How...Single PCI slot running multiple GPU's
668 (0.66/day)
While browsing through Instagram, I came across a company offering a computer equipped with an X670e AMD-based motherboard. This particular motherboard has only one 4.0 x 16 PCI slot, which poses a limitation on the number of GPUs that can be installed. However, the vendor has found a way to overcome this limitation by running up to 5 Nvidia A-GPUs on a single PCI slot.
The GPUs are connected to the motherboard via single risers, which are then plugged into a specialized type of PCI card capable of accepting all of these PCI cables. This unique setup enables the vendor to operate all the cards from a single PCI lane as if they were running on multiple PCI lanes.
This is a significant advantage, as the everyday AMD chips are not able to accommodate multiple GPUs due to the motherboard's single PCI 4.0 x 16 lane. If there is more than one GPU or lane occupied on the motherboard, the second PCI lane, when used in conjunction with the first, brings the PCI lanes to a dual 4.0 X 8 PCI lane configuration. Moreover, to achieve multiple GPUs at full 4.0x16 lane, processors with Xeon/Threadripper/Epyc chipsets are necessary.
I am intrigued by this setup and curious about the type of "PCI card" utilized to enable multiple GPUs to connect to a single PCI lane. And get full access and results on each GPU. As an end-user, this presents an opportunity to make the most of the PC without having to invest in processors costing over $2000. With AMD's best processor available at $800, multiple GPUs can be utilized to achieve optimal results, even with an ITX motherboard with only a single PCI lane.
How does this work?
I really appreciate any help you can provide.
1,755 (1.10/day)
Some motherboards used to have PCIe switches to enable crossfire/SLI when the CPU didn't have enough native PCIe lanes to support two x16 lane cards. Could this be a similar idea?
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
PCIe switches do that. One (quite extreme) example is a card that you can fit 21 SSDs on; each SSD uses 4 lanes. On that card there's a switch that can handle 100 lanes in total, 84 go to the SSDs and 16 are connected to the PCIe slot. The same thing can be done with graphics cards.
668 (0.66/day)
Thank you for the response. I am not sure.
I comprehend your statement, and I concur with the sentiment expressed. It is regrettable that the card in question bears a steep cost despite its lack of preloaded content. I intend to incorporate two Asus Hyper M.2 X16 Gen 4 cards into my system, each housing SSDs. This configuration will furnish me with the benefits of RAID and personal storage space for the foreseeable future.
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Cards such as this do not include a PCIe switch. They are nothing but wires basically. Their operation depends entirely on the bifurcation (lane-splitting) ability of the processor, and on BIOS support for that.
If you have a Ryzen 7000 CPU, it can split its PCIe x16 bus into x8 + x8. This means it can connect to two graphics cards, or two SSDs on an adapter card, but not more. Further splitting into x8 + x4 + x4 or even x4 + x4 + x4 + x4 is questionable and poorly documented, but other people here may be able to tell you about specific cases when it works.
Two adapter cards can't possibly make 8 SSDs work in a Core or Ryzen system. There are simply too few lanes available in the system.
Here's an example of an adapter card with a PCIe switch (Asmedia brand) on it. But its slot connector is only PCIe 3.0 x8, and M.2 connectors are PCIe 3.0 x4 each. Yet it's costly, the price I see in Germany is 111 EUR.
668 (0.66/day)
Thank you. And I agree with the information you provided.
Here is a picture of the actual setup. I do understand how the PCI lane is shopped up. But something mathmattically is not adding up? How do you tehnically pull 4.0 X 80 out of the lane and chop the 80 / 5? Down the 4.0 X 16. I will admit, I like what the person is doing and how he using this smaller processor to there advantage. This keeps from the need of going big workstation CPU. This brings the bang for the buck down in the serious playing field.
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
The CPU can only communicate with one GPU at any given time. Well, maybe it can communicate with two GPUs at half speed because it can split its 16 lanes into 8 + 8, as I've mentioned before, but this doesn't make a difference. The total bandwidth is 32 GB/s (PCIe 4.0 x16), so every GPU gets 1/5 of that on average. A PCIe switch can't magically improve the bandwidth. But this "low" bandwidth may not be a limiting factor at all, it depends on application of course.
668 (0.66/day)
Thank you - I agree with you. If this person is using this kind of power for rendering/workstation. Maybe the software how some way, is able to tap into all that power. Right now, this has my mind blown. I reached out to the engineers at PNY just to see how this works and I have not heard back yet.
IN my mental, you take an ITX board, place it into an M-ATX case, and insert 4 GPUs to access some nice power!
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
There are adapters to connect four GPU via usb3 to one x16 slot, I've had 6/12 GPU in pcs max in game was quadfire Polaris with two 460's for physx that pc nearly set on fire though.
668 (0.66/day)
Thanks
How does this work? You expressed the cards are connecting from the PCI slot on the GPU (4 X 16) the cable coverts over to USB3. Then the PCI lane/card on the motherboard accepts the converted USB3.
Do you know what kind of card that is? You have had 6 to 12 GPU connected in this manner?
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Thanks
That version was only for mining on due to low bandwidth , quadfire plus was done we ith bulldozer on a crosshair V I think, it's dead now and I have had a mining board thAt had X1 x12 pciex slots.
Look on Alibaba , eBay and Amazon for such adapter's.
668 (0.66/day)
Thank you so much!
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Several generations of both AMD and Intel processors support bifurcating the x16 slot into x4/x4/x4/x4 if you use something like that Asus M.2 adapter card. Some generations are limited to a x8/x4/x4 split.
What you need to get beyond that is a pcie switch. This will allow multiple x16 devices to share one x16 connection (for example). But they are only able to communicate one at a time, meaning this is useful in situations where throughput is not the highest priority.
With the same 100-lane switch Sabrent uses in that m.2 card you can make a 5-to-1 x16 slot adapter to have 5 GPUs connected to one x16 slot on the motherboard. With 4 lanes left unused. Which is probably what those 5 GPU images above are referring to. Apparently that 100-lane switch is rather expensive though, so you won't find any such adapters online for $50.
No idea what the limitations on number of devices on one pcie bus are. But in theory you could go nuts and make a x16 to 84 x1 slots with that switch.
668 (0.66/day)
So are you expressing? Is there no technical way to step on the gas of 5 GPUs simultaneously and pass through the adaptor?
Also, I will have to check on the adaptors. These days, it's hard to tell who is making quality products. I would look for brands like SuperMicro or etc., because that is all I know.
Thanks
631 (0.54/day)
Mouse Logitech G903
Thanks
You are trying to drive 5 cars side by side at 100kph* through a one lane tunnel while still going 100kph. You will have 4 bad crashes. These 5 cars will have to stop and wait to go one at a time to get through safe (4 of them have to stop technically).
There is no physical way to run 5 x16 slots at full speed through one x16 slot. But a switch will let you do the second version above.
*Just a random number picked for simplicity
668 (0.66/day)
I do understand. I do understand I will need to research the 100-lane switch.
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
It seems that motherboard makers were able to unlock these abilities, and Intel and AMD didn't care enough to stop them.
Officially, according to Ark, Intel CPUs could do 8+4+4 before Alder Lake and 8+8 afterwards. AMD CPUs can do 8+8.
@HBSound
This is a separate issue that doesn't really belong in this thread but: why do you need RAID? Capacity? Speed? Resilience against failure? You don't automatically get any of these, and as a general advice I'd say don't mess with it unless you know for certain you need it.
668 (0.66/day)
@HBSound
Someone else inserting RAID using speaking about the multi-SSD card above. They used it as an example.
My whole purpose is to discover how someone can use 5 GPUs in a SINGLE PCI slot.
478 (0.48/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
It is probably a custom ASIC or FPGA with allot of SERDES that is being used in bridge mode (Packet Switch) with custom software to control it and address the data to the cards. Their design uses a riser cable that connects to the motherboard and then to their backplane that has the ASIC bridge IC and the 5 PCIE slots. I will also note that the motherboard has PCIE gen 5, which is double the rate of gen 4 that the video cards are, so it gives them more bandwidth to allocate (Time Slice like Ethernet) to the 5 cards on the backplane.
Here is a link to a TI 4 channel PCIE chip that I used in the past that is doing the same thing but is gen 1.1 by x1. It should give you a better idea of how they are doing it.
TI XIO3130 4 Channel Bridge Chip (Packet Switch)
TI XIO3130 Users Guide
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Microchip and Broadcom make these switches. The chips, that is. Not retail products. Those by Microchip have up to 100 PCIe 4.0 lanes, they make 5.0 switches too but I haven't checked the details.
478 (0.48/day)
Some Where On Earth
System Name Spam
Case Lan-Li A3
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
I just looked at Microchip's site and they do have a PCIe Gen 5 Packet Switch that is large enough handle what they are doing. Broadcom bought PLX a few years back and has not done much with them, which is a shame since they were one of the more advanced PCI-PCIE bridge/switch manufactures.
668 (0.66/day)
Is this pointing in the right direction - https://www.microchip.com/en-us/product/PM50100
Thank you so much!
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Thank you so much!
Yes. Wow. I'm wondering if there's any use for this, at all, at the moment. One application I can think of are large enterprise network switches with many 112-gigabit SFP ports. But those probably have specialised chips inside, SPF lanes are not the same as PCIe lanes and would need some kind of conversion. Apart from that, there's the Nvidia H100 accelerator with a PCIe 5.0 x16 interface. But not much more.
668 (0.66/day)
I got you.
I will go to Microchip and get some direction. Maybe a PCI card is a little on the simpler side? And how do you take advantage of all that kind of technology?
The image above leads with an A6000 and 4-A4500 PCI cards. know the A6000 fills up a complete 4.0x16 when it comes to speed and performance. But I can not say the same for the A4500. I know the A4500 needs a x16 lane, but when it comes to starting performance. I do not know if the card brings that kind of power.
4,108 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Ah, that guy @Wirko again.
But no, that monster card is not a RAID controller. At least it's not advertised, the product page only mentions "Software or OS RAID Supported DataProtection", which is not hardware RAID. But that was not the point here. The card allows connection of many 4-lane M.2 PCIe devices to one 16-lane PCIe slot, that was the point. Devices include these:
These examples have a M.2 connector but it is equivalent to a PCIe x4 slot connector (or a longer x8 or x16 connector with only 4 lanes used).
That would be feasible (hey, the topmost example is a GPU!) but it would also be terribly expensive. Total bandwidth would be limited to where the bottleneck lies, which means the PCIe x16 slot.
