Graphics Card Won't Display! Please Help
solidspartan117
5 (0.00/day)
Hi I'm new here and I have a big problem, I have tried everything and would like any help I can get.
My Rig:
Intel Core i5 2320 @ 3.4Ghz
Acer Oem Motherboard
4Gb Dual Channel 1333Mhz DDR3 Ram
Gainward GTX275 Golden Sample
500Gb Western Digital Blue Caviar
DVD Re-writer Drive
3 Non-LED Case Fans
Fractal Design Tesla 600W Psu
The Graphics Card when connected wont display through my monitor and I have Re-seated 4x and checked that all connections are secure and that both 6-pin Pci-e are connected but still no display. When I plug it into my On board Graphics then the display comes on and everything works, I have tried disabling the on board Graphics through Device Manger to no avail and I cant change the primary boot in the Bios as it is Oem and wont let me.
The PSU is new and has more than enough power but I will give you some details:
+3.3V = 24A
+5V = 24A
+12v1 = 20A
+12v2 = 20A
+12v3 = 20A
+12v4 = 20A
-12v = 0.5A
+5Vsb = 2.5A
The Continuous output is rated at 531.5W with a peak of 600W and is 80Plus Certified
So I highly doubt it is the power supply as it has more than enough but I suppose it could be faulty? and it was then how would I tell?
I also should mention that I have tested the Graphics card in another system and it worked fine and when I put a low profile card into my computer it worked, so is it my Motherboard or something else? I am at a complete loss and any help would be greatly appreciated.
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
You may need to config the GPU options within the bios.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Assuming you have actually put the 275 in the correect PCI-E slot, might I ask a couple of questions........
* Can you boot to integrated graphics with the 275 in the slot through "safe" mode (F8?)?
* If you can, can you disable integrated graphics in device manager whilst in safe mode so that on normal restart it may then boot to 275? Does Device Manager identify both integrated grapics and 275?
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
try to turn it on without card then set the bios to use pciex card then turn it off
plug the card into pciex slot and try turn it on
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Guys, I think he is saying that his OEM Bios won't allow him to do that.
"I have tried disabling the on board Graphics through Device Manger to no avail and I cant change the primary boot in the Bios as it is Oem and wont let me".
solidspartan117
5 (0.00/day)
Hey and thanks for all the quick reply's :)
When I go into Bios it wont let me select what to boot from as it is just blacked out, also when the card is installed I can use the onboard graphics fine but switching the the Graphics card gives a black screen.
I did try to Disable and uninstall the onboard Graphics but it still didn't work and I tried to install the Graphic cards Drivers but just said "No compatible hardware could be detected".
When I'm in the Device Manager it only detects the onboard Graphics and not the Graphics card, it is installed into the correct slot as I only have one as it is a Micro-ATX. I have ran Memory Diagnostics and temperature tests and everything is fine.
I also tried using the DVI, HDMI and VGA with nothing but a blank screen.
6,270 (0.89/day)
New York
Does the fan on the Graphic card spin up?
2,318 (0.33/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
6,270 (0.89/day)
New York
Try the graphic card in safe mode? If so does it work?
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I wonder if ACER did something evil like put a jumper on the board to disable on-board graphics.
solidspartan117
5 (0.00/day)
Well in the Bios the Graphics is set to auto and I can't change it but what do you mean boot into safe mode? Do you mean with the GTX 275 or the onboard? As I cant even get the bios to display with the GTX275??
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Try and find out any info on the motherboard that you can, there are some of these OEM boards where the manufacturer just locks/hides advanced bios options and there are some little apps out there that can unlock them.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
What model of ACER machine is that?
Edit: http://acer.custhelp.com/app/answers/detail/a_id/1116/kw/upgrade video
Maybe relevant, I dunno, it only talks about ATI video cards:
Why isn't video displayed with some add-on PCI-Express video cards on my Acer desktop?
While the Acer Power Fe and Acer Aspire T670 desktops meet PCI Express standards ATI had identified an issue where certain older Radeon video cards have a conflict with the integrated video controller present on the desktop. Due to this conflict some PCI-Express video cards will not be recognized as installed on the desktop.
Note: If the add-on video card is not recognized by the desktop the video signal will still be present on the integrated video port on the desktop.
solidspartan117
5 (0.00/day)
So the GTX 275 might just be too old?
And if so what would you recommend as a suitable upgrade, I have my eye on a GTS 250?
2,972 (0.56/day)
System Name Old Fart / Young Dude
Processor 2500K / 6600K
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / CM Hyper 212 EVO
Memory 16 GB Kingston HyperX / 16 GB G.Skill Ripjaws X
Video Card(s) Gigabyte GTX 1050 Ti / INNO3D RTX 2060
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / LG UHD 43" TV
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/ FiiO D03K/ JBL LSR 305
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100 / Rival 110
Keyboard Sidewinder/ Steelseries Apex 150
Software Windows 10 / Windows 10 Pro
NOOOO. The GTX275 is almost 2x times faster than the GTS250. What is your budget and what resolution is your monitor?
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
It just says some certain older ATI cards. Can you get your hands on *any* newer PCIe card to try and see if it works with the ACER?
