- May 14, 2004
- 28,753 (3.75/day)
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
Memory | 48 GB |
System Name | MONSTER |
Processor | Core2 Quad Q6600 G0 @3.6GHz (9x400MHz) 1.35v |
Motherboard | Gigabyte GA-P35-DS4 Rev. 1.0 |
Cooling | Home-made water cooling + 3x120mm 1200rpm case cooling |
Memory | 4x1GB Kingmax DDR2-1066 @ 1000MHz CL4 5-5-16 |
Video Card(s) | Asus EN8800GTS (g92) 512MB @core:783, shader:1944, video ram:1044 |
Storage | 2x250GB Hitachi 8MB 7200RPM SATA2 RAID0 + WD 400GB 16MB 7200RPM SATA2 |
Display(s) | Samsung 226BW 22" 1680x1050 2ms |
Case | Custom Made |
Audio Device(s) | Creative Labs Audigy X-Fi XtremeMusic |
Power Supply | Spire Rocketeer 600W |
Software | Vista Ultimate 64 & 32 bit; Windows XP Pro 64 and 32 bit |
Benchmark Scores | 17645 3D Mark 2006, http://service.futuremark.com/compare?3dm06=4995796 |
Processor | Intel i9 9900K @5GHz w/ Corsair H150i Pro CPU AiO w/Corsair HD120 RBG fan |
Motherboard | Asus Z390 Maximus XI Code |
Cooling | 6x120mm Corsair HD120 RBG fans |
Memory | Corsair Vengeance RGB 2x8GB 3600MHz |
Video Card(s) | Asus RTX 3080Ti STRIX OC |
Storage | Samsung 970 EVO Plus 500GB , 970 EVO 1TB, Samsung 850 EVO 1TB SSD, 10TB Synology DS1621+ RAID5 |
Display(s) | Corsair Xeneon 32" 32UHD144 4K |
Case | Corsair 570x RBG Tempered Glass |
Audio Device(s) | Onboard / Corsair Virtuoso XT Wireless RGB |
Power Supply | Corsair HX850w Platinum Series |
Mouse | Logitech G604s |
Keyboard | Corsair K70 Rapidfire |
Software | Windows 11 x64 Professional |
Benchmark Scores | Firestrike - 23520 Heaven - 3670 |
Would you like to share some more details about it(GT200)?![]()
Memory | 48 GB |
System Name | Work in progress |
Processor | AMD 955---4Ghz |
Motherboard | MSi GD70 |
Cooling | OcZ Phase/water |
Memory | Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000 |
Video Card(s) | CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz |
Storage | SSD 64GB |
Display(s) | Envision 24'' 1920x1200 |
Case | Using the desk ATM |
Audio Device(s) | Sucky onboard for now :( |
Power Supply | 1000W TruePower Quattro |
Thanks mate!install a gt200 card, run gpu-z to see the details
System Name | MightyX |
Processor | Ryzen 9800X3D |
Motherboard | Gigabyte B650I AX |
Cooling | Scythe Fuma 2 |
Memory | 32GB DDR5 6000 CL30 tuned |
Video Card(s) | Palit Gamerock RTX 5080 oc |
Storage | WD Black SN850X 2TB |
Display(s) | LG 42C2 4K OLED |
Case | Coolermaster NR200P |
Audio Device(s) | LG SN5Y / Focal Clear |
Power Supply | Corsair SF750 Platinum |
Mouse | Corsair Dark Core RBG Pro SE |
Keyboard | Glorious GMMK Compact w/pudding |
VR HMD | Meta Quest 3 |
Software | case populated with Artic P12's |
Benchmark Scores | 4k120 OLED Gsync bliss |
When you launch the exe, it works in the same way CPUz does. All it does is tell you information about yoru video card such as speed, who made it, what brand it is, etc.
In the sensors tab, it tells you the temperature of the video card.
System Name | My Current Desktop |
Processor | i9 12900KF |
Motherboard | Asus ROG STRIX Z690-E GAMING WIFI |
Cooling | ARCTIC Liquid Freezer II 360 |
Memory | G.Skill Trident Z5 RGB Series 64GB (2 x 32GB) DDR5 6400 F5-6400J3239G32GX2-TZ5RW |
Video Card(s) | RTX 3090 FE |
Storage | SAMSUNG 980 PRO SSD 1TB |
Display(s) | Samsung G80SD |
Case | Fractal Design Torrent White |
Audio Device(s) | Schiit Bifrost2 |
Power Supply | Corsair HX850 |
Mouse | Razer Basilisk v3 pro |
Keyboard | Keychron Q6 Max (brown) |
Software | Win 11 Pro |
Memory | 48 GB |
Memory | 48 GB |
