- Aug 16, 2005
- 27,895 (3.84/day)
- Alabama
System Name | RogueOne |
Processor | Xeon W9-3495x |
Motherboard | ASUS w790E Sage SE |
Cooling | SilverStone XE360-4677 |
Memory | 128gb Gskill Zeta R5 DDR5 RDIMMs |
Video Card(s) | MSI SUPRIM Liquid 5090 |
Storage | 1x 2TB WD SN850X | 2x 8TB GAMMIX S70 |
Display(s) | 49" Philips Evnia OLED (49M2C8900) |
Case | Thermaltake Core P3 Pro Snow |
Audio Device(s) | Moondrop S8's on Schitt Gunnr |
Power Supply | Seasonic Prime TX-1600 |
Mouse | Razer Viper mini signature edition (mercury white) |
Keyboard | Wooting 80 HE White, Gateron Jades |
VR HMD | Quest 3 |
Software | Windows 11 Pro Workstation |
Benchmark Scores | I dont have time for that. |
wouldn't a range extender be able to do the same?
The short answer is no. The right answer is it always depends on the device responding and the amplification. Directional antenna and cranking transmit power arent real solutions especially if say the receiving device is a cell phone. Because the cell phone for example is going to be under the impression since it is connected that the device will "hear it". However the cell phones transmit power is no where NEAR as high as an access point or router with the TX power cranked or using a directional antenna. So the reception ends up WORSE on the device because instead of failing off to say cellular it sees that its signal is "good" so it will happily retransmit into nothingness.
Upping transmit power is also terrible for things next to the AP or router. Which is why I cringe at people that mention "my X is right next to my router/AP, my signal still sucks." Imagine (In laymans) you are down the street and someone is screaming at you and you cant hear. So instead they use a mega phone so you can hear them and they can speak normally (increase TX power). Seems to make sense. But now imagine you are NEXT to the person with the megaphone. Instead of understanding them and having a conversation no one can hear you, and you cant quite understand them because its SUPER LOUD.
EDIT:: Now with that said, I just couldnt standby and really wanted to clear some misconceptions about wireless. In OPs case it likely isnt that extreme. I mean 10m is a little over 30ft. Its a bit of a gap. He might get away with some kind of repeater or a cheap PtP system. His performance will likely depend a lot on what he wants to spend money on though.
