matiasbertotti
- Mar 28, 2024
- 3 (0.04/day)
Hi everyone, i recently being struggling with my CPU cause its being reaching high temperatures while playing videogames, I disabled "Turbo Boost" and my games are still really playable after it but i know I'm losing horsepower of my CPU doing that, I recently found out throttlestop and that I can limit the Pl1 and Pl2 so i can be at normal temepratures while playing, also by just adjusting Speed Shift EPP i found out my CPU does not get high temperatures as before. But I'm a little bit concerned of the messages that i receive of Throttlestop. My question is, I shouldn't care about this? Should i change something? I just want to play videogames with temperatures in between 70 - 80 and not 90 - 100.
The first image is while I'm doing a test with Cinebench, the second one is in idle. Sometimes EDP Other goes red on "Ring".
I added a Third Image while on a playing "The outer Worlds", in the past by this time i would be already hitting 90°C If not more, just by starting the game, but modifying the Speed Shift EPP a little further i see this results and every lecture goes away. What's the reason behind? going back to the desktop EDP Other comes back in Ring and GPU.
Any help will be highly appreciate. Thank you very much
