GPU-Z and multiple GPU's
[Daniel]
4 (0.00/day)
System Name The Eternal Upgrade
Processor Core i7 920 @ 3.36Ghz (x20 + Turbo)
Motherboard eVGA x58 3x SLI
Cooling Noctua NH-U9B & 2X9cm (push/pull)
Memory 6x1Gb Aeneon xTune DDR3 1600
Video Card(s) eVGA GTX260 Core 216 & Core 192 (both 65nm)
Storage WD 640GB (SATA2)
Display(s) Benq FP241W 24"
Case CM Stacker 830 Evo
Audio Device(s) X-Fi XtremeMusic
Power Supply CM Real Power Pro 1000W
Software WinXP Pro x64 SP2
Greetings. New GPU-Z user here. I have version 0.3.3 running right now on my i7 rig.
Here's some background leading into my question... I bought a GTX260 Core216 (65nm) back in December. Recently, GTX260's have been dropping in price. In my area, only the non-Core216's were going on sale... so I decided to not "wait and see" and bought a GTX260 (192 Core) to enter the SLI arena with.
But I noticed when I opened the nVidia Control Panel and ran the System Info tool... both cards were reported as Core216 models... I felt like I'd won the lottery for a moment, then questioned how "valid" the reading was. I had heard stories about people receiving the Core216 when they had ordered a vanilla (192), so it was possible.
So I downloaded GPU-Z as a "second opinion", and it reports them the same... almost "too identical" tho... there is not one character anywhere that I can tell the difference between the 2 cards on the main "info" page.
I know I can pull my old card out and try take the readings of just the new on, but I am hoping to avoid that. If GPU-Z "talks" to each card individually, I think I'd happy camper.
So, can I trust this reading? Did GPU-Z query each card independently? Or did it pull information from the "nVidia SysInfo Tool", which may or may not be correct.
Thanks in advance!
Daniel
Normally if you are running a 216 with a 192, SLI causes both to run as 192SP GTX 260's.
Disable SLI, then see what GPU-Z says between the two.
EDIT: Just seen in GPU-Z SLi is disabled.
Looks like you got lucky and got another 216Sp! :toast:
gpu-z reads from the gpu directly. make sure sli is off. if both are still 216 sp run some benchmarks on one card and then on the other (have just 1 card in the system to be sure)
Ah, you beat me to my edit ;)
Whether I have SLI enabled or disabled, the same information is presented. In the attached scheenshot I added to the original post, you can see SLI is disabled.
As w1zz says try some BM's, but to me it looks like you got another 216SP sitting there! :D
Could it be an issue with XP 64?
Anyway, I would do a driver wipe with DriverSweeper, then re-install the drivers. See what it says after that. If it is still the same, I would test with just the new card in the machine.
Hmm, I never noticed if benchmarks allowed me to point to a specific card... I'll have to check that out.
That is what I did right before adding the new card...
  • uninstalled driver
  • booted into safe mode
  • ran driver sweeper
  • powered off
  • added new card
  • added SLI bridge
  • powered on
  • loaded driver
They don't, once you disable SLi, the benchmarks/games will use whichever card the monitor is plugged into.
I would just pull the old card out of the machine and get the readings on the new card alone.
I do run multiple monitors. I didn't like how the nVidia driver would occasionally incorrectly handle which was the primary monitor when going in/out of SLI... more times than not, my 19" CRT would get the nod, and that was just plain wrong.
So I moved the 19" to the second (new) video card. What this also allowed me to do was run CUDA GPU-folding instances (one per card) when not in SLI.
So it's too bad the bench tools don't check/ask... I would be ready for it ;)
