Help setting up RAID
DrPepper
The Doctor is in the house
7,482 (1.18/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
Ok I have 2 40gb IDE HDD's and I need help setting them up in raid :cool: just as an experiment. Can anyone give any basic help for me.
XP or Vista?
You'll have to re-install either one your using. Vista is easy to use with RAID, I think. XP with the motherboard disc (raid drivers), still doesn't see my raid! :mad: I did have a RAID0 setup, but started to have problems. It's a pain to get dual boot to work on a RAID, but by the time i got it working. I didn't won't anymore. ha ha
Its Vista but that is installed on another disc. I was thinking about setting up a server edition 2008
Well how much are raid cards for IDE these days.
software raid is crap and pointless... sorry to be harsh, but its true :)
For raid 1... it could be usefull for backup purposes(but very slow)... and for raid 0 , its a waste of time
I could transfer over from my RAID-0 array on my OS drive ~10GB of music in under 3 minutes using software raid (on the motherboard). I dont see that as pointless.
Even if it is crap and pointless I want to know so I can learn how to do it in the future.
Its simple. But its important to know that setting up RAID will require formatting your drives.
Plug in drives.
Go into bios - set drives to RAID instead of IDE.
Raid configuration utility should now appear during bootup.
Create RAID array by following the prompts in the utility.
Reboot and install windows xp, loading your raid drivers off a floppy disk that you created using the raid disk creator on your mobo cd.
Thats it.
If you want a dual boot with vista. You can then use xp to run Norton partition magic and create a partition on your hard drives to seperate the two OS's. Reboot and install Vista on the other partition.
If you are prepared with the software and hardware, its piss easy.
Id just like to also say that the RAID setup isnt the same for all hardware, but it should be pretty similar.
I used the Intel Matrix Raid setup rather than JBOD or the Jmicron onboard raid ports.
