Help Autostart Problem Removing qttask.exe
599 (0.08/day)
Germany,Hannover
System Name ChaosMoes
Processor Intel® Core™ i5-3570K no OC yet
Motherboard Asrock Z77 Extreme4
Cooling Scythe Ninja 3 Rev. B
Memory 16GB 2xPatriot DIMM 8 GB DDR3-1866 Kit (PV38G186C9KRD, Viper 3 Venom Red)
Video Card(s) ASRock Radeon RX 590 Phantom Gaming X 8GB GDDR5 188€@13.07.19 Amazon Sale
Storage Samsung 840 Pro SSD 256GB, + ST32000645NS Seagate Constellation 109€ reichelt.de 2012
Display(s) 27" Phillips PHL 276E9Q 189€ @ Saturn(Germany) 1.09.2018
Case Zaria A20 !!!THANK YOU TECHPOWERUP.COM!!!
Audio Device(s) onboard Sound
Power Supply SeaSonic Prime Ultra Titanium 750W
Mouse Logitech M705
Keyboard Microsoft SideWinder X4 Keyboard
As the title shows i can't remove the stupid qttask.exe from my windows xp pc (sp2).
I tried so far:
Regeditor->RunOnce and Runonex or something like that (also start Menue autostart)
and i thought lookin in the Quicktime setup should help but i can't find where to deactivate it.
(don't answer, uninstall it. I Need it because of my Ipod and Quicktime Alternative doesnt work with I-Tunes!!!!)
Uninstall it...lol
Anyway, I'm not quite sure what you're talking about, but I think your talking about the Quicktime icon that loads into the system tray area of the startmenu with your clock and other junk at startup. If that's the case, Open Quicktime > Edit > Preferences > QuickTime-Preferences > *Top Drop Down Menu* > Browser Plug-in > Uncheck the fourth box down which says, "QuickTime system tray icon."
THX I've found a solution like you said, but it's under Extended Options.
Open Quicktime > Edit > Preferences > QuickTime-Preferences > *Top Drop Down Menu* > Extended Options > last checkbox Load taskbaricon.
Great! Maybe I was using an outdated version. I never use QuickTime.
