- Dec 8, 2020
- 3,235 (1.93/day)
- United Kingdom
I have had that question before, I don't think so. You could try mute then sleep, I am not sure to be honest sorry.
Set 'Stereo Mix' to 24 bit 48k, which matches the main stream, though I doubt that helps.
As a side note, listen to, mute, and a few other features are Windows, not Realtek.
Also be sure to set your media player to 32 bit float. If you have Z906 you will (should) hear the difference.
The Z906 uses digital Class-D, so basically an early PowerDAC, 48 bit 200MHz.
