Help Needed Building a Server !
zOaib
977 (0.13/day)
FL
System Name BabaJinn's U.F.O
Processor Intel Core i7 975 Extreme @ 3.8 ghz (for now)
Motherboard Asus Rampage Xtreme II X58
Cooling ZALMAN 9900 CPU COOLER Led
Memory 12GB Crucial Ballistix Tracers (Blue Led) 1600 DDR3
Video Card(s) MSI NVIDIA GTX 480 1.5 GB DDR5 384-BIT
Storage 2 x WD Velociraptor 10k rpm 300GB sata + 2x 500GB WD Caviar Sata + 320 GB Seagate Barracuda Sata
Display(s) DELL U2711 27inch Goodness @ 2560 x 1440
Case Mountain-Mods U2-UFO Custom Case (Made in USA)
Audio Device(s) Supreme FX X-Fi MB (Creative)
Power Supply ZALMAN 1000W PSU MODULAR
Software Windows 7 Ultimate 64-bit (Retail Version)
hi guys , i am in the process of buying parts and building one , just wanted if u guys can direct me with the best price to performance ratio on parts and which ones to buy , this server i am setting up will be solely for runnign a ftp server , which will contain unlicensed anime and manga , for people to download .............. so all help from u all is very much appreciated , thx !
just grab a cheap biostar am2 board, sempy64 cpu(256k cache) 1-2gb ram and some 400gb seagate sata drives, would do perfect for you, also i may reccomend that you do torrent tracker insted of ftp as its more reliable and efficent, people wont rely on your bandwith alone but on eachother as well ^^(faster speeds+less load=more stuff shared)
or just grab a old pc and use it as a server :)
if you are just running ftp you can safely go with the cheapest setup you can find. even a pentium 2 class computer can saturate a 10 megabits interface. since you may be running sata disks make sure you have enough sata ports if you plan on having a lot of storage
Agreed, the server won't require any processing power, simply enough options to connect your storage devices.
If you're hosting on the internet you won't even need high end I/O since you're limited by your internet connection. Even on the average LAN 100Mbit is the limit.
You could consider a simple RAID 5 setup though, to keep the data safe.
My recommendation is to go ULV mini-ITX silent. You can get a small form factor case, put one large HDD in there, and leave it on 24/7 at very lower power... but most importantly, without adding noise to your environment.
A ULV mini-ITX silent is NOT the faster thing on the block, but as previous posters have commented, if you are running a web server, or a LAN server with <10 users, then there is more than enough power there.
Don't get confused with all the articles about "power corporate servers". These things are running mailboxes for literally thousands of users, or running active web pages with thousands of concurrent connections.
Stick with something small and simple.
W1zzard mentioned using an old pentium 2 class computer. If you have something knocking around, then OK. But I don't recommend saving money buying a used P2 off ebay. The amount of time you will spend SETTING UP your server, and for the sake of compatibility with a modern OS and USB 2.0 specification, I recommend you use P3 or above.
Also take a look at Buffalo linkstation. This may have the features you require. It's not much bigger than a VHS cassette box, easily transportable, and connect to your LAN router. And it's ready-to-go straight out of the box. In our SOHO office we have two of these things running as fileservers. There are also hacks to these boxes so that they become LAN mediaservers or Linux web servers.
sweet , its good to know i can work with an average proc to get this up n running ...... thx a lot guys.
i think ill go torrent although its a lot more work to keep working trackers on link , but i'd rather have repeating and donating customers than the ones who wont come back of very slow bandwith .
yeah, and you can get decently easy tracker software if you ask around in say the utorrent forums, my advice is to requier a non abusive client list, utorrent,azerus(sp),classic/orignal bt, shareaza and some others dont cheat, bitcommet/bitlord and any clients based on them are suspect at best, many people us them because it allows them to cheat and get stuff without sharing much if anything :(
you could also use pub trackers and just use the server to seed stuff out, there are a few good anime trackers as well as a few decent simi-public trackers as well that allow anybody to upload a torrent ^^
go on ebay and ets some dell gx110 they run well and have p3 933s the us gov ran some on there a few months ago $50 a pop 200 pcs
Man I picked up an old Dell Poweredge 500sc server off eBay last year for 100 bucks all I added was a pci-x raid controller(40$) and a few hard drives(100$) and a giga LAN adapter(25$). Sure it’s no hot rod it’s a p3 1000
But it’s still faster than the internet it’s hooked up too. I use it as an ftp file server with 460 kbs cable my photo customers access their photos on it at decent speeds. Why a used server well it’s a server not a pc being used as one it has a server works chip set and pci-X and runs quite and reliably 7 days a week 365 a year 24 a day with very little down time. Why break your bank account this baby has saved me thousands of $$ in work
thx i think i am gonna do it your way , cause i did budget out 800 bucks , but i dotn wanna use it if i dont need to , i am gonna find a dell used one on ebay. thx again for all your input guys.
no anime porn here sorry ...... russianboy;)
tigerdirect has some $400 HP p4 and 160gb sata hdd but you need the catalog as it is a front page only cost
400bucks, i could make a new torrent/file server for less then that with far more space to boot.
hey i was just looking at the fact it was a new server (hp dx2200 pentium 4)
