Full system scanner?
1,498 (0.27/day)
canada
System Name INTEL/AMD
Processor I7 4790k stock / 1100T@3.8GHZ(on air)
Motherboard GIGABYTE GAMING 5 / GIGABYTE GA-990FXA-UD3
Cooling Noctua NH-D15 / zalmen 9900
Memory 4x4 GB 1600 / 4x4gb 1600
Video Card(s) GTX670 x2 / ATI 5870 x2
Storage 2xcorsair ssd 120gb raid0 /2x adata ssd 120gb
Display(s) 55Iinch LCD / 22inch acer
Case CM 690 II Advanced (USB 3) / Anteck 900
Power Supply Enermax 800EWT / 750 zalman
Software Win 10
i need a program to check everything on my pc i.e ram hhd gpu cpu for problems i keep freezing and crashing. even on stock i dont get it. i need something to check for problems a eazy program for free or for pay.:rockout:
BinaryMage
608 (0.12/day)
System Name Igne Mortis
Processor Intel Core 2 Duo E8500
Motherboard Gigabyte GA-EP45-UD3P
Cooling Arctic Cooling Freezer 7 Pro LGA775
Memory 4GB OCZ Platinum DDR2 1066
Video Card(s) ASUS HD4850 TOP
Storage Seagate 500GB
Display(s) Dual 1280x1024
Audio Device(s) Integrated
Power Supply Antec NeoPower 550
There is no magic "cure-all", so don't look for one. I would first try updating drivers, running an antivirus scan, and switching components to check for a bad component. One of those should fix your problem.
7,023 (1.31/day)
You can't check everything at once.
Memtest for ram
prime95 for cpu/ram interface
hyperpi for cpu
aida64 for ram and cpu benchmark
And all gpu stuff is here:
http://www.ozone3d.net/
edit: to check your hard drive use chkdsk, to check windows files use sfcscannow
5,123 (0.88/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
what exact PSU do you have?
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Memtest for ram
hyperpi for cpu
Don't forget about OCCT as well, can stress GPU, CPU, PSU. Can do a form of linpack cpu stress as well. I also utilize the above when ensuring stability or testing for intermittent failures/crashes.
1,498 (0.27/day)
canada
Software Win 10
my system locks up sometimes and like the cpu thing on my g15 still moves then it snaps out of it or it bsod or just frezzes its a rocketfish 900 watt power unit. or my tv and monitor will flash for a bit then snap out of it. i dont get it
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Test your hard drive with HDtune
5,123 (0.88/day)
North of Germany
There you have your culprit... rocketfish should be huntkey, and a huntkey PSU is... well...
one big steaming pile of crap.
All of your rig is fine, but it wouldnt wonder me if the PSU cant keep up... after i yesterday read this review about a 1000w generic PSU housing parts that actually could deliver a max of 750w, till the whole PSU blew,and was only safe when using it as 500w PSU... im pretty sure that if you exchange that, your problems gonna vanish;)
1,498 (0.27/day)
canada
Software Win 10
so your calling my ROCKITFISH A POS lol my company owns it and it feels bad man. j.k how would i test it safely? or do i just buy a new1?
5,123 (0.88/day)
North of Germany
best would be to lend yourself a good, branded PSU if possible, from a friend or so, to see if that will bring change... if the crashes are the culprit and you use, say, a 1000w corsair PSU.... and the culprit vanishes instantly... then you can be pretty sure that it was the PSU...
There are also plug-in testers for PSUs, but most shouldnt be of too good quality.... the best test, is indeed, testing with a part gueranteed to work:)
1,498 (0.27/day)
canada
Software Win 10
i did the hd tune test and my ssd is fine? i cant get memtest to boot from disk what other program can be used to test this? and what is a good brand of psu?
5,123 (0.88/day)
North of Germany
use OCCT with the Powersupply stress test;) if that acts up.... you can also be pretty sure i think
1,498 (0.27/day)
canada
Software Win 10
if it blows up then what lol?
5,123 (0.88/day)
North of Germany
they you got some nice RMA material, and can be dead fond of your problem:D
PSU should stand that, and if it blows... BOOOO! :p
1,498 (0.27/day)
canada
Software Win 10
well i might try this in another rig i.e a shitty one cuz i dont wanna blow up my pc i dont have the money for that.
5,123 (0.88/day)
North of Germany
that wont help your problems i guess.... how should you know, your PSU is the culprit, if you test on a completely different rig?:)
i also have to say, that chances are bigger, that before anything blows, your system will rather hang aggressively ;)
1,498 (0.27/day)
canada
Software Win 10
but iv herd when ur pus goes it takes ur system with it and if i just buy a new1 i will have a better energy efficiency but what is some god brand names for psu i dont rlly know much about them.
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
i personally go with pc power and cooling. a lot of people recommend
rosewill, corsair is also a good brand.
go with a lower wattage rating, but better brand and better energy star rating.
i can't see your specs, but i doubt you need 900 watts. most gamers,etc,
myself included , need about 600 watts. go with that and a good brand,
rather than spend the money on a crap brand with a higher rating, that
means nothing.
most regular/office users can go with a 350-400 watt no problem.
5,123 (0.88/day)
North of Germany
but iv herd when ur pus goes it ta+kes ur system with it and if i just buy a new1 i will have a better energy efficiency but what is some god brand names for psu i dont rlly know much about them.
a PSU like yours surely can do that, but i have had quite a few generics blow, and never, i had problems with the rig... i dont want to say,that it cant happen... but its pretty rare. As said, i think before that happens, the rig will probably crash anyway.
Yeah, if the PSU you buy, is a PSU branded for efficiency like 80+ bronze,silver or gold, it will also save you money on the electric bill, each month. (compared to the rocketfish)
If you want a good PSU, just buy a Corsair,Pc Power & Cooling,OCZ ModXstream, or Enermax... Corsairs are pretty good for their price, and Enermax pretty expensive but even better (in my opinion);)
wattagewise, i would go for at least a 750w unit, to be able to keep it, no matter what HW you gonna get after it ;) maybe, one day you want something that will pull more :)
1,498 (0.27/day)
canada
Software Win 10
ok thz to everyone that replayed to this i will be buying a better one anyways cuz this one was a temp that i never replaced lol.
5,123 (0.88/day)
North of Germany
hope that this will solve your problems;)
