How to get rid of coil whine?
Does all new pascals whine?
  • Yes, nvidia failed this city!
    Votes: 3 30.0%
  • No. You are extreamly unlucky... We pitty you fool!
    Votes: 7 70.0%
  • Total voters
    10
232 (0.05/day)
System Name Vegos Whispering Merlin
Processor from 7980XE @4,8GHz to 7740 @5,4GHz, all delided + custom IHS
Motherboard EVGA DARK
Cooling lots of BitsPower, , lots of HWLabs, eloop, Mayhems aurora
Memory 32GB Galax HOF OCE 3800 15/16/16/36
Video Card(s) SLI HOF 1080Ti @2100MHz
Storage Intel 900P 280GB + Storage 1,2TB P3520 & 2TB P4500
Display(s) Predator 144Hz 27" IPS
Case Caselabs Merling SM8
Audio Device(s) Razer HS + Razer Leviatan
Power Supply EVGA T2 1600W
Mouse Logitech MX Master for work and Razer Lancehead for gaming
Keyboard Razer Ornata Chroma
Software W10Pro
Benchmark Scores One GPU: www.3dmark.com/spy/3203275 SLI: www.3dmark.com/spy/3460940 www.3dmark.com/fs/15137359
ok, so i have at this moment my 6th 1080 and 4th 1070 and absolutely all of them have a coil whine
and its laud...
as you can see all brands, FE and clocked models - all do whine
the most quiet noise is generated by evga 1070 but still is laud as hell especially when all of them are watercooled
in most of them i already voided warranty by removing stock cooling so i dont care what i have to do with it - just please tell me there is a way to get rid of it.
few years back i have coild whime from corsair ax PSU and i red about some ideas to fix it and it sugested to use silicon.
Can this work with VGAs? where do i apply it?
I do not want to spend this much money and noth have a quiet PC i ment to build!
Please help!
glue gun over coils.
You basically melt it on pcb on one side over coil to other side of pcb like a fat thick line.
I can't stand coil whine either, so I made sure to get one that's good for it: the Pailit GTX 1080 GameRock. Seriously quiet cooler and only very slight coil whine. Not possible to completely eliminate it.
https://www.techpowerup.com/reviews/Palit/GeForce_GTX_1080_GameRock
Just get the non-Premium one and overclock it if you want and don't bother with the overpriced G-Panel.
where do i put this glue?, all over it?
Like this
around these tiny "boxes" right? between it and PCB?
I cant say so much about how pascal GPU based cards coil whine, but remember that 900 series also where plage of coil whine and where also hit by coil whine with the first cards i got from EVGA those where two EVGA GTX 970 FTW cards and the cards suffers from coil whine so i returned them.
In the other hand i have only had good thing when it comes to GPU´s from Zotac. I have so far had 7 cards from Zotac and none of them have ever suffered from coil whine over 3 models. 3 x GTX 285, 2 GTX 660 TI and those cards i have now 2 x GTX 970.
If you havent tried Zotac yet them try to find some info about zotac based cards about coil whine, cause Zotac cut maybe be your saving from coil whine. Well it up to you.
By the way some times your PSU can also be the cause of coil whine in your video card.
Yeah,you can do it that way or just straight across and touch pcb on both ends.
I would make sure the warranty is void 1st. and he needs to be careful as if he's not the cooler may not fit back on after.
answered: "Yes, nvidia failed this city!" because reason...
reason:
well ... a lot of green ...
nonetheless my own card has no coil whine (my previous did ... )
You might consider a well acoustically insulated case.
My PSU has a bit of coil whine which is noticable with the side panel removed but totally inaudible with it in place.
Sounds like you have very good hearing at that frequency. Me on the other hand can't hear a thing above 3000 Hz coil whine has never been an issue
you can easily "undo" the glue with a little bit of heat to warm the glue up then just peal it off like a sticker, should all come off in one peace, we are after all talking about arts and crafts glue ;)
Turn up your music more :D
