 6600|x5675 Cne11.5 -1102|Timespy 24000 | TS Extreme gpu 1 - 87 fps
Cpus go back into motherboard in a certain orientation, that I'm sure you quite aware of by now. i cant believe AMD is still using pins on their cpu. Didnt intel do away with that way back in x58 days. are they still doing that? check the 24 pin , 6/8 pin 5v rail/ and any 12v rails attached to the motherboard. Remove the entire pc and resetup outside the case. Thats how you found out if you have a short somewhere in the case. grab a spare cpu to be for sure. lets see the damage
Omg09
3 (0.00/day)
By those pins i meant those small things that cpus are connected to the socket (it’s easy to bend them), i donno whether it’s called somehow else, lack of vocab
I checked everything that goes into the mb, tryed to even unmount everything and put it together again but no result of that.
I’m thinking I probably killed the mb by static since I was doing the whole thing on a rug. Since neither of the fans spin and it doesn’t do anything when I try to turn it on.
Omg but what are the odds of killing such a new device by static (the mb is Asus ROG strix x470-f gaming with 3rd gen. bios friendly)
9,828 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Check to make sure the CPU cooler is fully positioned and installed level. Bad mounting can sometimes cause that issue.
3,419 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
On a rug? I'm afraid rugs and carpets are static magnets.
Yes, it is possible that static has damaged the motherboard, in that case. And yes, most of us have experienced the CPU being stuck to the cooler.
With the motherboard secure in the case, the cooler safely mounted on the CPU (the CPU wouldn't locate correctly if any pins were still bent, anyway), a memory stick installed, make sure you only have the PSU connected, checking of course that the front panel on/off/reset etc are connected correctly. Also, make sure you touch the case before contact with the motherboard.
Try turning it on and if that fails, try another PSU, if you have one to hand.
Omg09
3 (0.00/day)
Yea like a carpet thing :D I know about statics but there’s just this small probability of it actually damaging such a new device right, that was a thing like 90s-ish :D.. BUT I touched the chasis anyway to get rid of the static electricity..
I’m sure that the power supply unit is ok since a control LED on the mb actually indicates being powered.. also ensured that every single cable leading to the mb is plugged.
2,213 (1.04/day)
Hungary
Display(s) Dahua 30" LM30-E330CA 2560x1080/VA/200Hz
Mouse Canyon Puncher GM-11
A bit unrelated but what always worked me so far when removing the CPU cooler is to stress it and let it heat up somewhat before turning off the system. 'something like Aida/Prime stress for a few mins'
This way I never had my CPU stuck to the cooler and also no bent pins on my AMD CPUs and I mainly use AMD CPUs for ~15 years now.
18 (0.01/day)
System Name Lara10rd
Processor Intel Core i9 13900K
Motherboard Asus Strix Z790-F Gaming
Cooling Corsair Link H150i RGB LCD
Memory Corsair Vengeance RGB 32GB DDR5 6000mhz
Video Card(s) Nvidia RTX4080
Storage WD Black 770 Pciex 4.0 M.2 500GB
Display(s) MSI 32" 2K 165Hz 1MS Curve
Case NZXT H6
Audio Device(s) Realtek internal
Power Supply Thermaltake GF3 1200watts 80 + Gold
Mouse Corsair Harpoon Wireless
Keyboard Corsair K70 RGB
Benchmark Scores 3DMark TimeSpy 27, 175
Check to see if you are applying too much pressure to the processor when you installed the new cooler.
448 (0.06/day)
System Name Desktop
Processor 7800 x3d
did you accidentally leave the on/off switch following the cable to the motherboard disconnected? or maybe not put it back on the right way. trip the surge protector? trip the breaker box?
2,970 (0.80/day)
Long Island
Static is force of nature. There's been no "new revisions"
Over tightening can cause this as moBo warps,
AsRock
TPU addict
19,254 (2.95/day)
UK\USA
Cooling D15
All so a gentle twist of the cooler clockwise and anticlockwise.
Hope he has not bent any of the pins.
4,914 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
If the Dark Rock 2 has compression springs they should bottom out preventing you from over tightening, and wrapping the motherboard.
