Discussion: Rare problem, PC runs on case A but not B
A UPS would still not prevent shocks when touching the case. A ups connected between the socket and your pc is still supplying in AC. Also a Ups or surge protector need a grounding point for it to function well enough. Your Psu is the one responsible for turning it to dc current. That is why its power is measure in Voltage-ampere for it power rather than watt. Static build up would still happens.
It is true you can ghetto build ground points like connecting wires of your case to water pipe or a metal rod to the ground to get the grounding. It'll worked but the former is abit dangerous if the pipe have water that you use. The latter is how grounding work in its basic form. It is cheap way but I would still recommend doing it the proper way. If you have a metal rod around and hammer. It can be way to grounding.
Good luck Op which ever way that is easier and affordable for you.
I will show you what its like in the US since I got to learn about Indonesia.
th
th
The left socket is modern with negative positive and earth but on the right is what I use to have that is old with no earth and bad for almost everything unless your talking about charging a cell phone.
The electrical box right below in the big picture is outdated and they usually dont look so good and are actually older in a lot of houses if they have not been replaced. You can have a lot of problems with having to replace fuses and being overloaded.. especially in the summer with air conditioners.
This one on the right is our modern electrical circuit breaker box. No more fuses and no more problems.
your 3 pin socket looks like a face :)
Never seen house with big electrical box like above. Usually houses around here have very small electrical box that consist of single switch
Good to know, thanks
Their called circuit breakers in my place. What it does is all the wiring in the house is wired to it and then it is wired outside to your power company. The function of the circuit breakers is well like its name suggest to break circuits if there is a short-circuit somewhere in the house or building. Old circuit breakers like what @xfia shown uses fuses to cut the circuit when there is short somewhere protecting the house from fires. The downside is fuses are one time use. When the fuses is broken it would have to replaced. It would sucked having to change it when there is power surges or power spike tripping the breakers. It is also more dangerous changing fuses as the electricity is still flowing if you never off the mains form the power company. Modern circuit breaker uses a magnetic switch rather than a fuse. When there is a short-circuit the the switch is flip off cutting the circuit. Their much better than fuses and would not require changes when it is tripped, you just have to flip the switch back on.
I think your house is probably the modern one a simple modern one. I am just guessing.
This is what our breaker looks like. Very traditional.
The left picure is the breaker that connect to power company line. Still using analogue power consumption counter.
The right picture is the fuse inside the house. Still using that old cylinder fuse. One time usage, need to be replaced if blown.
Fun fact, modern fuses (at least in Europe) have two modes for braking the circuit, one i the magnetic one (for fast blow) and one is thermo trigger, blowing at low over-current (ca 11 A for a 10 A b fuse. 17.5 A for a 16 A b fuse)
Op has modern main breaker (under the power counter), but only one phase!
I strongly recommend staying away from all of that and either calling the pros or moving. If you do it yourself, and you don't know what you are doing (and it seems you don't, otherwise you wouldn't be asking us) it's possible you could either be hurt or outright killed by something.
Not trying to put down your ability to do anything man, but when it comes to anything electrical it's best to be 100% sure before you start stuff like this,
aha so problem is that gorunding isnt connected at all.
you can fix it by yourself it isnt hard but you have to be careful and to turn off power before you start workng.
here is guide how to wire schuko plug http://www.howtospecialist.com/installation/electrical/how-to-wire-and-install-an-electric-output/
but most likely wireing in your house dont have grounding cable (green/yellow one) or you wouldnt have problems you have.
in order to fix this you need mains tester like this
, screw driver and some spare wire (0.75-1mm2).
check where is live wire with tester and on socket cover put dot with marker over hole of life wire. turn off power and remove cover. transfer marker dot to the base of the socket (the part that is in the wall) and take out socket base from the wall.
cut ~5cm from spare wire and strip about 1cm insulation from both sides.
wire grounding pin to the nul cable (the one W/O marker dot). if wireing in you house is made properly all life wires should be same coler but still check em with tester for just in case.
tighten bolts of the wires and check with 2 fingers and mid force if you can pull out cables out of their places. if cable popped out reseat it and tighten bolts again.
reseat socket in the wall place cover back turn on power and test all pins with mains tester (grounding pin too). if tester lights on anything beside marked pin you've made a mistake with wireing.
if everything is ok you can test socket with real device. plug it into socket and check if you are shocked from metal parts.
repeat for all sockets in your house.
Don't do this. If you get it wrong you'll have 230v on your toaster case. If there's no ground, there's no ground. Adding a faux one in the sockets doesn't solve anything, just makes it dangerous.
This. Do it wrong and things might burn.
too late. all sockets in my house are already nullified and everything is running fine.
leaving it w/o grounding could be far more dangerous then nullifying sockets and testing you you did it right.
When would it be far more dangerous?
I do agree with Frick. Wiring the wrong order is a common beginners mistake that can yield disastrous consequences.
1st thing to check with the electrician is the main grounding, from PLN's meter there should be 2 wires: 1 live & 1 neutral, from there the neutral is bonded with earth/ground wire so that there should be 3 wires coming off the fuse: 1 live (through the fuse), 1 neutral & 1 PE/ground.
if the earthing/grounding (that should be bonded after the meter) is missing, you would need to install one coz it is actually mandatory for SLO (newer installation is required to have SLO (sertifikat laik operasi) before PLN connect it to their distribution line. if it's already there then you would just need to install new cable for the PE (protective earth/grounding) to all socket outlets.
when you have leakage from live wire because of damage insulation and you touch metal parts of device. you dont know when it will happen or to whom will happen
(could be kid!!) nor you know if you will be in home to help or even if you are will you have time to react or will you react fast enough. such situation with so much factors that are out of control is far more dangerous than braking some fuses or sockets with wrong wiring.
if op is confident enough to replace socket by himself he can do this too. it isnt anything different beside a bit more work to be done. if op isnt confident to try he can always call technician
i also said
And if the neutral gets loose you get the same effect.
Considering Schukos are not polarized (meaning you can insert the plug in either orientation), unless you were to attach the phase (brown or yellow) to the ground prong, the order doesn't make any difference.
That is generally only an issue in split-phase (2 hot+neutral) appliances using a 3 wire/3 prong connection. Up until about 20 years ago they used to allow the chassis of things like electric stoves, dryers, etc to be bonded to neutral. This would still trip a breaker if a phase was shorted to chassis, except if the neutral was loose/open. Thats why code was changed to require a separate equipment ground conductor (EGC) and 4 prong plug. Regular plug-in equipment such as a lamp, toaster or computer power supply NEVER has the neutral bonded to the chassis. This is especially true of any equipment with an IEC interchangeable cord that could have something like a Schuko or Europlug on the end which is not polarized, because that could potentially put phase current to the chassis.
Now seeing what the OP has, if he is getting zapped by his computer and appliances, and if he has 3 prong Schukos it indicates that there is current on the EGC - which means not only is it improperly installed and/or disconnected at his main breaker, but also that something else that's plugged in either has a phase short to ground or an improper neutral -> EGC bond. Just because there is no ground wire connected to the Schuko doesn't mean there isn't a conductive path between the different outlets in the house.. The ground clips on any grounded outlet are also connected to its metal mounting bracket (unless it is specifically designed with an isolated ground - these are colored orange and have a Δ symbol on the face, usually only found in hospitals and such). If it is installed in a metal box with a metal conduit or armored cable between them, that can act as a conductive path.
The pic of his meter isn't very clear, but I see a yellow wire that doesn't appear to be connected - if it is yellow and green, this is probably his EGC. It looks like a brown wire is behind it connecting to the breaker. I know a lot of asian/european countries used off-standard colors years ago, so if I could see a better pic of whats in there I could say for sure. I also do not see a GEC (grounding electrode conductor - the wire that is supposed to go to the ground rod) coming out of the main breaker box.
Check the USB ports on the first case. Shorted USB ports can prevent the system from starting.
That is exactly why you wouldn't connect the ground to the neutral in the socket, isn't it?
I had to re-read that post a couple times because I didn't realize that's what ne6togadno was saying to do - I thought he was saying to just install a grounded outlet without the ground.. You're right, that's called a bootleg ground, and it's dangerous for the same reason they no longer allow it in large appliances. Under normal cconditions it would technically be safer than what he has now, because the chassis becomes grounded (a bootleg ground at the outlet is different than bonding in a non-polarized device), and it WOULD let a short to chassis trip the breaker, but if the neutral is open it will allow current to backfeed to the chassis - which is a variation of what he is experiencing now..
So the OP has to figure out if there is a conductive path between the outlets, and if there is he has to figure out why there is current running along it. I know surface wiring is common in europe and asia, so if that's what he has it probably won't be all that difficult to add a true ground wire.
I dont got grounding either in my living room only bath and kitchen. I have pulled an extension cord from the kitchen to the living room to my PC desk
Thank you, mine was a pretty old house and I don't want to risk opening PLN's seal just to see the wires, so I'm gonna call electrician.
USB works fine
To everyone, thank you for your feedbacks. I don't really understand about electricity and I don't want to take risk doing modification, even the simple one. So to be safe, I called electricians to do it.
They will be doing their work next week and hopefully will fix my issue.
no, you don't need to open the meter's seal. just check the wires running from the meter to the fuse box inside. just ask the electrician to check the main grounding.
