How to Enable ATI Eyefinity in Games?
zanat0s
166 (0.03/day)
System Name Kaizen- continuess improvement
Processor i7 965 Oced @ 4.1Ghz
Motherboard EVGA 3X SLI CLASSIFIED V.760
Cooling watercooled Koolance
Memory 6 X 2 GB Dominator GT 1866Mhz 7-8-7-7 20
Video Card(s) 1 Sapphire 6990(soon to be 2)
Storage Agility-EX 3 120 ggb and one WD black for downloads
Display(s) 2 X 30 DELL 300WFP 2008
Case Silvverstone TJ-07
Audio Device(s) Asus Xonar 1.3 HDMI
Power Supply Tangan 1100 Watt(is this good or not?)
Software Windows 7 74 Bit Pro!
Hi all,
i have 3 Monitors X 30 Inches and i have 2 X 5970CF! i am trying to start games using eyefinity but it is not working.
is eyefinity working only with some games or are there things i should do so the game can play in 3 monitors?
cadaveca
My name is Dave
17,238 (2.48/day)
Nope, very few apps are actually running right...many on ATI's "approved list" don't work right either.
However, you'll get more apps working with your monitors in portrait mode. This maintains the standard FOV's, so causes less issues.
Only 17 apps are actually deemed "eyefinity approved", while another 22 are listed as "ready".
Out of those apps, I can count less than 15 that actually work right in landscape mode. Even many listed to work, don't...they jsut chop the top and bottom of the screen off...and then obscure menus, so you cannot even start teh apps correctly unless you've memorized what to push to load a save, or whatever.
Full list is here:
http://support.amd.com/us/eyefinity/Pages/eyefinity-software.aspx
For my purposes, AlienvsPredator, Dirt2, BFBC2, Dragon Age, Assasin's Creed2, NFS Shift, Valve Source-based games, GTA4, and Hawx, are the only fully working apps at this point. That's far from the 17 listed, and yes, I've tested now over 200 games. I have 180+ games in STEAM alone, so testing has actually been pretty easy.
zanat0s
166 (0.03/day)
i cannot CREATE a group of monitors i do not know why but it simply doesn't work...
cadaveca
My name is Dave
17,238 (2.48/day)
All monitors plugged into the same card?
One card using DisplayPort? Or an ACTIVE DP-DVI adapter?
creating the group is essential, os yeah, that'd be a big hurdle that MUST be overcome.
900 (0.13/day)
Canada
System Name MurderBox #17
Processor Intel Core i7 5930k - 4.5Ghz 1.275v - Bitspower Summit EF
Motherboard Asus X99-E WS - Bitspower THOR AIX99 Full Full Board Block
Cooling SR-1 480, 8x Corsair ML120 , MCP350, I&H Res 250, PETG hard pipe, Mayhems Pastel White
Memory 32GB G.Skill Ripjaws 4 DDR4 2666
Video Card(s) Nvidia GTX 1080 Ti Founders Edition - EK Fullcover waterblock with Backplate
Storage 970 Pro 512GB, 960 EVO 500GB, PM961 512GB, 3x SM951 256GB,, WD Black 2TB, Seagate 4TB
Display(s) ASUS PG348Q 3440x1440, 2X ASUS PB278 2560x1440
Case MurderMod TJ07 With Illuminated mid-plate
Audio Device(s) Schiit Bifrost > Schiit Asgard > Hifiman HE400i - Audio Technica AT2020
Power Supply Corsair AX1200i With custom MDPC Sleeve and Noctua NF-A14 iPPC-3000 PWM
Mouse Steelseries Rival 600
Keyboard Corsair K95 RGB
Software Microsoft Windows 10 Professional 64bit
At this time I don't think Eyefinity works correctly with quad crossfire setups. try disabling crossfire x and see if it works then. If that is the case then you know that it is the second 5970 that is causing the issue.
Oh yeah and an active displayport adapter is required unless you have displayport monitors
zanat0s
166 (0.03/day)
i disabled crossfire andi could have eyefinity!why i cannot have eyefinity with 2 5970?
842 (0.15/day)
Edmonton, AB, Canada
System Name Project Neverending
Processor AMD 9700X
Motherboard Asus 870 TUF
Cooling Corsair Titan 360
Memory 32 GB Kinston Fury 5200
Video Card(s) Asus RX 7900 XTX OC
Storage Samsung 990 Evo NVMe, 2 Samsung 860 Evo 1TB
Display(s) Acer Predator X34 (3440X1440), Samsung U28D590 (3840X2160)
Case Lian Li 011 Dynamic XL
Audio Device(s) Supreme FX X-Fi, Logitech 5.1 speaker system
Power Supply Corsair HXi 1000
Mouse Logitech G703
Keyboard Logitech G105
Benchmark Scores Updates coming soon ®
You'll have to ask ATi why.
4,926 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
Cause Quadfire can have alotta issue's Bra!
zanat0s
166 (0.03/day)
so?
am i screwed that god 5970? can't ati solve that with drivers?
REALIN
55 (0.01/day)
Processor AMD Phenom 2 x4 940 BE (3.5GHz)
Motherboard Asus M4A78-E
Cooling Corsair H50 Hydro
Memory Kingston 4GB DDR2 (800MHz)
Video Card(s) Sapphire 5870 1GB (900/1300) Vapor-X
Storage Western Digital Black 32MB 1TB
Display(s) Samsung SyncMaster P2450
Case Antec Twelve Hundred
Power Supply Fractal Design 650W
Software Windows 7 Professinal 64bit
I've seen people use 2x 59700 in quad crossfire using eyefinity. But I don't know how to fix it!
716 (0.13/day)
C:\Kitteh
Processor i7 2600K | Phenom II 840
Motherboard ASUS P8Z68 Deluxe | ASUS M4A88T-M
Cooling Corsair H60 | Scythe Samurai ZZ
Memory 4x4GB Samsung Green 1600 @ 1866 | 2x2GB Corsair XMS3 1333
Video Card(s) Evga GTX 670 FTW | On Board AMD
Storage 2 x 64GB Samsung 830, Velociraptor 300GB,1TB Black,1.5TB Black |10TB server
Display(s) HP 2509m 25" 1080p
Case Lian Li PC-V1020A | Lian Li PC-V354A
Audio Device(s) Azuntech Bravuria 7.1 | On-Board (Disabled)
Power Supply Seasonic X-series 760 , Seasonic X-series 760
Software Windows 7 Ultimate X64 | UnRaid (CentOS)
zanat0s
166 (0.03/day)
lol? what else can i do ? save me...
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
well you are not really giving enough info.
"i cannot create a group" gives us no where near enough information.
I have eyefinity with 2x5850s in Xfire - I have had great luck with games working. idk off the top of my head but I KNOW many more than dave listed. what do you mean by "fully working"? some have hud or menu issues, and that sucks - but the game itself runs fine and looks good.
empire total war is an example of that. settlers 7 too. and Saboteur. then there are tons i saw no problems with: tropico 3, GRiD, Burnout Paradise, Eve, Just Cause 2, SWtFU, Batman AA, Mount & Blade, Red fAction Guerilla, RTS games (World in Conflict, Civilization 4, Europa, Cities XL, Napoleon Total War...Fallout 3 worked great after some tweaking, stalker 2 & 3 as well (didn't test 1) , Metro 2033
and more i can't think of. if I look through my games list I am sure I will almost double my list. then include yours and all the ones neither of us tested.
you(dave) make it sound like it barely works and you can only use it for a few different things, which is just not true. even games with no native support , often support config file changes. and many simply support larger resolutions without any file messing, the settings just become available. and as far as landscape... i have found the issue ends up lying in my final resolution, not my display mode. too tall and it doesn't work it seems to me.
so yeah the tech is still relatively new despite it's "age" , but I think it already works very well and with future improvements will become amazing.
zanat ... more info please :)
cadaveca
My name is Dave
17,238 (2.48/day)
Maybe I have these issues becaues of running 19020x1080 monitors instead of 1920x1200...but yeah, I actually forgot about those apps, grid, Dirt etc...
For me, working is perfect, and not requiring any "tweaking". As far as I am concerned, alot of the titles with issues jsut simply need a patch...but I dunno that can happen for some of them.
And yes, it's not so bad, except performance with 2x 5870 isn't enough, and 3 cards doesn't work...and pretty much every new titles works great.
I thought they had 5970 CFX eyefinity working too...
4,966 (0.85/day)
yeah idk about more than 2 gpus - and i would definitely agree there should be no tweaking necessary. but if you want it to work you can make it for the majority of games i have tried.
I am using 1080 as well, and it does add fisheye and make it awkward with such large horizontal and small vertical resolution proportionally. GTA4 series has been the best game I have found as far as reducing fish eye and actually extending rendering further. can't wait for RDR on PC to try it :)
as for performance, I can't complain about that much either. with 2x5850s at 5760x1080 I am at mid to high settings in all my games. the only one that i ha trouble with at higher settings was just cause 2. but jc2 has weird framerates as is so that played into it.
so it's not enough for max, or as much eye candy as i want. which is what i think you are saying. on newer, better games- with 600$ worth of video card I have to choose between better quality and eyefinity... can't have em both. that does suck indeed... but i am happy overall.
cadaveca
My name is Dave
17,238 (2.48/day)
I cannot play GTA4 @ med settings.:laugh: It plays...but it BURNS ME EYES!!!
:laugh:
I've ended up using teh Dell3008 far more often than not.
BFBC2 eyefinity is fantastic!!! Good framerates too! Dirt2...ugh...Grid...fantastic!
And yeah, I need to max everything out. I can do that @ 2560x1600, 4xAA, with 2x5870, so naturally I want the same visual experience using eyefinity!!
REALIN
55 (0.01/day)
Nothing new that GTA 4 on PC is not running great. :(
cadaveca
My name is Dave
17,238 (2.48/day)
Runs fantastic on high settings @ 2560x1600, with 2x5870...I'm almost done the gay tony DLC, finished Lost and damned...
REALIN
55 (0.01/day)
Still crossfire dont work, on both my computers I got a like 5 more fps disabling crossfire for GTA 4. Have not checked with DLC but guess its still the same
cadaveca
My name is Dave
17,238 (2.48/day)
Crossfire works fine here...I get about 60% more from second card. Soemthing else must be causing your problem...are you running the latest patch? Also, how are you measuring FPS? If you are using the built-in tests, they are flawed...when I played teh actual game parts of the new tests from teh DLC, tests were FAR FAR slower than actually in game...
Single card, I cannot run high @ 2560x1600...med only.
REALIN
55 (0.01/day)
Now I only have one 5870 1GB so can't check. But before when I had 2x 4870 1GB I had that problem and I know alot of others had problem with crossfire. Have not read anything that they should fixed crossfire for GTA 4 and think SLI didn't work neither. :wtf:
Maybe I missed that they said they fixed crossfire game patch or driver notes.
REALIN
55 (0.01/day)
Oh forgot to mention, I checked with the game benchmark! :p
cadaveca
My name is Dave
17,238 (2.48/day)
Yeah, the benches are kinda nerfed, IMHO. The only time I get some slowdown below 60FPS is when it rains, or there is heavy fog...light fog is fine.
The new shadow settings seem to make a world of difference.
I had similar poor performance with 4870 as well as 4890's...just not enough grunt, I guess.
REALIN
55 (0.01/day)
Yeah the new shadow system seems good. Hope next GTA game actually is perfect optimized from the beginning!
4,926 (0.79/day)
Multidimensional
VR HMD ( ◔ ʖ̯ ◔ )
Lol, had a couple of drinks if your wondering why my slang is really gay lol, plus I was watching 2 fast 2 furious at the time:laugh::laugh:
