System Name | ab┃ob |
Processor | 7800X3D┃5800X3D |
Motherboard | B650E PG-ITX┃X570 Impact |
Cooling | NH-U12A + T30┃AXP120-x67 |
Memory | 64GB 6400CL32┃32GB 3600CL14 |
Video Card(s) | RTX 4070 Ti Eagle┃RTX A2000 |
Storage | 8TB of SSDs┃1TB SN550 |
Case | Caselabs S3┃Lazer3D HT5 |
Processor | 7800X3D -25 all core |
Motherboard | B650 Steel Legend |
Cooling | Frost Commander 140 |
Memory | 32gb ddr5 (2x16) cl 30 6000 |
Video Card(s) | Merc 310 7900 XT @3100 core -.75v |
Display(s) | Agon 27" QD-OLED Glossy 240hz 1440p |
Case | NZXT H710 |
Power Supply | Corsair RM850x |
Ryzen Master reads CPU idle voltage and temperatures through a proprietary method that no other software can. Readings will be different regardless of what you use - Afterburner, HWInfo, etc. This is the decision AMD has made.
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
How much of a difference are you seeing?Anyone else seeing the cpu temp reported in gpu-z does not match to that displayed in Ryzen Master ?
Memory | 48 GB |
Processor | AMD 5900x |
Motherboard | Asus x570 Strix-E |
Cooling | Hardware Labs |
Memory | G.Skill 4000c17 2x16gb |
Video Card(s) | RTX 3090 |
Storage | Sabrent |
Display(s) | Samsung G9 |
Case | Phanteks 719 |
Audio Device(s) | Fiio K5 Pro |
Power Supply | EVGA 1000 P2 |
Mouse | Logitech G600 |
Keyboard | Corsair K95 |
i found hwinfo to read same as ryzen master. /shrug
Storage | Sabrent |
I'm not doubting that I was just raising the point that the cpu temp monitoring in cpu-z is not accurate at all. I don't rely on it anymore....
