Help with FPS problems (CPU bottleneck?)
Status
Not open for further replies.
62 (0.04/day)
Processor Ryzen 5 5600x
Motherboard Asrock B450M Steel Legend
Cooling Freezer 34 eSports DUO
Memory Kingston HyperX 16GB 3200mhz
Video Card(s) PALIT GeForce RTX 4070 GamingPro 12GB
Storage 1TB Toshiba Hard Disk
Display(s) MSI Optix G27C5 165Hz
Case Cougar DuoFace Pro RGB black
Audio Device(s) Razer BlackShark V2 X
Power Supply FSP GROUP HYDRO G PRO ATX3.0(PCIE5.0) 1000W
Mouse Glorious Model O
Keyboard Razer Huntsman TE
I have this problem from a while and i don't know from what is it??
I have R7 2700x
GTX 1660 TI OC edition
16gb ram 3200mhz
650W
great cooling
Here in this scenario on everything low, because i play competitive and i need every frame.
I suggest that its CPU bottleneck idk here you can see a picture
do you run your RAM in dual channel and do you have XMP/DOCP enabled?
Reinstall Windows. Something is terribly wrong. Don't install anything aside from fresh NVIDIA drivers and the game. I've seen something like that only when setting Windows Power Management to Power Saver Mode.
What would be the ideal fps for this setup?
Reinstalling Windows is a chore. Try Reset first. Shouldn't touch any data except programs installed in C:/ and various Windows settings but backup User folders if you want to.
assuming this is 1080p (competitive and all) that's insanely low fps
Why are only core 1 showing % utilization? and so high. Do you limit it to using one core only?
idk
yes
i want to ask is my code going to get removed cuz i activated it week ago
how to see if its using only one
200 fps consistant
Please write a useful title for your post.
Are the 60fps frame limiters turned off in the game settings or gpu software?
It might be helpful if you listed all the tweaks you have used on this system and in the game. Might try going back to stock settings everywhere for effect. Your previous posts suggest that performance was good at some point in the past...right?
Already spoke about this in your previous post
I just reported it
There is this thread
And this thread, all relating to same problem.
Definition of Insanity.
@D3N4O
Go to a shop and have them fix it or get on youtube, there are plenty of guides on there for your problems.
I have R7 2700x
16gb ram 3200mhz
650W
great cooling
Sounds like a user bottleneck, take it in to a shop for a checkup and reinstall, your windows key is tied to your hardware and will reactivate anyway.
Some kind of game boosting feature or something is what it looks like to me, one that's failing Todo it's job.
Possibly a miner virus too.
How to see for miner virus tho??
and i think its not miner virus because in task manager its not used anything
Try the full reset then IMHO
if i upgrade to rx 6600 xt will my cpu bottleneck r7 2700x or i should get the gpu and r5 5600x-(maybe)
they are pretty good tho
No you will always have a bottleneck,. Everyone and everything is bottlenecked, but this is a issue isn't it not just hitting a bottleneck , I would deal with the issue I had personally.
well i will just buy rx 6600 xt or rtx 3060
I will say XT
You're playing 1080p low, you will always be bottlenecked by cpu in Unreal Engine. Changing gpu won't do a thing, you can read up on this or throw money on new parts hoping your problems will go away.
my friend has the same build but with 32gb ram and gets 50% usage 200 fps smth like that
Status
