- Mar 8, 2006
- 1,200 (0.17/day)
System Name | Desktop / Laptop |
Processor | AMD Ryzen R7 5600x / Intel i5-4200U |
Motherboard | ASUS TUF B550-Plus / Lenovo MB |
Cooling | Arctic Liquid Freezer II 280 / Stock |
Memory | Corsair Vengeance 2x16GB DDR 3800 / 8GB DDR3-1600MHz |
Video Card(s) | AMD Radeon 6900XT / Intel HD 4400 |
Storage | 2.5TB SSDs + 4TB HDD / Samsung 850 EVO 500 GB |
Display(s) | 34" LG Ultrawide / 12.5 " 1080p IPS Touchscreen |
Case | Fractal Design R6 / Lenovo X240 |
Audio Device(s) | Onboard / Onboard |
Power Supply | Enermax REVOLUTION87+ 1000W / Lenovo 40W |
Mouse | Razer Basilisk X |
Keyboard | Dell Business Multimedia Keyboard |
Software | Windows 10 Pro 64 bit |
Benchmark Scores | Chicken Invaders 5 @125+ FPS |
I have the Zotac 3070 Twin Edge and I am not very happy with the noise the cooler makes. I made a custom fan curve but it's still not great. Given the current price-hike of GPUs I think trying to get a better custom cooler GPU will cost me more or less the same as getting this card water cooled plus the benefit with a watercooling is that in the future I can re-use it and just get a new block. I have a CPU AIO which I don't plan to change but I do want to make the set-up future proof with the ability to add another radiator and a CPU block.
I am a noob at this so want to make sure I get all right. Anyone has any good guides to recommend? I am looking at alphacool and EK, are there any other recommended companies? Also any drawbacks at getting pump / reservoir combo?
Looking at alphacool I am thinking:
- Radiator: Alphacool NexXxoS ST30 Full Copper 280mm radiator V.2
- Pump Alphacool Eisstation VPP reservoir incl. VPP755 or Alphacool Eisstation DDC reservoir incl.DDC310
- What is the difference between the 2 pumps? Which one is recommended
- Waterblock: Alphacool Eisblock Aurora Acryl GPX-N RTX 3070
- Hoses: I want flexible hoses. What kind of diameter do I need?
- Fittins: What kind of fittings should I use
- Coolant: Is there any difference between the cheaper and more expensive in terms of performance or is it only looks? My case has no window so looks is not important
