hello, temp my rtx 2060 charts are now and idle mode around 47c, i dont know why it is because just 5 hours ago temp was 33c what is it, what do i do
Status
Not open for further replies.
102 (0.05/day)
System Name My pc
Processor Amd ryzen 7 2700
Motherboard Gigabyte aorus b 450m
Cooling LC-POWER Cosmo Cool - LC-CC-95 CPU
Memory Kingstone hyperx fury 2x8 gb 3200mhz
Video Card(s) Asus tuf rtx2060 oc
Storage 1 HDD 4tb,1 SSD 250gb
Power Supply Chiftec 1250w
636 (0.14/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
My prediction is this entire thread will turn into nothing of any use or consequence.
I make this prediction based on not understanding a single bit of the question being asked AND the OP's previous threads... :twitch:
But.............
@FM34: Try and ask your question again with a more precise approach - maybe even using a translator to add in the bits you're struggling with - failing this, those temperatures look "normal" and I wouldn't worry about them.
2,275 (0.97/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
just a guess but has your house heating turned on ?. 47c is nothing to worry about.
AsRock
TPU addict
19,254 (2.95/day)
UK\USA
Cooling D15
But.............
I believe his\her temps are raising over time when idle.
To me it sounds like case air flow MIGHT be to blame, maybe take the side panel off and see what the temps change to which should give you a idea if it can be improved on.
636 (0.14/day)
Or... a more sensible and common thing these days, is that the GPU is sat with its fans off.
So, when the OP starts said rig, the temps of the GPU are low 30's.... after a couple of hours sat on desktop with light loads in low 2D, the core is sitting at mid-40's.
All sounds well here without any airflow issue.
Edit for previous threads of non-consequence:
102 (0.05/day)
System Name My pc
yes but just 5 hours ago the temperature was 33c, i was playing in the nvidi control panel around power menagment but i got everything back by default and since then my temp is so much. Recommend me some aftermarket cooling for tuf rtx2060 gpu
when i see my 44c i turn on 100% fan speed and go down to 33c as soon as i return to default it goes back to 44c
3,738 (0.88/day)
Athens, Greece
Maybe it's fever? Aspririn? Also love the tittle.
Seriously, as the others said, 47 C is more than fine. Your card is not a person to be having problems at 47 C. It can withstand over 80 C or even 90 C. You don't need an aftermarket cooler. And in my opinion, if you are thinking that 47 C is a problem, then you probably don't have any kind of experience with computer hardware to start messing around with after market coolers.
You should also post the model of that RTX 2060 card. It will help to see if that card comes with any kind of "zero rpm" feature.
1,890 (0.75/day)
Cusp Of Mania, FL
Processor Ryzen 9 3900X
Case NZXT H710
Keyboard HyperX Alloy Pro
I wouldn't worry about it, so long as load temps aren't going up to like 90C it's not really important. And even then, it's only really a problem because the card will force itself to run slower and use less power. It's not usually possible for it to run up to temperatures that will damage it. It literally will not do that. You can't even make it do that intentionally.
I mean... could just be fan-stop. When a GPU goes idle, a lot of times the fans will stop until it hits a set point... which could be anywhere from 40-60C, depending on the make of card. This also means that on boot, the fans might not run since it never got hot enough. At that point, it could be in the 30s. But if you run it up to say... 60C, now the fans are going. But say they're set to stop as soon as it drops below 50. In that case, the card will take a very long time to get back down to what you saw before, because the fans aren't running. What are your fan speeds?
Or maybe at around that temperature the fans spin so slowly they don't bring the temperature down much. That could also make it so it takes a good bit of time for it to wind down after doing some work... maybe even flat-lining at a higher point, depending on room temperature and case conditions. Once it goes up, the fans may not spin fast enough to bring it down to that cool 30C, just because of how the curves are set. Either way, you'll almost never idle as low as you do right after booting up fresh, not running the machine. It can take hours for it to creep all the way back down once the card saturates. I've seen it happen many times with budget cards.
Fans... it would have to be fans. Shut the machine down when you go to bed and see how things look in the morning. If it goes back down to ~30C, then you know it's just the behavior of the card. Nothing to worry about... it just holds onto a little of the heat after you work it. Those temperatures are never gonna hurt it. It's not the best cooler, but honestly even if it always idled at ~45C it's good enough.
Please don't buy an aftermarket cooler for this. It's not a good idea to go and gut a card, possibly voiding the warranty, just because it doesn't idle as low as you think it should. Not to mention, there's always a chance you'll damage the card when you pull the cooler off. And that's not even considering that if we were having real temperature problems... like it was running 95C or more under load and slowing down, that's probably a faulty (or just really bad performing) card and you should return it for another, not start buying stuff to make it work like it should.
I really doubt that's the case, though.
Hippocratic oath, man... "Do first no harm." Meaning, before you go in potentially messing something up, try things that don't have that risk. You don't go right to brain surgery for a headache! Again... check out your fan speeds. If you don't have it, download MSI Afterburner and tweak them a bit. You may be able to get it down to where it was before. If there is automatic fan stop on the card, you can bypass it by applying a custom curve that makes them spin all of the time. I did that with my Strix 2060 because the fans make an annoying noise when they spin up. If I wasn't doing that, the fans wouldn't spin at all until around 50C. I mean ASUS seem to think that's fine, because that's how they run out of the box!
Idle may seem high, but it's not like other working cards don't idle in that range. My RX 580 would idle at around 45C, before that, it was a mining card, and now it gets pushed to 85C playing games in another room. Not even close to a problem.
102 (0.05/day)
System Name My pc
I mean... could just be fan-stop. When a GPU goes idle, a lot of times the fans will stop until it hits a set point... which could be anywhere from 40-60C, depending on the make of card. What are your fan speeds?
Maybe at around that temperature the fans spin so slowly they don't bring the temperature down much. That could make it so it takes a good bit of time for it to wind down after doing some work... maybe even flat-lining at a higher point, depending on room temperature and case conditions. Once it goes up, the fans may not spin fast enough to bring it down to that cool 30C, just because of how the curves are set. Either way, you'll almost never idle as low as you do right after booting up fresh, not running the machine. It can take hours for it to creep all the way back down once the card saturates.
i set up a little more aggressive cooler operation.and temp is idle mode about 41c.In load mode temp gpu is about 77c, can i try to replace thermal paste?
1,890 (0.75/day)
Cusp Of Mania, FL
Case NZXT H710
I mean, sure... but it's a risk that won't get you anything other than *maybe* seeing a slightly lower number. 77C is fine for that card. If you don't mind it being louder, bring up the fan speeds in that temperature range. The paste isn't going to make a difference unless it's really bad. In which case temperatures would probably be a lot higher than they are now. It's one of those things where the paste job either works or doesn't. And you'd know if it doesn't. It sounds like your card is properly pasted and seated, so the benefits of replacing the paste are so low you might not even see a consistent difference. We're talking 1-3C.
In your case, I really doubt it'd make a difference. That card has a basic cooling solution, so it'll run hotter than others. But where you're at now isn't going to affect how it performs or how long it lasts. It's still well into the 'normal' range for GPUs.
2,275 (0.97/day)
south wales uk
if a new card don't take it apart as you could void the warranty.
AsRock
TPU addict
19,254 (2.95/day)
UK\USA
Cooling D15
Sounds like it's the cards bios is only ramping the fans up when it get to a temperature, this is pretty normal as so many people over the years complain about fan noise these days.
You could just use afterburner and control the fan to what makes you happy.
You could all so ask the the maker of the v card you have for a more aggressive fan profile but they will most likely just tell you it's all ok which is true.
At least check with the manufacture.
19,379 (3.46/day)
This guy.....3 threads on this card...2 about idle temps...
It's simple. He turned on his pc for the first time... since it's cold, it starts out at idle 33C and slowly goes up as it sits there. Again.. normal.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Duplicate of another thread so this one closed.
Status
